Oliver2
(Oliver)
January 3, 2021, 11:41pm
1
Raspberry Pi4 4GB
Fresh installation of v1.6.2 Image / openhab-config v1.6.2-1087
openhabian-config Menu #14 (Update file permissions of commonly used files and folders) creates the following error:
Applying file permissions recommendations... FAILED (samba and 3rd party logdir)
What can I do to provide more information?
layout: documentation
title: openHABian
source: https://github.com/openhab/openhabian/blob/main/docs/openhabian-DEBUG.md
<!-- Attention authors: Do not edit directly. Please add your changes to the appropriate source repository -->
This document is meant to give a guiding hand to users when their openHABian install fails either on initial image installation or later on when running menu options that install or configure optional components.
::: tip
[TLDR](https://www.howtogeek.com/435266/what-does-tldr-mean-and-how-do-you-use-it/)
Set `debugmode=maximum`in `/etc/openhabian.conf` and see `/boot/first-boot.log` for image installation else record the terminal output.
**Please do not ask for help on the forum unless you have _FULLY_ read this guide.**
**Attention:**
If you do not use the image but use `openhabian-config` manually - either to run `openhabian-config unattended` or interactive use -, **there is no logfile**.
To record output in this case, you need to configure your terminal client to record and save the command line output.
This file has been truncated. show original
There will be times when you discover a bug in OH. This tutorial explains how to file an issue so the developers can know about the bug and hopefully fix it.
Do I Have a Bug?
openHAB is a complex system with lots of options and ways to configure various capabilities. As the old saying goes, openHAB gives you a lot of rope with which to hang yourself.
So how do I as an average user know whether I’ve done something wrong or if there is a bug? The good news is we don’t expect you.
Step 1: Ask fo…
Set debug mode to maximum then try again it may give you a better reason than Failed.
Oliver2
(Oliver)
January 4, 2021, 12:18am
3
I see. Error comes up because it accesses some ZRAM directories but ZRAM is disabled on my device.
Wolfgang_S
(Wolfgang_S)
January 4, 2021, 11:41am
4
Oliver2
(Oliver)
January 4, 2021, 11:50am
5
You’re right. I checked Github before posting but waited for a day. Meantime the issue was raised…
