Ok, thats strange.
After switching to the older release of you binding everything worked as expected.
I then had to boot my server and after that it stopped working again.
I then switched back to the newer release and it startet to work again. In the karaf console i could see some updates a few seconds after i dropped the newer releasee into the plugins folder. Here´s my log, maybe it helps:
> 13:04:19.179 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27100' changed from ONLINE to UNINITIALIZED
> 13:04:19.191 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27100' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.232 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8C2' changed from ONLINE to UNINITIALIZED
> 13:04:19.243 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8C2' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.257 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8E2' changed from ONLINE to UNINITIALIZED
> 13:04:19.283 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8E2' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.291 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27101' changed from ONLINE to UNINITIALIZED
> 13:04:19.295 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27101' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.316 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27130' changed from ONLINE to UNINITIALIZED
> 13:04:19.337 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27130' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.358 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27121' changed from ONLINE to UNINITIALIZED
> 13:04:19.378 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27121' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.487 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8C1' changed from ONLINE to UNINITIALIZED
> 13:04:19.491 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8C1' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.496 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8C0' changed from ONLINE to UNINITIALIZED
> 13:04:19.521 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8C0' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.535 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8E0' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.556 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8E0' changed from ONLINE to UNINITIALIZED
> 13:04:19.560 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8C3' changed from ONLINE to UNINITIALIZED
> 13:04:19.583 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8C3' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.591 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27132' changed from ONLINE to UNINITIALIZED
> 13:04:19.594 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27132' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.598 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x2D8D2' changed from ONLINE to UNINITIALIZED
> 13:04:19.606 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x2D8D2' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.611 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x2D8D1' changed from ONLINE to UNINITIALIZED
> 13:04:19.636 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x2D8D1' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.640 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8E4' changed from ONLINE to UNINITIALIZED
> 13:04:19.644 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8E4' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.648 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27131' changed from ONLINE to UNINITIALIZED
> 13:04:19.656 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27131' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.666 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8E1' changed from ONLINE to UNINITIALIZED
> 13:04:19.675 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8E1' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.679 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27120' changed from ONLINE to UNINITIALIZED
> 13:04:19.686 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27120' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.691 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27124' changed from ONLINE to UNINITIALIZED
> 13:04:19.712 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27124' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.717 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8E3' changed from ONLINE to UNINITIALIZED
> 13:04:19.720 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8E3' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.736 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x2D8D0' changed from ONLINE to UNINITIALIZED
> 13:04:19.744 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x2D8D0' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.748 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27133' changed from ONLINE to UNINITIALIZED
> 13:04:19.756 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27133' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.760 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D9A1' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.768 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D9A1' changed from ONLINE to UNINITIALIZED
> 13:04:19.771 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8D1' changed from ONLINE to UNINITIALIZED
> 13:04:19.786 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8D1' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.790 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27102' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.796 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27102' changed from ONLINE to UNINITIALIZED
> 13:04:19.802 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27123' changed from ONLINE to UNINITIALIZED
> 13:04:19.816 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8C4' changed from ONLINE to UNINITIALIZED
> 13:04:19.820 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27122' changed from ONLINE to UNINITIALIZED
> 13:04:19.826 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:esp8266Bridge:001' changed from ONLINE to UNINITIALIZED
> 13:04:19.829 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8C4' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.833 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27122' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.848 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27123' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.853 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:esp8266Bridge:001' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
> 13:04:19.996 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:esp8266Bridge:001' has been updated.
> 13:04:20.004 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x5D8C0' has been updated.
> 13:04:20.028 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x5D8C1' has been updated.
> 13:04:20.032 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x5D8C2' has been updated.
> 13:04:20.040 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x5D8C3' has been updated.
> 13:04:20.043 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x5D8C4' has been updated.
> 13:04:20.048 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x5D8E0' has been updated.
> 13:04:20.052 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x5D8E1' has been updated.
> 13:04:20.060 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x5D8E2' has been updated.
> 13:04:20.067 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x5D8E3' has been updated.
> 13:04:20.074 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x5D8E4' has been updated.
> 13:04:20.083 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x2D8D0' has been updated.
> 13:04:20.092 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x2D8D1' has been updated.
> 13:04:20.103 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x2D8D2' has been updated.
> 13:04:20.111 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x5D8D1' has been updated.
> 13:04:20.122 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x27100' has been updated.
> 13:04:20.131 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x27101' has been updated.
> 13:04:20.137 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x27102' has been updated.
> 13:04:20.148 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x27120' has been updated.
> 13:04:20.151 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x27121' has been updated.
> 13:04:20.162 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x27122' has been updated.
> 13:04:20.166 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x27123' has been updated.
> 13:04:20.177 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x27124' has been updated.
> 13:04:20.181 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x27130' has been updated.
> 13:04:20.186 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x27131' has been updated.
> 13:04:20.189 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x27132' has been updated.
> 13:04:20.196 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x27133' has been updated.
> 13:04:20.200 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'espmilighthub:rgb_cct:001:0x5D9A1' has been updated.
> 13:04:20.207 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:esp8266Bridge:001' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:20.231 [INFO ] [ub.handler.EspMilightHubBridgeHandler] - MQTT sucessfully connected
> 13:04:20.234 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:esp8266Bridge:001' changed from INITIALIZING to ONLINE
> 13:04:20.274 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8C0' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:20.319 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8C1' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:20.338 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8C2' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:20.495 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8C1' changed from INITIALIZING to ONLINE
> 13:04:20.575 [INFO ] [ub.handler.EspMilightHubBridgeHandler] - MQTT sucessfully connected
> 13:04:20.596 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8C3' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:20.645 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8C4' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:20.676 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8C3' changed from INITIALIZING to ONLINE
> 13:04:20.736 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8E0' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:20.761 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8E1' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:20.782 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8C0' changed from INITIALIZING to ONLINE
> 13:04:20.786 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8C2' changed from INITIALIZING to ONLINE
> 13:04:20.789 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8C4' changed from INITIALIZING to ONLINE
> 13:04:20.792 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8E2' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:20.799 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8E3' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:20.835 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8D1' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:20.839 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27121' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:20.842 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8E4' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:20.855 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27100' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:20.867 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27122' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:20.878 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8E0' changed from INITIALIZING to ONLINE
> 13:04:20.890 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8E1' changed from INITIALIZING to ONLINE
> 13:04:20.916 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27131' changed from INITIALIZING to ONLINE
> 13:04:20.936 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27124' changed from INITIALIZING to ONLINE
> 13:04:20.939 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27133' changed from INITIALIZING to ONLINE
> 13:04:20.942 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x2D8D0' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:20.946 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27101' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:20.950 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27131' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:20.954 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27133' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:20.968 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8E2' changed from INITIALIZING to ONLINE
> 13:04:20.972 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8E3' changed from INITIALIZING to ONLINE
> 13:04:20.997 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8E4' changed from INITIALIZING to ONLINE
> 13:04:21.000 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x2D8D0' changed from INITIALIZING to ONLINE
> 13:04:21.003 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27101' changed from INITIALIZING to ONLINE
> 13:04:21.006 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x2D8D1' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:21.009 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27102' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:21.013 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27123' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:21.017 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27132' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:21.021 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x2D8D2' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:21.024 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27120' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:21.028 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x2D8D1' changed from INITIALIZING to ONLINE
> 13:04:21.043 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x2D8D2' changed from INITIALIZING to ONLINE
> 13:04:21.047 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D8D1' changed from INITIALIZING to ONLINE
> 13:04:21.060 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27100' changed from INITIALIZING to ONLINE
> 13:04:21.063 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27102' changed from INITIALIZING to ONLINE
> 13:04:21.066 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27120' changed from INITIALIZING to ONLINE
> 13:04:21.069 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27130' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:21.073 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27122' changed from INITIALIZING to ONLINE
> 13:04:21.091 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27130' changed from INITIALIZING to ONLINE
> 13:04:21.095 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27132' changed from INITIALIZING to ONLINE
> 13:04:21.098 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27124' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:21.102 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D9A1' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
> 13:04:21.106 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27121' changed from INITIALIZING to ONLINE
> 13:04:21.109 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x27123' changed from INITIALIZING to ONLINE
> 13:04:21.120 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'espmilighthub:rgb_cct:001:0x5D9A1' changed from INITIALIZING to ONLINE
> 13:04:21.124 [INFO ] [smarthome.event.ItemStateChangedEvent] - Kuechenlicht_3_Level changed from 1 to 0
> 13:04:21.146 [INFO ] [smarthome.event.ItemStateChangedEvent] - Remote_3_State changed from ON to OFF
> 13:04:21.149 [INFO ] [smarthome.event.ItemStateChangedEvent] - Remote_3_Level changed from 1 to 0
> 13:04:21.154 [INFO ] [smarthome.event.ItemStateChangedEvent] - Kuechenlicht_3_State changed from ON to OFF
> 13:04:21.157 [INFO ] [smarthome.event.ItemStateChangedEvent] - Tuerlicht_Level changed from 50 to 0
> 13:04:21.161 [INFO ] [smarthome.event.ItemStateChangedEvent] - L_EZ_3_Level changed from 100 to 0
> 13:04:21.164 [INFO ] [smarthome.event.ItemStateChangedEvent] - Baumlicht_Level changed from 100 to 0
> 13:04:22.067 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Kuechenlicht_0_State' received command OFF
> 13:04:22.089 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Kuechenlicht_0_State' received command OFF
> 13:04:22.093 [INFO ] [smarthome.event.ItemStateChangedEvent] - Kuechenlicht_0_State changed from ON to OFF
> 13:04:22.104 [INFO ] [home.event.GroupItemStateChangedEvent] - gParty_Licht_state changed from ON to OFF through Kuechenlicht_0_State
> 13:04:22.108 [INFO ] [home.event.GroupItemStateChangedEvent] - gkuechenlicht changed from ON to OFF through Kuechenlicht_0_State
> 13:04:22.112 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Kuechenlicht_0_State' received command OFF
> 13:04:22.114 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Kuechenlicht_0_State' received command OFF
> 13:04:26.271 [INFO ] [smarthome.event.ItemStateChangedEvent] - Remote_1_State changed from OFF to ON
> 13:04:26.278 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Kuechenlicht_0_State' received command ON
> 13:04:26.296 [INFO ] [smarthome.event.ItemStateChangedEvent] - Kuechenlicht_1_Level changed from 0 to 69
> 13:04:26.299 [INFO ] [smarthome.event.ItemStateChangedEvent] - Remote_1_Level changed from 0 to 69
> 13:04:26.302 [INFO ] [smarthome.event.ItemStateChangedEvent] - Kuechenlicht_1_State changed from OFF to ON
> 13:04:26.306 [INFO ] [home.event.GroupItemStateChangedEvent] - gkuechenlicht changed from OFF to ON through Kuechenlicht_1_State
> 13:04:26.309 [INFO ] [smarthome.event.ItemStateChangedEvent] - Kuechenlicht_0_State changed from OFF to ON
> 13:04:26.326 [INFO ] [smarthome.event.ItemStateChangedEvent] - Remote_1_Hue changed from 360,100,1 to 360,100,69
> 13:04:26.329 [INFO ] [smarthome.event.ItemStateChangedEvent] - Kuechenlicht_1_Hue changed from 360,100,1 to 360,100,69
> 13:04:26.335 [INFO ] [home.event.GroupItemStateChangedEvent] - gParty_Licht_state changed from OFF to ON through Kuechenlicht_0_State
> 13:04:26.338 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Kuechenlicht_0_Hue' received command 360,100,69
> 13:04:26.341 [INFO ] [smarthome.event.ItemStateChangedEvent] - Kuechenlicht_0_Hue changed from 319,100,0 to 360,100,69
> 13:04:28.472 [INFO ] [smarthome.event.ItemStateChangedEvent] - Remote_1_State changed from ON to OFF
> 13:04:28.492 [INFO ] [smarthome.event.ItemStateChangedEvent] - Remote_1_Level changed from 69 to 0
> 13:04:28.508 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Kuechenlicht_0_State' received command OFF
> 13:04:28.511 [INFO ] [smarthome.event.ItemStateChangedEvent] - Kuechenlicht_1_State changed from ON to OFF
> 13:04:28.516 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Kuechenlicht_0_State' received command OFF
> 13:04:28.521 [INFO ] [smarthome.event.ItemStateChangedEvent] - Kuechenlicht_1_Level changed from 69 to 0
> 13:04:28.524 [INFO ] [smarthome.event.ItemStateChangedEvent] - Kuechenlicht_0_State changed from ON to OFF
> 13:04:28.527 [INFO ] [home.event.GroupItemStateChangedEvent] - gParty_Licht_state changed from ON to OFF through Kuechenlicht_0_State
> 13:04:28.532 [INFO ] [home.event.GroupItemStateChangedEvent] - gkuechenlicht changed from ON to OFF through Kuechenlicht_0_State
> 13:04:28.539 [INFO ] [home.event.GroupItemStateChangedEvent] - gkuechenlicht changed from ON to OFF through Kuechenlicht_0_State
> 13:04:29.864 [INFO ] [smarthome.event.ItemStateChangedEvent] - Kuechenlicht_2_State changed from OFF to ON
> 13:04:29.926 [INFO ] [smarthome.event.ItemStateChangedEvent] - Remote_2_State changed from OFF to ON
> 13:04:29.930 [INFO ] [smarthome.event.ItemStateChangedEvent] - Kuechenlicht_2_Hue changed from 336,100,1 to 336,100,84
> 13:04:29.933 [INFO ] [smarthome.event.ItemStateChangedEvent] - Remote_2_Level changed from 0 to 84
> 13:04:29.936 [INFO ] [smarthome.event.ItemStateChangedEvent] - Kuechenlicht_2_Level changed from 0 to 84
> 13:04:29.940 [INFO ] [smarthome.event.ItemStateChangedEvent] - Remote_2_Hue changed from 336,100,1 to 336,100,84
> 13:04:29.946 [INFO ] [home.event.GroupItemStateChangedEvent] - gkuechenlicht changed from OFF to ON through Kuechenlicht_2_State
> 13:04:30.902 [INFO ] [smarthome.event.ItemStateChangedEvent] - Kuechenlicht_2_State changed from ON to OFF
> 13:04:30.919 [INFO ] [home.event.GroupItemStateChangedEvent] - gkuechenlicht changed from ON to OFF through Kuechenlicht_2_State
> 13:04:30.923 [INFO ] [smarthome.event.ItemStateChangedEvent] - Remote_2_State changed from ON to OFF
> 13:04:30.926 [INFO ] [smarthome.event.ItemStateChangedEvent] - Remote_2_Level changed from 84 to 0
> 13:04:30.928 [INFO ] [smarthome.event.ItemStateChangedEvent] - Kuechenlicht_2_Level changed from 84 to 0
