I’m using OH3.1 Build 2276
Sometimes I’m getting this Error in my log File:
2021-03-23 21:06:42.200 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'EG_Kueche_Therm1_Isttemp' changed from 23.20 to 23.10
2021-03-23 21:07:01.591 [ERROR] [ypes.access.impl.AbstractClassMirror] - resource is empty: java:/Objects/org.openhab.core.model.script.actions.Semantics
java.lang.IllegalStateException: null
at org.eclipse.xtext.common.types.access.impl.AbstractClassMirror.getEObject(AbstractClassMirror.java:95) [bundleFile:?]
at org.eclipse.xtext.common.types.access.TypeResource.getEObject(TypeResource.java:95) [bundleFile:?]
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:223) [bundleFile:?]
at org.eclipse.xtext.common.types.access.impl.IndexedJvmTypeAccess.getIndexedJvmType(IndexedJvmTypeAccess.java:80) [bundleFile:?]
at org.eclipse.xtext.common.types.access.impl.IndexedJvmTypeAccess.getIndexedJvmType(IndexedJvmTypeAccess.java:70) [bundleFile:?]
at org.eclipse.xtext.common.types.access.reflect.ReflectionTypeProvider.findTypeByClass(ReflectionTypeProvider.java:146) [bundleFile:?]
at org.eclipse.xtext.common.types.access.reflect.ReflectionTypeProvider.findTypeByName(ReflectionTypeProvider.java:88) [bundleFile:?]
at org.eclipse.xtext.common.types.util.TypeReferences.findDeclaredType(TypeReferences.java:256) [bundleFile:?]
at org.eclipse.xtext.common.types.util.TypeReferences.findDeclaredType(TypeReferences.java:233) [bundleFile:?]
at org.eclipse.xtext.xbase.scoping.batch.ImplicitlyImportedFeatures.getTypes(ImplicitlyImportedFeatures.java:82) [bundleFile:?]
at org.eclipse.xtext.xbase.scoping.batch.ImplicitlyImportedFeatures.getExtensionClasses(ImplicitlyImportedFeatures.java:76) [bundleFile:?]
at org.eclipse.xtext.xbase.scoping.batch.XbaseBatchScopeProvider.newSession(XbaseBatchScopeProvider.java:121) [bundleFile:?]
at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.resolve(DefaultReentrantTypeResolver.java:164) [bundleFile:?]
at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.reentrantResolve(DefaultReentrantTypeResolver.java:140) [bundleFile:?]
at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$LazyResolvedTypes.resolveTypes(CachingBatchTypeResolver.java:81) [bundleFile:?]
at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$2.process(CachingBatchTypeResolver.java:58) [bundleFile:?]
at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$2.process(CachingBatchTypeResolver.java:54) [bundleFile:?]
at org.eclipse.xtext.util.concurrent.IUnitOfWork$Void.exec(IUnitOfWork.java:38) [bundleFile:?]
at org.eclipse.xtext.util.OnChangeEvictingCache.execWithoutCacheClear(OnChangeEvictingCache.java:135) [bundleFile:?]
at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver.doResolveTypes(CachingBatchTypeResolver.java:54) [bundleFile:?]
at org.eclipse.xtext.xbase.typesystem.internal.AbstractBatchTypeResolver.resolveTypes(AbstractBatchTypeResolver.java:70) [bundleFile:?]
at org.eclipse.xtext.xbase.resource.BatchLinkingService.resolveBatched(BatchLinkingService.java:72) [bundleFile:?]
at org.eclipse.xtext.xbase.resource.BatchLinkableResource.resolveLazyCrossReferences(BatchLinkableResource.java:166) [bundleFile:?]
at org.eclipse.xtext.EcoreUtil2.resolveLazyCrossReferences(EcoreUtil2.java:505) [bundleFile:?]
at org.eclipse.xtext.build.IncrementalBuilder$InternalStatefulIncrementalBuilder.lambda$launch$2(IncrementalBuilder.java:266) [bundleFile:?]
at com.google.common.collect.Iterators$6.transform(Iterators.java:783) [bundleFile:?]
at com.google.common.collect.TransformedIterator.next(TransformedIterator.java:47) [bundleFile:?]
at com.google.common.collect.FluentIterable.copyInto(FluentIterable.java:791) [bundleFile:?]
at org.eclipse.xtext.build.ClusteringStorageAwareResourceLoader.executeClustered(ClusteringStorageAwareResourceLoader.java:69) [bundleFile:?]
at org.eclipse.xtext.build.BuildContext.executeClustered(BuildContext.java:55) [bundleFile:?]
at org.eclipse.xtext.build.IncrementalBuilder$InternalStatefulIncrementalBuilder.launch(IncrementalBuilder.java:259) [bundleFile:?]
at org.eclipse.xtext.build.IncrementalBuilder.build(IncrementalBuilder.java:404) [bundleFile:?]
at org.eclipse.xtext.build.IncrementalBuilder.build(IncrementalBuilder.java:386) [bundleFile:?]
at org.eclipse.xtext.ide.server.ProjectManager.doBuild(ProjectManager.java:106) [bundleFile:?]
at org.eclipse.xtext.ide.server.ProjectManager.doInitialBuild(ProjectManager.java:97) [bundleFile:?]
at org.eclipse.xtext.ide.server.BuildManager.doInitialBuild(BuildManager.java:164) [bundleFile:?]
at org.eclipse.xtext.ide.server.WorkspaceManager.refreshWorkspaceConfig(WorkspaceManager.java:233) [bundleFile:?]
at org.eclipse.xtext.ide.server.WorkspaceManager.initialize(WorkspaceManager.java:170) [bundleFile:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$initialize$0(LanguageServerImpl.java:225) [bundleFile:?]
at org.eclipse.xtext.ide.server.concurrent.WriteRequest.run(WriteRequest.java:50) [bundleFile:?]
I’m getting this error in my first post once a day. And I get this Warn:
[WARN ] [ternal.handler.HomematicThingHandler] - Channel not found for datapoint '000A5BE99F4B3E:1#ERROR_DEGRADED_CHAMBER'
In the UI is no channel and I have no Item. In the discription of the HMIP-SWSD ist no channel declared. Don’t kow what this is and where it is comming from. Is this warning possibly the cause for my first post
2021-03-31 22:02:53.866 [ERROR] [ypes.access.impl.AbstractClassMirror] - resource is empty: java:/Objects/org.openhab.core.model.script.actions.Semantics
But in my case it appears when I start Visual Studio Code.
