I’ll have to doublecheck some groups.
However these errors don’t seem to be present in my 2.4 build.
As OH matures, things that used to be problems but simply ignored are now reported as errors.
That could be it, I’ll do some spring cleaning then, cheers!
I’ve stopped trying to restore colors on startup, can’t find any misconfigured groups, but it’ll probably be easier to determine when I get 2.5.0.1 running.
I’m gonna give it a shot tomorrow I think and see what happens.
You have to check EVERY first line in ALL .config files in ( /userdata/config/ and subfolders), if there are any of these entries:
especially: …/org/openhab/ habpanel.config
WRONG:
:org.apache.felix.configadmin.revision:=“1.0”
or
:org.apache.felix.configadmin.revision:=“2.0”
or
:org.apache.felix.configadmin.revision:=“3.0”
…and so on…
CORRECT:
:org.apache.felix.configadmin.revision:=L"1"
or
:org.apache.felix.configadmin.revision:=L"2"
or
:org.apache.felix.configadmin.revision:=L"3"
…and so on…
Please also check: …/org/openhab/ addons.config
Finally i got a few hours to fiddle with this again ![]()
Thank you for your reply.
You were right, habPanel had the described issue, I changed it to
Additional I had a few with “felix.cm.newConfiguration=B"true” "
I assume that is normal and Openhab just didn’t get to them yet?
I’m still getting these errors unfortunately, I’m fairly sure I checked all my .cfg and .config files, but I’ll run through them again for good measure.
2019-12-22 09:51:26.905 [ERROR] [org.apache.felix.scr ] - bundle org.apache.felix.scr:2.1.16 (43)Error while loading components of bundle org.openhab.core.config.discovery:2.5.0 (139)
java.lang.ClassCastException: java.lang.String cannot be cast to java.lang.Long
at org.apache.felix.cm.impl.ConfigurationImpl.configure(ConfigurationImpl.java:659) ~[?:?]
at org.apache.felix.cm.impl.ConfigurationImpl.configureFromPersistence(ConfigurationImpl.java:619) ~[?:?]
at org.apache.felix.cm.impl.ConfigurationImpl.<init>(ConfigurationImpl.java:194) ~[?:?]
at org.apache.felix.cm.impl.ConfigurationManager.listConfigurations(ConfigurationManager.java:552) ~[?:?]
at org.apache.felix.cm.impl.ConfigurationAdminImpl.listConfigurations(ConfigurationAdminImpl.java:190) ~[?:?]
at org.apache.felix.scr.impl.manager.RegionConfigurationSupport.findConfigurations(RegionConfigurationSupport.java:655) ~[bundleFile:?]
at org.apache.felix.scr.impl.manager.RegionConfigurationSupport.findSingletonConfiguration(RegionConfigurationSupport.java:554) ~[bundleFile:?]
at org.apache.felix.scr.impl.manager.RegionConfigurationSupport.configureComponentHolder(RegionConfigurationSupport.java:199) ~[bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator.setRegionConfigurationSupport(BundleComponentActivator.java:763) ~[bundleFile:?]
at org.apache.felix.scr.impl.helper.ConfigAdminTracker$1.addingService(ConfigAdminTracker.java:69) ~[?:?]
at org.apache.felix.scr.impl.helper.ConfigAdminTracker$1.addingService(ConfigAdminTracker.java:41) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) ~[osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) ~[osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183) ~[osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:318) ~[osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:261) ~[osgi.core-6.0.0.jar:?]
at org.apache.felix.scr.impl.helper.ConfigAdminTracker.<init>(ConfigAdminTracker.java:86) ~[bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator.<init>(BundleComponentActivator.java:275) ~[bundleFile:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:380) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) [bundleFile:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:264) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [bundleFile:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [osgi.core-6.0.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [org.eclipse.osgi-3.12.100.jar:?]
2019-12-22 09:51:33.744 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Lights.items'
2019-12-22 09:51:33.838 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Switchs.items'
2019-12-22 09:51:33.892 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Presence.items'
2019-12-22 09:51:33.949 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Entrances.items'
2019-12-22 09:51:33.964 [WARN ] [arthome.core.items.dto.ItemDTOMapper] - State 'ON' is not valid for a group item with base type 'Contact'
2019-12-22 09:51:33.969 [ERROR] [e.internal.items.GroupFunctionHelper] - Group function 'OR' requires two arguments. Using Equality instead.
2019-12-22 09:51:33.977 [WARN ] [arthome.core.items.dto.ItemDTOMapper] - State 'ON' is not valid for a group item with base type 'Contact'
2019-12-22 09:51:33.980 [ERROR] [e.internal.items.GroupFunctionHelper] - Group function 'OR' requires two arguments. Using Equality instead.
2019-12-22 09:51:34.008 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Wol.items'
2019-12-22 09:51:34.609 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'influxdb.persist'
2019-12-22 09:51:35.650 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Wol.things'
2019-12-22 09:51:36.654 [ERROR] [org.apache.felix.scr ] - bundle org.apache.felix.scr:2.1.16 (43)Error while loading components of bundle org.openhab.core.thing:2.5.0 (185)
