- Platform information:
- Hardware: MacBook 2016
- OS: 10.14.5
- Java Runtime Environment:
java -version java version "10.0.2" 2018-07-17 Java(TM) SE Runtime Environment 18.3 (build 10.0.2+13) Java HotSpot(TM) 64-Bit Server VM 18.3 (build 10.0.2+13, mixed mode)
- openHAB version: latest GIT version
- Issue of the topic: Unable to create a new binding
- If logs where generated please post these here using code fences:
./create_openhab_binding_skeleton.sh DaikinAltherma "Karsten Becker" KarstenB
[INFO] Scanning for projects...
Downloading from archetype: https://openhab.jfrog.io/openhab/webapp/#/builds/openHAB-Core/org/openhab/openhab-super-pom/maven-metadata.xml
[WARNING] Checksum validation failed, expected <!-- but is f77ac75052362c2f198948c3b420d0c9da1064d3 from archetype for https://openhab.jfrog.io/openhab/webapp/#/builds/openHAB-Core/org/openhab/openhab-super-pom/maven-metadata.xml
[WARNING] Could not validate integrity of download from https://openhab.jfrog.io/openhab/webapp/#/builds/openHAB-Core/org/openhab/openhab-super-pom/maven-metadata.xml: Checksum validation failed, expected <!-- but is f77ac75052362c2f198948c3b420d0c9da1064d3
Downloaded from archetype: https://openhab.jfrog.io/openhab/webapp/#/builds/openHAB-Core/org/openhab/openhab-super-pom/maven-metadata.xml (2.2 kB at 1.8 kB/s)
[WARNING] The metadata /Users/karstenbecker/.m2/repository/org/openhab/openhab-super-pom/maven-metadata-archetype.xml is invalid: end tag name </head> must be the same as start tag <meta> from line 23 (position: TEXT seen ...<title></title>\n</head>... @32:8)
Downloading from archetype: https://openhab.jfrog.io/openhab/webapp/#/builds/openHAB-Core/org/openhab/openhab-super-pom/1.0.1/openhab-super-pom-1.0.1.pom
[WARNING] Checksum validation failed, expected <!-- but is f77ac75052362c2f198948c3b420d0c9da1064d3 from archetype for https://openhab.jfrog.io/openhab/webapp/#/builds/openHAB-Core/org/openhab/openhab-super-pom/1.0.1/openhab-super-pom-1.0.1.pom
[WARNING] Could not validate integrity of download from https://openhab.jfrog.io/openhab/webapp/#/builds/openHAB-Core/org/openhab/openhab-super-pom/1.0.1/openhab-super-pom-1.0.1.pom: Checksum validation failed, expected <!-- but is f77ac75052362c2f198948c3b420d0c9da1064d3
It appears to me that the jfrog hot link does not work anymore.
Karsten
