[ERROR] [xt.xbase.jvmmodel.JvmModelAssociator]
I have created a rule with hadmin, but get the following code:
16:05:51.927 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model '(1)_lichtautoan.rules'
16:05:51.985 [ERROR] [xt.xbase.jvmmodel.JvmModelAssociator] - Error calling inferrer
java.lang.NullPointerException
	at org.eclipse.smarthome.model.rule.jvmmodel.RulesJvmModelInferrer$1$1$1.apply(RulesJvmModelInferrer.java:133)[125:org.eclipse.smarthome.model.rule:0.9.0.201612091054]
	at org.eclipse.smarthome.model.rule.jvmmodel.RulesJvmModelInferrer$1$1$1.apply(RulesJvmModelInferrer.java:1)[125:org.eclipse.smarthome.model.rule:0.9.0.201612091054]
	at org.eclipse.xtext.xbase.lib.ObjectExtensions.operator_doubleArrow(ObjectExtensions.java:139)[144:org.eclipse.xtext.xbase.lib:2.9.2]
	at org.eclipse.smarthome.model.rule.jvmmodel.RulesJvmModelInferrer$1$1.apply(RulesJvmModelInferrer.java:141)[125:org.eclipse.smarthome.model.rule:0.9.0.201612091054]
	at org.eclipse.smarthome.model.rule.jvmmodel.RulesJvmModelInferrer$1$1.apply(RulesJvmModelInferrer.java:1)[125:org.eclipse.smarthome.model.rule:0.9.0.201612091054]
	at org.eclipse.xtext.xbase.lib.internal.FunctionDelegate.apply(FunctionDelegate.java:42)[144:org.eclipse.xtext.xbase.lib:2.9.2]
	at com.google.common.collect.Lists$TransformingRandomAccessList$1.transform(Lists.java:617)[13:com.google.guava:18.0.0]
	at com.google.common.collect.TransformedIterator.next(TransformedIterator.java:48)[13:com.google.guava:18.0.0]
	at org.eclipse.xtext.xbase.jvmmodel.JvmTypesBuilder.operator_add(JvmTypesBuilder.java:133)[143:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
	at org.eclipse.smarthome.model.rule.jvmmodel.RulesJvmModelInferrer$1.apply(RulesJvmModelInferrer.java:145)[125:org.eclipse.smarthome.model.rule:0.9.0.201612091054]
	at org.eclipse.smarthome.model.rule.jvmmodel.RulesJvmModelInferrer$1.apply(RulesJvmModelInferrer.java:1)[125:org.eclipse.smarthome.model.rule:0.9.0.201612091054]
	at org.eclipse.xtext.xbase.jvmmodel.JvmModelAssociator$1.run(JvmModelAssociator.java:397)[143:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
	at org.eclipse.xtext.xbase.jvmmodel.JvmModelAssociator.installDerivedState(JvmModelAssociator.java:407)[143:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
	at org.eclipse.xtext.resource.DerivedStateAwareResource.installDerivedState(DerivedStateAwareResource.java:242)[139:org.eclipse.xtext:2.9.2]
	at org.eclipse.xtext.xbase.resource.BatchLinkableResource.getContents(BatchLinkableResource.java:148)[143:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
	at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.getModel(ModelRepositoryImpl.java:61)[120:org.eclipse.smarthome.model.core:0.9.0.201612091054]
	at org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl.modelChanged(RuleEngineImpl.java:243)[126:org.eclipse.smarthome.model.rule.runtime:0.9.0.201612091054]
	at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:207)[120:org.eclipse.smarthome.model.core:0.9.0.201612091054]
	at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:120)[120:org.eclipse.smarthome.model.core:0.9.0.201612091054]
	at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:270)[120:org.eclipse.smarthome.model.core:0.9.0.201612091054]
	at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.access$1(FolderObserver.java:264)[120:org.eclipse.smarthome.model.core:0.9.0.201612091054]
	at org.eclipse.smarthome.model.core.internal.folder.FolderObserver$WatchQueueReader.processWatchEvent(FolderObserver.java:145)[120:org.eclipse.smarthome.model.core:0.9.0.201612091054]
	at org.eclipse.smarthome.core.service.AbstractWatchQueueReader.run(AbstractWatchQueueReader.java:122)[96:org.eclipse.smarthome.core:0.9.0.201612091054]
	at java.lang.Thread.run(Thread.java:745)[:1.8.0_65]
16:05:51.996 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model '(1)_lichtautoan.rules'
16:05:52.042 [ERROR] [xt.xbase.jvmmodel.JvmModelAssociator] - Error calling inferrer
My rule looks like the following:
I’m seeing the same thing:
2017-01-07 11:51:45.716 [ERROR] [xt.xbase.jvmmodel.JvmModelAssociator] - Error calling inferrer
java.lang.IllegalStateException: ScriptServiceUtil not initialized yet!
        at org.eclipse.smarthome.model.script.ScriptServiceUtil.getInstance(ScriptServiceUtil.java:85)
        at org.eclipse.smarthome.model.script.ScriptServiceUtil.getItemRegistry(ScriptServiceUtil.java:91)
        at org.eclipse.smarthome.model.script.internal.engine.ServiceTrackerItemRegistryProvider.get(ServiceTrackerItemRegistryProvider.java:29)
        at org.eclipse.smarthome.model.script.internal.engine.ServiceTrackerItemRegistryProvider.get(ServiceTrackerItemRegistryProvider.java:1)
        at org.eclipse.smarthome.model.rule.jvmmodel.RulesJvmModelInferrer$1.apply(RulesJvmModelInferrer.java:180)
        at org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl.activate(RuleEngineImpl.java:108)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0]
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0]
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0]
        at java.lang.reflect.Method.invoke(Method.java:483)[:1.8.0]
(I did not change any rules to make this appear.)
What was the solution to this?
my rule was wrong… used the wrong blocks… it’s working now
What do you mean with “used the wrong blocks”? I am facing the problem after every new snapshot install that the log comes up with hundreds of error messages like this one.
So if you could give a hint where to look for the problem, I would appreciate :slight_smile:
thanks
br
