Java Runtime Environment: java version “1.8.0_121”
openHAB version: 2.3.0-SNAPSHOT, build 1220
Installation type: manual (installed to /opt/openhab2/
The lack of a more command is causing the help command to fail in the karaf console:
pi@rpi $: ssh openhab@localhost -p 8101
openhab> help
Command not found: more
openhab> help less
less - file pager
Usage: less [OPTIONS] [FILES]
-? --help Show help
-e --quit-at-eof Exit on second EOF
-E --QUIT-AT-EOF Exit on EOF
-F --quit-if-one-screen Exit if entire file fits on first screen
-q --quiet --silent Silent mode
-Q --QUIET --SILENT Completely silent
-S --chop-long-lines Do not fold long lines
-i --ignore-case Search ignores lowercase case
-I --IGNORE-CASE Search ignores all case
-x --tabs Set tab stops
-N --LINE-NUMBERS Display line number for each line
--no-init Disable terminal initialization
--no-keypad Disable keypad handling
Launching the openHAB runtime...
__ _____ ____
____ ____ ___ ____ / / / / | / __ )
/ __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __ |
/ /_/ / /_/ / __/ / / / __ / ___ |/ /_/ /
\____/ .___/\___/_/ /_/_/ /_/_/ |_/_____/
/_/ 2.3.0-SNAPSHOT
Build #1219
Hit '<tab>' for a list of available commands
and '[cmd] --help' for help on a specific command.
Hit '<ctrl-d>' or type 'system:shutdown' or 'logout' to shutdown openHAB.
openhab> help
bundle | Enter the subshell
bundle:capabilities | Displays OSGi capabilities of a given bundles.
bundle:classes | Displays a list of classes/resources contained in the bundle
bundle:diag | Displays diagnostic information why a bundle is not Active
bundle:dynamic-import | Enables/disables dynamic-import for a given bundle.
bundle:find-class | Locates a specified class in any deployed bundle
bundle:headers | Displays OSGi headers of a given bundles.
Looks like it is working for you just fine. Could you try this command:
openhab> help shell
And see if shell:more is an available command? or perhaps:
openhab> shell:more --help
I do not have the shell:more command available in karaf. The only pager I have is shell:less. It seems the default pager is set to a command which doesn’t exist in my particular case.
openhab> more -?
less - file pager
-? --help Show help
Your more command seems to be aliased to less. Mine is not, for whatever reason. Strange.
I just checked /opt/openhab2/userdata/etc/shell.init.script and the following alias is defined for help:
help = { *:help $args | more } ;
But since I don’t have a more command in my Karaf shell, I changed this to:
help = { *:help $args | less } ;
This has solved the problem of using the help command. The question is…why don’t I have a more command in my Karaf shell (since the Karaf documentation says that command is implemented by default). I seem to be the only one with this problem…
Did you install openhab via the apt repos or manually?
Sorry, I should have posted what fixed this for me (of course, once it was fixed, I just moved on…).
I replaced the contents of my shell.init.script with the contents of the same file from the openhab github repo.
They were quite different. My shell.init.script had the default values from the karaf repo and/or documentation. Somehow the OpenHAB upgrade script didn’t touch that file…weird.
