The problem is most likely that your rule assumes that EPBUpdate will contain a string with at least one colon (:) and that in some cases this is not true, hence status.get(1)will fail:
val String sensor_state = status.get(1)
I would add the following debug line immediately below then so you can see which state is giving you problems:
rule "Water_Sensor"
Item Water_Status received update
val String loggerName = "Water_Sensor"
logDebug(loggerName, 'Water_Status.state = "{}" (previously "{}")',
Water_Status.state.toString,
Water_Status.previousState().state.toString
val EPBUpdate = Water_Status.state.toString
val status = EPBUpdate.split(":")
if (status.length < 2) {
logWarn(loggerName, 'Water_Status.state = "{}" - It contains no ":" separator',
} else {
// The sensor state is the 2nd parameter
postUpdate(Water_Update, sensor_state)
switch (sensor_state) {
case "Water Detected": {
sendCommand (Water_Status , "LON")
case "Nothing": {
sendCommand (Water_Status , "LOFF")
To see the debug level messages at the start of the rule, you can either set the log level to DEBUG (log:set DEBUG org.openhab) or temporarily replace logDebug with logInfo which will display INFO messages (default log level for org.openhab).
