I’m still having issues when trying to use the 2.5 binding. I don’t have this issue with 2.4 so I’m wondering what I can look at to help resolve the issue. basically the system works for about 2 minutes after reboot. then it starts to become unstable, and I start to get connects/disconnects to the MQTT (mosquitto) broker. They are running on the same machine, the ESP module has no issues staying connected to the broker, but for some reason the binding keeps connecting and disconnecting.
15:29:25.641 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘espmilighthub:esp8266Bridge:001’ changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): MQTT broker connection lost:Connection lost (32109) - java.io.EOFException
15:29:25.676 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘espmilighthub:esp8266Bridge:001’ changed from OFFLINE (COMMUNICATION_ERROR): MQTT broker connection lost:Connection lost (32109) - java.io.EOFException to ONLINE
15:29:25.681 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘espmilighthub:rgbw:001:0x14BA1’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
15:29:25.687 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘espmilighthub:rgbw:001:0x14BA2’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
15:29:25.691 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘espmilighthub:rgbw:001:0x14BA3’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
15:29:25.695 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘espmilighthub:rgb_cct:001:0x88F1’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
15:29:25.699 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘espmilighthub:rgb_cct:001:0x88F2’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
15:29:25.706 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘espmilighthub:rgb_cct:001:0x88F3’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
15:29:25.714 [INFO ] [ub.handler.EspMilightHubBridgeHandler] - Sucessfully connected to the MQTT broker.
15:29:25.715 [INFO ] [ub.handler.EspMilightHubBridgeHandler] - Sucessfully connected to the MQTT broker.
15:29:25.729 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘espmilighthub:rgbw:001:0x14BA1’ changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
15:29:25.739 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘espmilighthub:rgbw:001:0x14BA2’ changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
15:29:25.749 [ERROR] [ub.handler.EspMilightHubBridgeHandler] - MQTT connection has been lost, cause reported is:{}
org.eclipse.paho.client.mqttv3.MqttException: Connection lost
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:190) [53:org.eclipse.paho.client.mqttv3:1.2.2]
Caused by: java.io.EOFException
at java.io.DataInputStream.readByte(DataInputStream.java:267) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream.readMqttWireMessage(MqttInputStream.java:92) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:137) ~[?:?]
… 1 more
15:29:25.769 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘espmilighthub:rgbw:001:0x14BA3’ changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
15:29:25.765 [INFO ] [ub.handler.EspMilightHubBridgeHandler] - Sucessfully connected to the MQTT broker.
15:29:25.782 [INFO ] [ub.handler.EspMilightHubBridgeHandler] - Sucessfully connected to the MQTT broker.
15:29:25.789 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘espmilighthub:rgb_cct:001:0x88F1’ changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
15:29:25.797 [ERROR] [ub.handler.EspMilightHubBridgeHandler] - MQTT connection has been lost, cause reported is:{}
… 1 more
15:29:25.814 [INFO ] [ub.handler.EspMilightHubBridgeHandler] - Sucessfully connected to the MQTT broker.
15:29:25.803 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘espmilighthub:rgb_cct:001:0x88F2’ changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
15:29:25.834 [INFO ] [ub.handler.EspMilightHubBridgeHandler] - Sucessfully connected to the MQTT broker.
15:29:25.830 [ERROR] [ub.handler.EspMilightHubBridgeHandler] - MQTT connection has been lost, cause reported is:{}
… 1 more
15:29:25.839 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘espmilighthub:rgb_cct:001:0x88F3’ changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
15:29:25.871 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘espmilighthub:esp8266Bridge:001’ changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): MQTT broker connection lost:Connection lost (32109) - java.io.EOFException
15:29:25.880 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘espmilighthub:rgbw:001:0x14BA1’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
15:29:25.883 [INFO ] [ub.handler.EspMilightHubBridgeHandler] - Sucessfully connected to the MQTT broker.
15:29:25.890 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘espmilighthub:rgbw:001:0x14BA2’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
caches cleared. any help in what I should look for. I’m somewhat baffled. Since I got lots of time at home figured I would try to find out what the issue is.
