Hit ‘’ for a list of available commands
and ‘[cmd] --help’ for help on a specific command.
Hit ‘’ or type ‘system:shutdown’ or ‘logout’ to shutdown openHAB.
openhab> org.apache.karaf.features.internal.util.MultiException: Error:
Error downloading mvn:org.openhab.ui.bundles/org.openhab.ui.dashboard/2.5.0.M4
at org.apache.karaf.features.internal.download.impl.MavenDownloadManager$MavenDownloader.(MavenDownloadManager.java:91)
at org.apache.karaf.features.internal.download.impl.MavenDownloadManager.createDownloader(MavenDownloadManager.java:72)
at org.apache.karaf.features.internal.region.Subsystem.downloadBundles(Subsystem.java:457)
at org.apache.karaf.features.internal.region.Subsystem.downloadBundles(Subsystem.java:452)
at org.apache.karaf.features.internal.region.SubsystemResolver.resolve(SubsystemResolver.java:224)
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:393)
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1062)
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:998)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Suppressed: java.io.IOException: Error downloading mvn:org.openhab.ui.bundles/org.openhab.ui.dashboard/2.5.0.M4
at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:77)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)
… 3 more
Caused by: java.io.IOException: Error resolving artifact org.openhab.ui.bundles:org.openhab.ui.dashboard:jar:2.5.0.M4: [Could not transfer artifact org.openhab.ui.bundles:org.openhab.ui.dashboard:jar:2.5.0.M4 from/to openhab (https://openhab.jfrog.io/openhab/online-repo-milestone/2.5/): Failed to transfer file https://openhab.jfrog.io/openhab/online-repo-milestone/2.5/org/openhab/ui/bundles/org.openhab.ui.dashboard/2.5.0.M4/org.openhab.ui.dashboard-2.5.0.M4.jar with status code 503]
I’m having a similar issue. I was making some network changes that required an IP change of the computer. They were made, tested and everything worked well.
Then I performed system updates and upgrades as suggested by the OS…and everything went to Hades. Openhab will not run.
I installed the Openhab add ons, but that made no improvement.
I’m getting the error messages below; this is a fresh log entry following a reboot. I can see the machine on my network and can navigate to its Apache2 page. The services status suggest that Openhab is running, but it’s clearly not.
Suggestions?
2019-12-15 17:26:39.879 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot features
at org.apache.karaf.features.internal.download.impl.MavenDownloadManager$MavenDownloader.<init>(MavenDownloadManager.java:91) ~[?:?]
at org.apache.karaf.features.internal.download.impl.MavenDownloadManager.createDownloader(MavenDownloadManager.java:72) ~[?:?]
at org.apache.karaf.features.internal.region.Subsystem.downloadBundles(Subsystem.java:457) ~[?:?]
at org.apache.karaf.features.internal.region.Subsystem.downloadBundles(Subsystem.java:452) ~[?:?]
at org.apache.karaf.features.internal.region.SubsystemResolver.resolve(SubsystemResolver.java:224) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:393) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1062) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:998) ~[?:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_232]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_232]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_232]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_232]
at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:77) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_232]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) ~[?:1.8.0_232]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) ~[?:1.8.0_232]
Caused by: java.io.IOException: Error resolving artifact org.openhab.ui.bundles:org.openhab.ui.dashboard:jar:2.5.0: [Could not transfer artifact org.openhab.ui.bundles:org.openhab.ui.dashboard:jar:2.5.0 from/to openhab (https://api.bintray.com/maven/openhab/mvn/online-repo/2.5/): Not authorized]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.configureIOException(AetherBasedResolver.java:803) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:774) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:657) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:598) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:565) ~[?:?]
at org.apache.karaf.features.internal.download.impl.MavenDownloadTask.download(MavenDownloadTask.java:52) ~[?:?]
at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:60) ~[?:?]
... 7 more
Suppressed: shaded.org.eclipse.aether.transfer.ArtifactTransferException: Could not transfer artifact org.openhab.ui.bundles:org.openhab.ui.dashboard:jar:2.5.0 from/to openhab (https://api.bintray.com/maven/openhab/mvn/online-repo/2.5/): Not authorized
at shaded.org.eclipse.aether.connector.basic.ArtifactTransportListener.transferFailed(ArtifactTransportListener.java:52) ~[?:?]
at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$TaskRunner.run(BasicRepositoryConnector.java:368) ~[?:?]
at shaded.org.eclipse.aether.util.concurrency.RunnableErrorForwarder$1.run(RunnableErrorForwarder.java:75) ~[?:?]
at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$DirectExecutor.execute(BasicRepositoryConnector.java:642) ~[?:?]
at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector.get(BasicRepositoryConnector.java:262) ~[?:?]
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.performDownloads(DefaultArtifactResolver.java:489) ~[?:?]
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:390) ~[?:?]
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifacts(DefaultArtifactResolver.java:215) ~[?:?]
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifact(DefaultArtifactResolver.java:192) ~[?:?]
at shaded.org.eclipse.aether.internal.impl.DefaultRepositorySystem.resolveArtifact(DefaultRepositorySystem.java:247) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:767) ~[?:?]
Caused by: shaded.org.apache.maven.wagon.authorization.AuthorizationException: Not authorized
at shaded.org.apache.maven.wagon.shared.http.AbstractHttpClientWagon.fillInputData(AbstractHttpClientWagon.java:1123) ~[?:?]
at shaded.org.apache.maven.wagon.shared.http.AbstractHttpClientWagon.fillInputData(AbstractHttpClientWagon.java:1072) ~[?:?]
at shaded.org.apache.maven.wagon.StreamWagon.getInputStream(StreamWagon.java:126) ~[?:?]
at shaded.org.apache.maven.wagon.StreamWagon.getIfNewer(StreamWagon.java:88) ~[?:?]
at shaded.org.apache.maven.wagon.StreamWagon.get(StreamWagon.java:61) ~[?:?]
at shaded.org.eclipse.aether.transport.wagon.WagonTransporter$GetTaskRunner.run(WagonTransporter.java:567) ~[?:?]
at shaded.org.eclipse.aether.transport.wagon.WagonTransporter.execute(WagonTransporter.java:435) ~[?:?]
at shaded.org.eclipse.aether.transport.wagon.WagonTransporter.get(WagonTransporter.java:412) ~[?:?]
at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$GetTaskRunner.runTask(BasicRepositoryConnector.java:456) ~[?:?]
at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$TaskRunner.run(BasicRepositoryConnector.java:363) ~[?:?]
... 21 more
Caused by: shaded.org.eclipse.aether.resolution.ArtifactResolutionException: Error resolving artifact org.openhab.ui.bundles:org.openhab.ui.dashboard:jar:2.5.0
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:413) ~[?:?]
... 7 more
