I use Ubuntu 20.04 and still openHAB 2 and of course the exec binding.
I got following error:
16:45:27.080 [INFO ] [del.core.internal.ModelRepositoryImpl] - Refreshing model 'pepper.items'
16:45:27.084 [ERROR] [del.item.internal.GenericItemProvider] - Binding configuration of type 'channel' of item 'gPepper02_Infoterminal' could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: ID segment '[exec' contains invalid characters. Each segment of the ID must match the pattern [A-Za-z0-9_-]*.
at org.eclipse.smarthome.model.thing.internal.GenericItemChannelLinkProvider.createItemChannelLink(GenericItemChannelLinkProvider.java:82) ~[?:?]
at org.eclipse.smarthome.model.thing.internal.GenericItemChannelLinkProvider.processBindingConfiguration(GenericItemChannelLinkProvider.java:72) ~[?:?]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:369) ~[?:?]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:338) ~[?:?]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.processBindingConfigsFromModel(GenericItemProvider.java:210) ~[?:?]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:404) ~[?:?]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:311) ~[?:?]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:149) ~[?:?]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:247) ~[?:?]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.processWatchEvent(FolderObserver.java:310) ~[?:?]
at org.eclipse.smarthome.core.service.WatchQueueReader.lambda$3(WatchQueueReader.java:323) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_302]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_302]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_302]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:1.8.0_302]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_302]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_302]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_302]
I tried it with \"
or \'
and @@
for the free spaces. Maybe you can help me:
My exec.whitelist:
/usr/bin/ssh -t -o StrictHostKeyChecking=no nao@192.168.0.41 'source /home/nao/.bash_profile; python albehaviormanager.py --function runBehavior --behavior_name "User/11_infoterminal-ade9a3/behavior_1"'
The pepper.items:
Switch gPepper02_Infoterminal (gPepper02_UserBehaviors) { channel="[exec:command:Pepper02InfoterminalRun:run]" }
And the pepper.things:
Thing exec:command:Pepper02InfoterminalRun [command="/usr/bin/ssh -t -o StrictHostKeyChecking=no nao@192.168.0.41 \'source/home/nao/.bash_profile; python albehaviormanager.py --function runBehavior --behavior_name \"User/11_infoterminal-ade9a3/behavior_1\"\'", interval=0, autorun=false]
I hope you can help me. Running sudo -u openhab /usr/bin/ssh -t -o StrictHostKeyChecking=no nao@192.168.0.41 'source /home/nao/.bash_profile; python albehaviormanager.py --function runBehavior --behavior_name "User/11_infoterminal-ade9a3/behavior_1"'
works fine by the way.
