Oh, I didn’t think of that - good thing I asked, thanks
You can check with wget if your DNS/network config has issues by downloading an add-on from the openHAB online repo:
E.g. inside the container:
wget -O /tmp/org.openhab.ui.paper-2.5.5.jar https://openhab.jfrog.io/openhab/libs-release/org/openhab/ui/bundles/org.openhab.ui.paper/2.5.5/org.openhab.ui.paper-2.5.5.jar
Or on the host
docker exec openhab wget -O /tmp/org.openhab.ui.paper-2.5.5.jar https://openhab.jfrog.io/openhab/libs-release/org/openhab/ui/bundles/org.openhab.ui.paper/2.5.5/org.openhab.ui.paper-2.5.5.jar
That is more realistic than just pinging Google.
Thanks for the commands. Unfortunately looks like the network configuration is not the problem:
root@aec6a27e1667:/tmp# wget -O /tmp/org.openhab.ui.paper-2.5.5.jar https://openhab.jfrog.io/openhab/libs-release/org/openhab/ui/bundles/org.openhab.ui.paper/2.5.5/org.openhab.ui.paper-2.5.5.jar
--2020-05-19 13:59:13-- https://openhab.jfrog.io/openhab/libs-release/org/openhab/ui/bundles/org.openhab.ui.paper/2.5.5/org.openhab.ui.paper-2.5.5.jar
Resolving openhab.jfrog.io (openhab.jfrog.io)... 35.231.52.82
Connecting to openhab.jfrog.io (openhab.jfrog.io)|35.231.52.82|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 935477 (914K) [application/java-archive]
Saving to: ‘/tmp/org.openhab.ui.paper-2.5.5.jar’
/tmp/org.openhab.ui.paper-2.5.5.jar 100%[=================================================================================================================================================>] 913.55K 1.10MB/s in 0.8s
2020-05-19 13:59:14 (1.10 MB/s) - ‘/tmp/org.openhab.ui.paper-2.5.5.jar’ saved [935477/935477]
This was run from inside the OpenHAB container.
Good to know. My testing was just for very basic setup & getting it running.
At least network_mod: host
is the easy way.
It seams it can work without that as well, see:
But the experience I had in my specific setup was that I needed network_mode: host
otherwise Phillips Hue Bridge would not work, I believe it had something to do with arping
or something in the locale network.
