Hmm, thanks for that. I implemented it and it works.
I used the Ikea rollerblinds that are springloaded. I removed the spring, so you cannot open it by hand (well, technically you can but it is really hard).
I’m planning to work on a different design that use a rails to open the curtains (the ‘normal’ curtains). That will use an endstop or something like that, but those you can open manually. Might have to think a bit harder about that.
That’s actually a very good idea to implement. I can create a function on the ESP that sends a mqtt signal to openhab, but how can I implement it? Is there a rule trigger for incoming mqtt messages? If yes, i think the best solution is to change the state when a certain message comes in.
