Hello, can anyone help me, I do not know why it does not work
it is a water measurement with a sensor on the water measuring unit and that has to run a counter
rule "Water Meting"
Item Input7_1 changed to OPEN or
Item EWA_test_teller changed to ON
var Number LVW1_Water_TotalPulses = W1_Water_TotalPulses.state as Number
if (W1_Water_TotalPulses = null){
sendCommand(W1_Water_TotalPulses, 0)
else{
LVW1_Water_TotalPulses = LVW1_Water_TotalPulses + 0.1
sendCommand(W1_Water_TotalPulses, LVW1_Water_TotalPulses)
Couple of issues
When testing for null you need to use === But I think you want to check that the state in NULL
use the method postUpdate of sendCommand when dealing with a known item: W1_Water_TotalPulses.postUpdate(0) instead of postUpdate(W1_Water_TotalPulses, 0)
Be consistent with our indenting use spaces OR tabs but not both
I recommend spaces it’s more consistent with other editors
There was no item definition for W1_Water_TotalPulses but I assumed it’s a number item with no binding.
rule "Water Meting"
if (W1_Water_TotalPulses.state == NULL) {
} else {
W1_Water_TotalPulses.postUpdate(LVW1_Water_TotalPulses)
rule "Water Meting"
if (W1_Water_TotalPulses.state == NULL) {W1_Water_TotalPulses.postUpdate(0)}
else {W1_Water_TotalPulses.postUpdate((W1_Water_TotalPulses.state as DecimalType) + 0.1)}
