i was at openhab 2.5.12 and tried to upgrade to 3.0.1 using sudo openhabian-config.I had an error at the end but everything seems to be upgraded.
Version and Main UI is the right one and my config and things are there and working .But…something is wrong,frontail log viewer says “openhab2”,folders at samba shares are still named openhab2…my log is
openhabian@openhab:~ $ sudo openhabian-config
2021-03-19_10:11:02_EET [openHABian] Checking for root privileges... OK
2021-03-19_10:11:03_EET [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2021-03-19_10:11:03_EET [openHABian] openHABian configuration tool version: [stable]patchday-20210119-1116(5e807c0)
2021-03-19_10:11:04_EET [openHABian] Checking for changes in origin branch stable... OK
2021-03-19_10:11:07_EET [openHABian] Switching to branch stable... OK
2021-03-19_10:11:13_EET [openHABian] Updating Linux package information... OK
2021-03-19_10:11:23_EET [openHABian] Preparing openHAB installation... 2021-03-19_10:11:34_EET [openHABian] Beginning openHAB backup... 2021-03-19_10:14:57_EET [openHABian] Creating openHAB backup... OK
2021-03-19_10:15:25_EET [openHABian] WARNING: We were unable to detect Java 11 on your system so we will install the openHABian default (Zulu 11).2021-03-19_10:18:10_EET [openHABian] Installing Java Zulu prerequisites (libc, libstdc++, zlib1g)... OK
2021-03-19_10:18:31_EET [openHABian] Downloading Java Zulu 11 32-Bit OpenJDK... OK
2021-03-19_10:22:27_EET [openHABian] Installing Java Zulu 11 32-Bit OpenJDK... OK
2021-03-19_10:23:00_EET [openHABian] Installing Java Zulu CEK to enable unlimited cipher strength... OK
2021-03-19_10:23:01_EET [openHABian] Installing openHAB... 2021-03-19_10:23:01_EET [openHABian] Beginning install of latest openHAB3 release (stable)... OK
2021-03-19_10:24:06_EET [openHABian] Adding required keys to apt... OK
2021-03-19_10:24:09_EET [openHABian] Installing selected openHAB version... OK
2021-03-19_10:32:27_EET [openHABian] Setting up openHAB service... OK
2021-03-19_10:32:30_EET [openHABian] Optimizing openHAB to run on low memory single board computers... OK
2021-03-19_10:32:30_EET [openHABian] Setting openHAB HTTP/HTTPS ports... OK
2021-03-19_10:32:30_EET [openHABian] Creating dependencies to jointly start services that depend on each other... OK
2021-03-19_10:32:32_EET [openHABian] Removing delay on loading openHAB rules... OK
2021-03-19_10:32:33_EET [openHABian] Adding an openHAB dashboard tile for 'openhabiandocs'... Replacing... OK
OK
OK
2021-03-19_10:35:37_EET [openHABian] Deleting mapdb persistence files... OK
2021-03-19_10:35:37_EET [openHABian] Migrating Amanda config... OK
2021-03-19_10:35:37_EET [openHABian] Migrating Samba and mount units... OK
OK
2021-03-19_10:36:04_EET [openHABian] Migrating frontail... OK
2021-03-19_10:36:19_EET [openHABian] Migrating homegear... sed: can't read /etc/systemd/system/homegear.service: No such file or directory
OK
FAILED (restart ZRAM)
2021-03-19_10:37:31_EET [openHABian] Updating Linux package information... OK
2021-03-19_10:37:31_EET [openHABian] Beginning install of latest openHAB3 release (stable)... OK
2021-03-19_10:37:33_EET [openHABian] Adding required keys to apt... OK
2021-03-19_10:37:35_EET [openHABian] Installing selected openHAB version... OK
2021-03-19_10:37:59_EET [openHABian] Setting up openHAB service... OK
2021-03-19_10:38:03_EET [openHABian] Optimizing openHAB to run on low memory single board computers... OK
2021-03-19_10:38:03_EET [openHABian] Setting openHAB HTTP/HTTPS ports... OK
2021-03-19_10:38:03_EET [openHABian] Creating dependencies to jointly start services that depend on each other... OK
2021-03-19_10:38:05_EET [openHABian] Removing delay on loading openHAB rules... OK
2021-03-19_10:38:07_EET [openHABian] Adding an openHAB dashboard tile for 'openhabiandocs'... Replacing... OK
OK
2021-03-19_10:39:49_EET [openHABian] Checking for default openHABian username:password combination... OK
2021-03-19_10:39:49_EET [openHABian] We hope you got what you came for! See you again soon ;)
any help?
