ESP8266 and TFT_eSPI library to drive SPI displays
Over in DIY digital doorbell / peephole camera, I’m currently working on a peephole camera based on a ESP32 and a ST7789 240x240.
Drawing a picture from the camera full-screen needs approx. 90ms. Drawing a 240x160px picture needs approx. 60ms. I’ve noticed extreme speed up with this library especially when drawing lines & pixels and clearing the screen to a specific color.
My setup is like this:
// Config for TFT_eSPI (User_Setup.h)
#define ST7789_DRIVER // Full configuration option, define additional parameters below for this display
#define TFT_CS 12 // Chip select control pin D8
#define TFT_DC 15 // Data Command control pin
#define TFT_RST -1 // Reset pin (could connect to NodeMCU RST, see next line)
#define TFT_BL 2 // LED back-light (only for ST7789 with backlight control pin)
#define TFT_MISO 22
#define TFT_MOSI 19
#define TFT_SCLK 21
#define LOAD_GLCD // Font 1. Original Adafruit 8 pixel font needs ~1820 bytes in FLASH
#define LOAD_FONT2 // Font 2. Small 16 pixel high font, needs ~3534 bytes in FLASH, 96 characters
#define LOAD_FONT4 // Font 4. Medium 26 pixel high font, needs ~5848 bytes in FLASH, 96 characters
#define LOAD_FONT6 // Font 6. Large 48 pixel font, needs ~2666 bytes in FLASH, only characters 1234567890:-.apm
#define LOAD_FONT7 // Font 7. 7 segment 48 pixel font, needs ~2438 bytes in FLASH, only characters 1234567890:-.
#define LOAD_FONT8 // Font 8. Large 75 pixel font needs ~3256 bytes in FLASH, only characters 1234567890:-.
#define LOAD_GFXFF // FreeFonts. Include access to the 48 Adafruit_GFX free fonts FF1 to FF48 and custom fonts
#define SMOOTH_FONT
#define SPI_FREQUENCY 80000000
#define SPI_READ_FREQUENCY 20000000
#define SPI_TOUCH_FREQUENCY 2500000
#define USE_HSPI_PORT
The library has a big drawback: Setup is done in the library folder/user_setup.h - not in the sketch. You only need to update this file.
Please take a look at the Demo video (https://www.youtube.com/watch?v=-9_9u8o3ZCU) to get a glimpse of the speed.
EDIT: I’m just reading SDA/SCL on the picture in your post. Be sure to address the LCD by SPI. Did you also try with higher processor clock?
