thanks matt.
yeah, the new 2.5 version works on both RGBW and RGB_CCT group zero does apply it’s state to individual groups.
I do have an issue with the 2.5 binding though, for some reason it keeps disconnecting and connecting to the MQTT broker.
16:27:03.626 [INFO ] [ub.handler.EspMilightHubBridgeHandler] - Sucessfully connected to the MQTT broker.
16:27:03.658 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘espmilighthub:esp8266Bridge:Auto001’ changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): MQTT broker connection lost:Connection lost (32109) - java.io.EOFException
16:27:03.668 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘espmilighthub:esp8266Bridge:Auto001’ changed from OFFLINE (COMMUNICATION_ERROR): MQTT broker connection lost:Connection lost (32109) - java.io.EOFException to ONLINE
16:27:03.693 [ERROR] [ub.handler.EspMilightHubBridgeHandler] - MQTT connection has been lost, cause reported is:{}
org.eclipse.paho.client.mqttv3.MqttException: Connection lost
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:181) [249:org.eclipse.paho.client.mqttv3:1.2.0]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
Caused by: java.io.EOFException
at java.io.DataInputStream.readByte(DataInputStream.java:267) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream.readMqttWireMessage(MqttInputStream.java:92) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:133) ~[?:?]
… 7 more
16:27:03.695 [INFO ] [ub.handler.EspMilightHubBridgeHandler] - Sucessfully connected to the MQTT broker.
16:27:03.723 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘espmilighthub:esp8266Bridge:Auto001’ changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): MQTT broker connection lost:Connection lost (32109) - java.io.EOFException
16:27:03.729 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘espmilighthub:esp8266Bridge:Auto001’ changed from OFFLINE (COMMUNICATION_ERROR): MQTT broker connection lost:Connection lost (32109) - java.io.EOFException to ONLINE
16:27:04.665 [ERROR] [ub.handler.EspMilightHubBridgeHandler] - MQTT connection has been lost, cause reported is:{}
… 7 more
16:27:04.667 [INFO ] [ub.handler.EspMilightHubBridgeHandler] - Sucessfully connected to the MQTT broker.
16:27:04.690 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘espmilighthub:esp8266Bridge:Auto001’ changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): MQTT broker connection lost:Connection lost (32109) - java.io.EOFException
16:27:04.702 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘espmilighthub:esp8266Bridge:Auto001’ changed from OFFLINE (COMMUNICATION_ERROR): MQTT broker connection lost:Connection lost (32109) - java.io.EOFException to ONLINE
16:27:04.722 [ERROR] [ub.handler.EspMilightHubBridgeHandler] - MQTT connection has been lost, cause reported is:{}
… 7 more
This happens every second. on off on off. It starts off about every minute then gets faster. till the log is just a steady stream of disconnect/connect.
I will note that in 2.4 it disconnects and reconnects about every 5 minutes or so, and does not seem to have much of an effect on usability.
I’m trying to sort through the above posts to get a grasp on the changes, but it’s a bit unclear to me.
As per my setup, I’m on 2.4 openhab, not using the MQTT binding, but using mosquitto installed on the rasberry pi for MQTT.
Just wanting to be clear on what you suggest, I currently have the org.eclipse.paho.client.mqttv3-1.2.0.jar in the addons folder, but I’m assuming I may not need it there.
