Due to a failed SD card I am setting up the latest build of Openhabian on my Raspberry Pi 3+
Unfortunately when I try to change to the latest testing build I get the following error.
2020-05-13_14:57:26_BST [openHABian] Checking for root privileges... OK
2020-05-13_14:57:26_BST [openHABian] Updating Linux package information ... 2020-05-13_14:57:26_BST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2020-05-13_14:57:26_BST [openHABian] openHABian configuration tool version: [master]v1.5-599(a2ee130)
2020-05-13_14:57:26_BST [openHABian] Checking for changes in origin... OK
2020-05-13_14:58:01_BST [openHABian] Updating Linux package information ... 2020-05-13_14:58:01_BST [openHABian] Installing or upgrading to latest openHAB milestone release (testing)...
$ apt-key add /tmp/openhab-key.asc
OK
$ apt-get update
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Ign:3 https://openhab.jfrog.io/openhab/openhab-linuxpkg testing InRelease
Err:4 https://openhab.jfrog.io/openhab/openhab-linuxpkg testing Release
Unknown date format Bad header data [IP: 35.231.52.82 443]
Reading package lists... Done
E: The repository 'https://openhab.jfrog.io/openhab/openhab-linuxpkg testing Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
$ apt-get -y --allow-downgrades install openhab2=
Building dependency tree
E: Version '' for 'openhab2' was not found
FAILED (apt)
I have tried running this command based on other error reported but my result hasn’t changed.
wget -qO - 'https://bintray.com/user/downloadSubjectPublicKey?username=openhab' | sudo apt-key add -
What am I missing?
Thanks.
