Platform information:
Mac High Sierra on a mac Mini with Openhab 2.1
Hi I’m trying to send a command to my Mac in a rules. Everything is working fine but now I’m trying to send a parameter in my commande so I need to add a space before my value and put my value between quoted mark
Thank you !! It seam to work but I still have an issue that I can’t figure out
Just to be sure if my value is ok is it possible to add the space and quoted mark directly to the value so I could check via the rest API if everything is ok
