Errors..Errors...and More Errors
Running OH ver 2.5.2
Windows Server 2012
I’m starting to see quite a bit of errors in the KARAF console…can someone help identify where these are happening so I can look to fix?
Squid
        at org.jupnp.util.io.IO.readBytes(IO.java:121)
        at org.jupnp.transport.impl.ServletUpnpStream.readRequestMessage(ServletUpnpStream.java:137)
        at org.jupnp.transport.impl.ServletUpnpStream.run(ServletUpnpStream.java:61)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
        at java.lang.Thread.run(Thread.java:748)
Caused by: java.util.concurrent.TimeoutException: Idle timeout expired: 30000/30000 ms
        at org.eclipse.jetty.io.IdleTimeout.checkIdleTimeout(IdleTimeout.java:171)
        at org.eclipse.jetty.io.IdleTimeout.idleCheck(IdleTimeout.java:113)
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
        at java.util.concurrent.FutureTask.run(FutureTask.java:266)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)
        ... 3 more
        Suppressed: java.lang.Throwable: HttpInput failure
                at org.eclipse.jetty.server.HttpInput.failed(HttpInput.java:822)
                at org.eclipse.jetty.server.HttpConnection$BlockingReadCallback.failed(HttpConnection.java:659)
                at org.eclipse.jetty.io.FillInterest.onFail(FillInterest.java:138)
                at org.eclipse.jetty.io.AbstractEndPoint.onIdleExpired(AbstractEndPoint.java:407)
                ... 9 more
org.eclipse.jetty.io.EofException: Early EOF
        at org.eclipse.jetty.server.HttpInput$3.getError(HttpInput.java:1133)
        at org.eclipse.jetty.server.HttpInput$3.noContent(HttpInput.java:1121)
        at org.eclipse.jetty.server.HttpInput.read(HttpInput.java:320)
        at java.io.InputStream.read(InputStream.java:101)
        at org.jupnp.util.io.IO.copyLarge(IO.java:980)
        at org.jupnp.util.io.IO.copy(IO.java:954)
        at org.jupnp.util.io.IO.toByteArray(IO.java:402)
java.io.IOException: java.util.concurrent.TimeoutException: Idle timeout expired: 30002/30000 ms
        at org.eclipse.jetty.server.HttpInput$ErrorState.noContent(HttpInput.java:1075)
Caused by: java.util.concurrent.TimeoutException: Idle timeout expired: 30002/30000 ms
        ... 3 more
                ... 9 more
        ... 3 more
                ... 9 more
java.io.IOException: java.util.concurrent.TimeoutException: Idle timeout expired: 30000/30000 ms
        ... 3 more
                ... 9 more
        ... 3 more
                ... 9 more
java.io.IOException: java.util.concurrent.TimeoutException: Idle timeout expired: 30001/30000 ms
Caused by: java.util.concurrent.TimeoutException: Idle timeout expired: 30001/30000 ms
        ... 3 more
                ... 9 more
