Error while importing openHab project in Eclipse
I am working on Openhab bindings as a part of my project work. When I try to import the openHab add ons project in the Eclipse, I get the following error. I am completely new to this and have no idea what’s wrong here.
Any help will be much appreciated!
Thanks.
biz.aQute.bnd:bnd-maven-plugin:pom:6.0.0 failed to transfer from https://repo.maven.apache.org/maven2 during a previous attempt. This failure was cached in the local repository and resolution is not reattempted until the update interval of central has elapsed or updates are forced. Original error: Could not transfer artifact biz.aQute.bnd:bnd-maven-plugin:pom:6.0.0 from/to central (https://repo.maven.apache.org/maven2): repo.maven.apache.org
Failed to read artifact descriptor for org.openhab.core.bom:org.openhab.core.bom.openhab-core:pom:3.2.0-SNAPSHOT
org.eclipse.aether.resolution.ArtifactDescriptorException: Failed to read artifact descriptor for org.openhab.core.bom:org.openhab.core.bom.openhab-core:pom:3.2.0-SNAPSHOT
	at org.apache.maven.repository.internal.DefaultArtifactDescriptorReader.loadPom(DefaultArtifactDescriptorReader.java:255)
	at org.apache.maven.repository.internal.DefaultArtifactDescriptorReader.readArtifactDescriptor(DefaultArtifactDescriptorReader.java:171)
	at org.eclipse.aether.internal.impl.collect.DefaultDependencyCollector.resolveCachedArtifactDescriptor(DefaultDependencyCollector.java:538)
	at org.eclipse.aether.internal.impl.collect.DefaultDependencyCollector.getArtifactDescriptorResult(DefaultDependencyCollector.java:523)
	at org.eclipse.aether.internal.impl.collect.DefaultDependencyCollector.processDependency(DefaultDependencyCollector.java:410)
	at org.eclipse.aether.internal.impl.collect.DefaultDependencyCollector.processDependency(DefaultDependencyCollector.java:362)
	at org.eclipse.aether.internal.impl.collect.DefaultDependencyCollector.process(DefaultDependencyCollector.java:349)
	at org.eclipse.aether.internal.impl.collect.DefaultDependencyCollector.collectDependencies(DefaultDependencyCollector.java:254)
	at org.eclipse.aether.internal.impl.DefaultRepositorySystem.collectDependencies(DefaultRepositorySystem.java:284)
	at org.apache.maven.project.DefaultProjectDependenciesResolver.resolve(DefaultProjectDependenciesResolver.java:169)
	at org.apache.maven.project.DefaultProjectBuilder.resolveDependencies(DefaultProjectBuilder.java:227)
	at org.apache.maven.project.DefaultProjectBuilder.build(DefaultProjectBuilder.java:200)
	at org.apache.maven.project.DefaultProjectBuilder.build(DefaultProjectBuilder.java:124)
	at org.eclipse.m2e.core.internal.embedder.MavenImpl.readMavenProject(MavenImpl.java:630)
	at org.eclipse.m2e.core.internal.project.registry.DefaultMavenDependencyResolver.resolveProjectDependencies(DefaultMavenDependencyResolver.java:65)
	at org.eclipse.m2e.core.internal.project.registry.ProjectRegistryManager.refreshPhase2(ProjectRegistryManager.java:550)
	at org.eclipse.m2e.core.internal.project.registry.ProjectRegistryManager.lambda$3(ProjectRegistryManager.java:514)
	at org.eclipse.m2e.core.internal.embedder.MavenExecutionContext.executeBare(MavenExecutionContext.java:179)
	at org.eclipse.m2e.core.internal.embedder.MavenExecutionContext.execute(MavenExecutionContext.java:153)
	at org.eclipse.m2e.core.internal.project.registry.ProjectRegistryManager.refresh(ProjectRegistryManager.java:512)
	at org.eclipse.m2e.core.internal.project.registry.ProjectRegistryManager.refresh(ProjectRegistryManager.java:364)
	at org.eclipse.m2e.core.internal.project.registry.ProjectRegistryManager.refresh(ProjectRegistryManager.java:315)
	at org.eclipse.m2e.core.internal.builder.MavenBuilder$BuildMethod.getProjectFacade(MavenBuilder.java:151)
	at org.eclipse.m2e.core.internal.builder.MavenBuilder$BuildMethod.lambda$0(MavenBuilder.java:89)
	at org.eclipse.m2e.core.internal.embedder.MavenExecutionContext.execute(MavenExecutionContext.java:101)
	at org.eclipse.m2e.core.internal.builder.MavenBuilder$BuildMethod.execute(MavenBuilder.java:88)
	at org.eclipse.m2e.core.internal.builder.MavenBuilder.build(MavenBuilder.java:197)
	at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:853)
	at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:232)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:281)
	at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:334)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:337)
	at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:389)
	at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:410)
	at org.eclipse.core.internal.resources.Workspace.buildInternal(Workspace.java:516)
	at org.eclipse.core.internal.resources.Workspace.build(Workspace.java:406)
	at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$6.run(SetupTaskPerformer.java:3896)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Caused by: org.eclipse.aether.resolution.ArtifactResolutionException: org.openhab.core.bom:org.openhab.core.bom.openhab-core:pom:3.2.0-SNAPSHOT failed to transfer from https://openhab.jfrog.io/openhab/libs-snapshot during a previous attempt. This failure was cached in the local repository and resolution is not reattempted until the update interval of openhab-artifactory-snapshot has elapsed or updates are forced. Original error: Could not transfer artifact org.openhab.core.bom:org.openhab.core.bom.openhab-core:pom:3.2.0-SNAPSHOT from/to openhab-artifactory-snapshot (https://openhab.jfrog.io/openhab/libs-snapshot): openhab.jfrog.io
	at org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:424)
	at org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifacts(DefaultArtifactResolver.java:229)
	at org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifact(DefaultArtifactResolver.java:207)
	at org.apache.maven.repository.internal.DefaultArtifactDescriptorReader.loadPom(DefaultArtifactDescriptorReader.java:240)
	... 41 more
Caused by: org.eclipse.aether.transfer.ArtifactTransferException: org.openhab.core.bom:org.openhab.core.bom.openhab-core:pom:3.2.0-SNAPSHOT failed to transfer from https://openhab.jfrog.io/openhab/libs-snapshot during a previous attempt. This failure was cached in the local repository and resolution is not reattempted until the update interval of openhab-artifactory-snapshot has elapsed or updates are forced. Original error: Could not transfer artifact org.openhab.core.bom:org.openhab.core.bom.openhab-core:pom:3.2.0-SNAPSHOT from/to openhab-artifactory-snapshot (https://openhab.jfrog.io/openhab/libs-snapshot): openhab.jfrog.io
	at org.eclipse.aether.internal.impl.DefaultUpdateCheckManager.newException(DefaultUpdateCheckManager.java:225)
	at org.eclipse.aether.internal.impl.DefaultUpdateCheckManager.checkArtifact(DefaultUpdateCheckManager.java:189)
	at org.eclipse.aether.internal.impl.DefaultArtifactResolver.gatherDownloads(DefaultArtifactResolver.java:573)
	at org.eclipse.aether.internal.impl.DefaultArtifactResolver.performDownloads(DefaultArtifactResolver.java:483)
	at org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:401)
	... 44 more
Failed to read artifact descriptor for org.openhab.core.bom:org.openhab.core.bom.runtime:pom:3.2.0-SNAPSHOT
org.eclipse.aether.resolution.ArtifactDescriptorException: Failed to read artifact descriptor for org.openhab.core.bom:org.openhab.core.bom.runtime:pom:3.2.0-SNAPSHOT
Caused by: org.eclipse.aether.resolution.ArtifactResolutionException: org.openhab.core.bom:org.openhab.core.bom.runtime:pom:3.2.0-SNAPSHOT failed to transfer from https://openhab.jfrog.io/openhab/libs-snapshot during a previous attempt. This failure was cached in the local repository and resolution is not reattempted until the update interval of openhab-artifactory-snapshot has elapsed or updates are forced. Original error: Could not transfer artifact org.openhab.core.bom:org.openhab.core.bom.runtime:pom:3.2.0-SNAPSHOT from/to openhab-artifactory-snapshot (https://openhab.jfrog.io/openhab/libs-snapshot): openhab.jfrog.io
	... 41 more
Caused by: org.eclipse.aether.transfer.ArtifactTransferException: org.openhab.core.bom:org.openhab.core.bom.runtime:pom:3.2.0-SNAPSHOT failed to transfer from https://openhab.jfrog.io/openhab/libs-snapshot during a previous attempt. This failure was cached in the local repository and resolution is not reattempted until the update interval of openhab-artifactory-snapshot has elapsed or updates are forced. Original error: Could not transfer artifact org.openhab.core.bom:org.openhab.core.bom.runtime:pom:3.2.0-SNAPSHOT from/to openhab-artifactory-snapshot (https://openhab.jfrog.io/openhab/libs-snapshot): openhab.jfrog.io
	... 44 more
Failed to read artifact descriptor for org.openhab.ui.bom:org.openhab.ui.bom.openhab-ui:pom:3.2.0-SNAPSHOT
org.eclipse.aether.resolution.ArtifactDescriptorException: Failed to read artifact descriptor for org.openhab.ui.bom:org.openhab.ui.bom.openhab-ui:pom:3.2.0-SNAPSHOT
Caused by: org.eclipse.aether.resolution.ArtifactResolutionException: org.openhab.ui.bom:org.openhab.ui.bom.openhab-ui:pom:3.2.0-SNAPSHOT failed to transfer from https://openhab.jfrog.io/openhab/libs-snapshot during a previous attempt. This failure was cached in the local repository and resolution is not reattempted until the update interval of openhab-artifactory-snapshot has elapsed or updates are forced. Original error: Could not transfer artifact org.openhab.ui.bom:org.openhab.ui.bom.openhab-ui:pom:3.2.0-SNAPSHOT from/to openhab-artifactory-snapshot (https://openhab.jfrog.io/openhab/libs-snapshot): openhab.jfrog.io
	... 41 more
Caused by: org.eclipse.aether.transfer.ArtifactTransferException: org.openhab.ui.bom:org.openhab.ui.bom.openhab-ui:pom:3.2.0-SNAPSHOT failed to transfer from https://openhab.jfrog.io/openhab/libs-snapshot during a previous attempt. This failure was cached in the local repository and resolution is not reattempted until the update interval of openhab-artifactory-snapshot has elapsed or updates are forced. Original error: Could not transfer artifact org.openhab.ui.bom:org.openhab.ui.bom.openhab-ui:pom:3.2.0-SNAPSHOT from/to openhab-artifactory-snapshot (https://openhab.jfrog.io/openhab/libs-snapshot): openhab.jfrog.io
	... 44 more
Missing artifact org.openhab.core.bom:org.openhab.core.bom.openhab-core:pom:3.2.0-SNAPSHOT
Missing artifact org.openhab.core.bom:org.openhab.core.bom.runtime:pom:3.2.0-SNAPSHOT
Missing artifact org.openhab.ui.bom:org.openhab.ui.bom.openhab-ui:pom:3.2.0-SNAPSHOT
Moved to developement/IDE category
What exactly did you import? I would suggest just to import the binding you want to have a look at by using this option within Eclipse:
and the browse to the pom of the binding you like to import.
I want to run the add ons as well as create a binding. I followed the steps mentioned in https://www.openhab.org/docs/developer/ide/eclipse.html and thus got the error.
I followed your step as well.
Also, I need the skeleton binding script to start with the binding development.
