I current running OH 2.5.10 in my docker environment. After I updatet to 2.5.10 the Alexa Binding not working any more. Then I use the snapshot version 2.5.11 and the binding working again.
But in my logs I get same error messages:
2020-12-14 11:07:03.699 [WARN ] [mazonechocontrol.internal.Connection] - Parsing json failed
com.google.gson.JsonSyntaxException: java.lang.NumberFormatException: For input string: “9:1889867878”
at com.google.gson.internal.bind.TypeAdapters$7.read(TypeAdapters.java:227) ~[?:?]
at com.google.gson.internal.bind.TypeAdapters$7.read(TypeAdapters.java:217) ~[?:?]
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$1.read(ReflectiveTypeAdapterFactory.java:129) ~[?:?]
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:220) ~[?:?]
at com.google.gson.internal.bind.TypeAdapterRuntimeTypeWrapper.read(TypeAdapterRuntimeTypeWrapper.java:41) ~[?:?]
at com.google.gson.internal.bind.ArrayTypeAdapter.read(ArrayTypeAdapter.java:72) ~[?:?]
at com.google.gson.internal.bind.MapTypeAdapterFactory$Adapter.read(MapTypeAdapterFactory.java:187) ~[?:?]
at com.google.gson.internal.bind.MapTypeAdapterFactory$Adapter.read(MapTypeAdapterFactory.java:145) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:888) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:853) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:802) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:774) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.parseJson(Connection.java:966) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.getPlaylists(Connection.java:1131) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.refreshData(AccountHandler.java:552) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.refreshAfterCommand(AccountHandler.java:830) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_275]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_275]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_275]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:1.8.0_275]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_275]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_275]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_275]
Caused by: java.lang.NumberFormatException: For input string: “9:1889867878”
at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:2043) ~[?:1.8.0_275]
at sun.misc.FloatingDecimal.parseDouble(FloatingDecimal.java:110) ~[?:1.8.0_275]
at java.lang.Double.parseDouble(Double.java:538) ~[?:1.8.0_275]
at com.google.gson.stream.JsonReader.nextInt(JsonReader.java:1201) ~[?:?]
at com.google.gson.internal.bind.TypeAdapters$7.read(TypeAdapters.java:225) ~[?:?]
... 25 more
2020-12-14 11:07:03.714 [WARN ] [mazonechocontrol.internal.Connection] - Illegal json: {“playlists”:{…
2020-12-14 11:07:11.976 [ERROR] [trol.internal.handler.AccountHandler] - refresh data fails with unexpected error
java.time.format.DateTimeParseException: Text ‘2020-12-14TnullZ’ could not be parsed at index 11
at java.time.format.DateTimeFormatter.parseResolved0(DateTimeFormatter.java:1949) ~[?:1.8.0_275]
at java.time.format.DateTimeFormatter.parse(DateTimeFormatter.java:1851) ~[?:1.8.0_275]
at java.time.ZonedDateTime.parse(ZonedDateTime.java:597) ~[?:1.8.0_275]
at java.time.ZonedDateTime.parse(ZonedDateTime.java:582) ~[?:1.8.0_275]
at org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler.updateNotifications(EchoHandler.java:1283) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.lambda$4(AccountHandler.java:489) ~[?:?]
at java.util.concurrent.CopyOnWriteArrayList.forEach(CopyOnWriteArrayList.java:895) ~[?:1.8.0_275]
at java.util.concurrent.CopyOnWriteArraySet.forEach(CopyOnWriteArraySet.java:404) ~[?:1.8.0_275]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.refreshNotifications(AccountHandler.java:488) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.refreshData(AccountHandler.java:585) ~[?:?]
Any idea about this error message?
