The plot thickens.
I thought I’d try setting the association with a different software. So I ran open-zwave-control-panel
When I try to set the association group, I get:
2017-10-18 10:54:45.154 Info, Node069, Association::Set - Adding node 15 to group 1 of node 69
2017-10-18 10:54:45.154 Detail, Node069, Queuing (Send) AssociationCmd_Set (Node=69): 0x01, 0x0b, 0x00, 0x13, 0x45, 0x04, 0x85, 0x01, 0x01, 0x0f, 0x25, 0xa3, 0xaa
2017-10-18 10:54:45.154 Info, Node069, Get Associations for group 1 of node 69
2017-10-18 10:54:45.154 Detail, Node069, Queuing (Send) AssociationCmd_Get (Node=69): 0x01, 0x0a, 0x00, 0x13, 0x45, 0x03, 0x85, 0x02, 0x01, 0x25, 0xa4, 0xa7
post: key=groups data= size=0
2017-10-18 10:54:45.154 Info, Node069, Sending (Send) message (Callback ID=0xa3, Expected Reply=0x13) - AssociationCmd_Set (Node=69): 0x01, 0x0b, 0x00, 0x13, 0x45, 0x04, 0x85, 0x01, 0x01, 0x0f, 0x25, 0xa3, 0xaa
2017-10-18 10:54:45.162 Detail, Node069, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-10-18 10:54:45.162 Detail, Node069, ZW_SEND_DATA delivered to Z-Wave stack
2017-10-18 10:54:45.212 Detail, Node069, Received: 0x01, 0x07, 0x00, 0x13, 0xa3, 0x00, 0x00, 0x06, 0x4e
2017-10-18 10:54:45.212 Detail, Node069, ZW_SEND_DATA Request with callback ID 0xa3 received (expected 0xa3)
2017-10-18 10:54:45.212 Info, Node069, Request RTT 57 Average Request RTT 58
2017-10-18 10:54:45.212 Detail, Expected callbackId was received
2017-10-18 10:54:45.212 Detail, Expected reply was received
2017-10-18 10:54:45.212 Detail, Message transaction complete
2017-10-18 10:54:45.212 Detail, Node069, Removing current message
2017-10-18 10:54:45.212 Info, Node069, Sending (Send) message (Callback ID=0xa4, Expected Reply=0x04) - AssociationCmd_Get (Node=69): 0x01, 0x0a, 0x00, 0x13, 0x45, 0x03, 0x85, 0x02, 0x01, 0x25, 0xa4, 0xa7
2017-10-18 10:54:45.220 Detail, Node069, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-10-18 10:54:45.220 Detail, Node069, ZW_SEND_DATA delivered to Z-Wave stack
2017-10-18 10:54:45.273 Detail, Node069, Received: 0x01, 0x07, 0x00, 0x13, 0xa4, 0x00, 0x00, 0x06, 0x49
2017-10-18 10:54:45.273 Detail, Node069, ZW_SEND_DATA Request with callback ID 0xa4 received (expected 0xa4)
2017-10-18 10:54:45.273 Info, Node069, Request RTT 60 Average Request RTT 59
2017-10-18 10:54:45.273 Detail, Expected callbackId was received
2017-10-18 10:54:55.215 Error, Node069, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-10-18 10:54:55.215 Detail, Node069, Removing current message
2017-10-18 10:54:55.215 Detail, Node069, Notification: Notification - TimeOut
2017-10-18 10:54:55.215 Info, Notification: Notification home e551caa9 node 69 Timeout
So it does seem that the issue is on the device side, not on the openHAB side. Either it is defective, or there’s another setting that needs to be changed before its association can be changed. The only thing that is a bit funny now is that when trying to change the association, openHAB gives an HTTP error immediately, not after a timeout like open-zwave. But that could be due to earlier timeout message when openHAB start that maybe marks the node as not responding?
