first of all a happy new year and thanks to everyone for continuously supporting to brinh Alexa control to openhab.
I am currently on OH3.2 in the docker version. I also had the websocket error for quite some time. Now I tried the sihui-option to go with the new addon. Currently the version being downlaoded is 3.2.9.
Unfortunately I do face an issue.
Installing the binding works. Then adding an amazon account thing also works.
When trying to configure via “http(s)://:/amazonechocontrol/fddeaeac89” I am not able to log in.
First, entering email and password takes me to OTP-entry. I receive a code via SMS, so my Aamazon credentials seemed to be ok. After entering the OTP code, I get forwarded to URL “http:///amazonechocontrol/account-thing/ap/signin” showing the following error message:
“Login to ‘amazon.com’ failed: Request failed”
I tried multiple times, no success. The same procedure works with the OH3.2 binding (leading to websocket error, though).
Any help would be appreciated as this binding proved to be valuable and is badly missed
Please try installing the distribution version (and only that, uninstall the other one) and try to login. If that does work, uninstall the distribution version again and install 3.2.9 again, it‘ll pick up the configuration. Could be a bug.
After the login you can switch back to the other version. It‘s an issue with generating the serial number before login, so after the initial login everything works (restoring the login is fine).
Although I was trying and guessing around a bit on the sequence of steps and when to remove the old binding. After a few logins I think it worked. I now do have only your binding active, the things are online and I receive no websocket errors.
Thanks for the good job! And thanks for investing your time on a Sunday
Already found the bug. Silly me. Used a different ordering of parameters in the constructor definition and when calling that constructor. That resulted in an invalid device serial number.
i tried to activate the “new” 3.2.9 and stuck at the same point in the login. I remember back than the 2-point-authentication was needed to activate the Account. After binding activation i deactivated the 2-point-authentication in amazon again. So i switch it back on, however, still no success. So i will de-install 3.2.9 again and install 3.2 to activate the account and than switch to 3.2.9?
Dont know.
I de-installed 3.2.9 now and just installed 3.2. Did no change to the things or the account-thing. After installing 3.2 its working again. The http(s)://:/amazonechocontrol/account1 shows all my devices.
However, after de-installing 3.2 again and installing 3.2.9 again all things are again offline and log-in doesnt work. Still did no change to all the things.
One side information: After login didnt work with 3.2.9 i deleted the old account-thing (text based thing) and created a new one in 3.2.9 in the UI. Maybe this is the issue.
Think i will stay now at 3.2 and wait for an update. Can you just post a short notification here so that i can recognize it?
If it works on 3.2, switching to 3.2.9 should work. If that doesn’t work, there is another issue. It could be related to the text-based thing definition. I recommend to never use that and can‘t provide any support for that.
I am on OH 3.2 stable.
I did 1. and 2. and after less than 1 minute all went online again and the web socket error disappeared
Kudos to @J-N-K for his great work!
v3.2.0 I can set up, login etc. but get the Web Socket Error and the Amazon Echo app cannot see any of the openhab items.
On 3.2.9, I cannot log in. Error is Login to ‘amazon.com’ failed: Request failed. Maybe a localisation issue? I need to log in to amazon.co.uk although I’m not sure if, for the purposes of this binding, it matters.
Please send TRACE logs of the login attempt either by PM or via mail to github@klug.nrw. Do not post them here.
Please note: the „login“ (i.e. via /amazonechocontrol/account) is not working for 3.2.9. if you have an account that is logged in, it should work.
If you tried to install 3.2.9 and then tried to login via /amazonechocontrol/account, the storage is probably corrupted. I‘m currently trying to figure out what is the easiest way to resolve that.
Edit: For the Amazon App to see your items you don’t need the amazonechocontrol binding. You have to add proper metadata and install the Alexa openHAB skill.
Where do you try to login (amazon.com or another domain?) And please go to you user data folder (e.g. /var/lib/openhab on Debian based system). There should be a amazonechocontrol%3Aaccount%3A<thing-id>.json-file. In that file, do you see a session AND a sessionStorage entry or only one of them?
And if you just uninstall 3.2 and install 3.2.9 (while being logged in!) this is not working? Not even after a restart? Do not log out on the account page and don’t disable or change things. If that still does not work, please
