It has been a while since I tried my bulb with your binding. And it turns out that there is a problem. I didn’t realize it at first…
If I power cycle the bulb (from off to on) the connection is not re-established and the bulb does not react any more. But if I restart the binding from the karaf console everything works as it should.
The bulb has never been part of my hue network. And it does not matter if the hue controller is online or not. Behaviour is the same. I’m running snapshot Build #1073 with your afore mentionend binding on Debian Jessie with Kernel 4.12 and Oracle Java (build 1.8.0_151-b12).
I attached a debug log. Maybe it is useful for you. I made some comments (marked with " --> " and in bold) within the log for the following actions:
–> bulb powered on
13-Nov-2017 20:57:43.102 [DEBUG] [ab.binding.zigbee.handler.ZigBeeCoordinatorHandler] - ZigBee Node discovered: ZigBeeNode [IEEE=0017880102E7B6B0, NWK=C055, Type=ROUTER]
13-Nov-2017 20:57:43.102 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880102E7B6B0: Node updated - ZigBeeNode [IEEE=0017880102E7B6B0, NWK=C055, Type=ROUTER]
13-Nov-2017 20:57:43.113 [INFO ] [ab.binding.zigbee.discovery.ZigBeeDiscoveryService] - 0017880102E7B6B0: Starting ZigBee device discovery
13-Nov-2017 20:57:43.114 [DEBUG] [ding.zigbee.discovery.ZigBeeNodePropertyDiscoverer] - 0017880102E7B6B0: ZigBee node property discovery start
13-Nov-2017 20:57:43.114 [DEBUG] [ding.zigbee.discovery.ZigBeeNodePropertyDiscoverer] - 0017880102E7B6B0: ZigBee node property discovery using 16974/11
13-Nov-2017 20:57:53.116 [DEBUG] [ding.zigbee.discovery.ZigBeeNodePropertyDiscoverer] - 0017880102E7B6B0: Manufacturer request timeout
13-Nov-2017 20:57:55.298 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880102E7B6B0: Node updated - ZigBeeNode [IEEE=0017880102E7B6B0, NWK=C055, Type=ROUTER]
13-Nov-2017 20:58:03.118 [DEBUG] [ding.zigbee.discovery.ZigBeeNodePropertyDiscoverer] - 0017880102E7B6B0: Model request timeout
13-Nov-2017 20:58:13.120 [DEBUG] [ding.zigbee.discovery.ZigBeeNodePropertyDiscoverer] - 0017880102E7B6B0: Hardware version request timeout
13-Nov-2017 20:58:23.122 [DEBUG] [ding.zigbee.discovery.ZigBeeNodePropertyDiscoverer] - 0017880102E7B6B0: Stack version request timeout
13-Nov-2017 20:58:33.124 [DEBUG] [ding.zigbee.discovery.ZigBeeNodePropertyDiscoverer] - 0017880102E7B6B0: ZCL version request timeout
13-Nov-2017 20:58:43.126 [DEBUG] [ding.zigbee.discovery.ZigBeeNodePropertyDiscoverer] - 0017880102E7B6B0: Application version request timeout
13-Nov-2017 20:58:53.128 [DEBUG] [ding.zigbee.discovery.ZigBeeNodePropertyDiscoverer] - 0017880102E7B6B0: Date code request timeout
13-Nov-2017 20:58:53.128 [DEBUG] [ding.zigbee.discovery.ZigBeeNodePropertyDiscoverer] - 0017880102E7B6B0: ZigBee node property discovery complete: {zigbee_logicaltype=ROUTER, zigbee_powerlevel=FULL, zigbee_networkaddress=49237, zigbee_powermode=RECEIVER_ON_IDLE, zigbee_powersources=[MAINS, DISPOSABLE_BATTERY, RECHARGABLE_BATTERY], zigbee_powersource=MAINS}
13-Nov-2017 20:58:53.128 [INFO ] [ab.binding.zigbee.discovery.ZigBeeDiscoveryService] - 0017880102E7B6B0: Update ZigBee device zigbee:device with bridge zigbee:coordinator_telegesis:6933de2d
13-Nov-2017 20:59:25.275 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880102E7B6B0: Node updated - ZigBeeNode [IEEE=0017880102E7B6B0, NWK=C055, Type=ROUTER]
13-Nov-2017 21:00:55.321 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880102E7B6B0: Node updated - ZigBeeNode [IEEE=0017880102E7B6B0, NWK=C055, Type=ROUTER]
13-Nov-2017 21:02:25.299 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880102E7B6B0: Node updated - ZigBeeNode [IEEE=0017880102E7B6B0, NWK=C055, Type=ROUTER]
13-Nov-2017 21:03:55.368 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880102E7B6B0: Node updated - ZigBeeNode [IEEE=0017880102E7B6B0, NWK=C055, Type=ROUTER]
–> turned openhab switch off = nothing happens
13-Nov-2017 21:03:55.450 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880102E7B6B0: Command for channel zigbee:device:6933de2d:0017880102e7b6b0:0017880102E7B6B0_11_switch_onoff --> OFF
13-Nov-2017 21:04:24.200 [DEBUG] [org.openhab.binding.zigbee ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.config.core.ConfigOptionProvider, org.eclipse.smarthome.config.core.ConfigDescriptionProvider}={component.name=org.openhab.binding.zigbee.internal.ZigBeeConfigProvider, component.id=305, service.id=489, service.bundleid=14, service.scope=bundle} - org.openhab.binding.zigbee
–> bundle:stop in karaf
13-Nov-2017 21:04:24.220 [DEBUG] [org.openhab.binding.zigbee ] - ServiceEvent UNREGISTERING - {org.openhab.binding.zigbee.internal.ZigBeeConfigProvider}={component.name=org.openhab.binding.zigbee.ConfigDescription, component.id=306, service.id=490, service.bundleid=14, service.scope=bundle} - org.openhab.binding.zigbee
13-Nov-2017 21:04:24.224 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - Handler disposes. Unregistering listener.
13-Nov-2017 21:04:24.233 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - Handler disposes. Unregistering listener.
13-Nov-2017 21:04:29.215 [INFO ] [g.zigbee.handler.ZigBeeCoordinatorTelegesisHandler] - Serial port [/dev/zigbee] is closed.
13-Nov-2017 21:04:29.234 [DEBUG] [org.openhab.binding.zigbee ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=org.openhab.binding.zigbee.internal.ZigBeeHandlerFactory, component.id=307, service.id=491, service.bundleid=14, service.scope=bundle} - org.openhab.binding.zigbee
13-Nov-2017 21:04:29.265 [DEBUG] [org.openhab.binding.zigbee ] - BundleEvent STOPPING - org.openhab.binding.zigbee
13-Nov-2017 21:04:29.270 [DEBUG] [org.openhab.binding.zigbee ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=492, service.bundleid=14, service.scope=singleton} - org.openhab.binding.zigbee
13-Nov-2017 21:04:29.272 [DEBUG] [org.openhab.binding.zigbee ] - BundleEvent STOPPED - org.openhab.binding.zigbee
–> bundle:start in karaf
13-Nov-2017 21:04:44.587 [DEBUG] [org.openhab.binding.zigbee ] - BundleEvent STARTING - org.openhab.binding.zigbee
13-Nov-2017 21:04:44.602 [DEBUG] [org.openhab.binding.zigbee ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.ConfigOptionProvider, org.eclipse.smarthome.config.core.ConfigDescriptionProvider}={component.name=org.openhab.binding.zigbee.internal.ZigBeeConfigProvider, component.id=308, service.id=493, service.bundleid=14, service.scope=bundle} - org.openhab.binding.zigbee
13-Nov-2017 21:04:44.605 [DEBUG] [org.openhab.binding.zigbee ] - ServiceEvent REGISTERED - {org.openhab.binding.zigbee.internal.ZigBeeConfigProvider}={component.name=org.openhab.binding.zigbee.ConfigDescription, component.id=309, service.id=494, service.bundleid=14, service.scope=bundle} - org.openhab.binding.zigbee
13-Nov-2017 21:04:44.611 [DEBUG] [org.openhab.binding.zigbee ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=org.openhab.binding.zigbee.internal.ZigBeeHandlerFactory, component.id=310, service.id=495, service.bundleid=14, service.scope=bundle} - org.openhab.binding.zigbee
13-Nov-2017 21:04:44.615 [DEBUG] [org.openhab.binding.zigbee ] - BundleEvent STARTED - org.openhab.binding.zigbee
13-Nov-2017 21:04:44.635 [DEBUG] [enhab.binding.zigbee.internal.ZigBeeHandlerFactory] - Creating coordinator handler for org.eclipse.smarthome.core.thing.internal.BridgeImpl@55580b57
13-Nov-2017 21:04:44.650 [DEBUG] [g.zigbee.handler.ZigBeeCoordinatorTelegesisHandler] - Initializing ZigBee Telegesis serial bridge handler.
13-Nov-2017 21:04:44.651 [DEBUG] [ab.binding.zigbee.handler.ZigBeeCoordinatorHandler] - Initializing ZigBee network [zigbee:coordinator_telegesis:6933de2d].
13-Nov-2017 21:04:44.651 [DEBUG] [ab.binding.zigbee.handler.ZigBeeCoordinatorHandler] - Channel 22
13-Nov-2017 21:04:44.652 [DEBUG] [ab.binding.zigbee.handler.ZigBeeCoordinatorHandler] - PANID 35279
13-Nov-2017 21:04:44.652 [DEBUG] [ab.binding.zigbee.handler.ZigBeeCoordinatorHandler] - EPANID 5A754F916801953F
13-Nov-2017 21:04:44.653 [DEBUG] [ab.binding.zigbee.handler.ZigBeeCoordinatorHandler] - Key null
13-Nov-2017 21:04:44.653 [DEBUG] [ab.binding.zigbee.handler.ZigBeeCoordinatorHandler] - Key String
13-Nov-2017 21:04:44.654 [DEBUG] [ab.binding.zigbee.handler.ZigBeeCoordinatorHandler] - Key initialised BC60D26793ABAAD4285EBC6DE49C75D9
13-Nov-2017 21:04:44.654 [DEBUG] [ab.binding.zigbee.handler.ZigBeeCoordinatorHandler] - Key final array BC60D26793ABAAD4285EBC6DE49C75D9
13-Nov-2017 21:04:44.655 [DEBUG] [g.zigbee.handler.ZigBeeCoordinatorTelegesisHandler] - ZigBee Coordinator Telegesis opening Port:’/dev/zigbee’ PAN:89cf, EPAN:5A754F916801953F, Channel:22
13-Nov-2017 21:04:44.655 [DEBUG] [ab.binding.zigbee.handler.ZigBeeCoordinatorHandler] - Scheduling ZigBee start
13-Nov-2017 21:04:45.656 [DEBUG] [ab.binding.zigbee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
13-Nov-2017 21:04:45.656 [DEBUG] [ab.binding.zigbee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
13-Nov-2017 21:04:45.657 [DEBUG] [ab.binding.zigbee.discovery.ZigBeeDiscoveryService] - Creating ZigBee discovery service for zigbee:coordinator_telegesis:6933de2d
13-Nov-2017 21:04:45.657 [DEBUG] [ab.binding.zigbee.discovery.ZigBeeDiscoveryService] - Activating ZigBee discovery service for zigbee:coordinator_telegesis:6933de2d
13-Nov-2017 21:04:45.658 [DEBUG] [org.openhab.binding.zigbee ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=496, service.bundleid=14, service.scope=singleton} - org.openhab.binding.zigbee
13-Nov-2017 21:04:45.659 [DEBUG] [ab.binding.zigbee.handler.ZigBeeCoordinatorHandler] - Key initialise BC60D26793ABAAD4285EBC6DE49C75D9
13-Nov-2017 21:04:45.659 [INFO ] [g.zigbee.handler.ZigBeeCoordinatorTelegesisHandler] - Connecting to serial port [/dev/zigbee] at 19200
13-Nov-2017 21:04:45.671 [INFO ] [g.zigbee.handler.ZigBeeCoordinatorTelegesisHandler] - Serial port [/dev/zigbee] is initialized.
13-Nov-2017 21:04:45.799 [DEBUG] [ab.binding.zigbee.handler.ZigBeeCoordinatorHandler] - initResponse is JOINED
13-Nov-2017 21:04:45.799 [DEBUG] [ab.binding.zigbee.handler.ZigBeeCoordinatorHandler] - initializeNetwork is false
13-Nov-2017 21:04:45.830 [DEBUG] [ab.binding.zigbee.handler.ZigBeeCoordinatorHandler] - Initialise done… 22 35279 5A754F916801953F
13-Nov-2017 21:04:45.832 [DEBUG] [enhab.binding.zigbee.internal.ZigBeeHandlerFactory] - Creating coordinator handler for org.eclipse.smarthome.core.thing.internal.ThingImpl@567b9952
13-Nov-2017 21:04:45.831 [DEBUG] [enhab.binding.zigbee.internal.ZigBeeHandlerFactory] - Creating coordinator handler for org.eclipse.smarthome.core.thing.internal.ThingImpl@ea06ddab
13-Nov-2017 21:04:45.839 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - Initializing ZigBee thing handler zigbee:device:6933de2d:0017880100be9f54.
13-Nov-2017 21:04:45.840 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - Initializing ZigBee thing handler zigbee:device:6933de2d:0017880102e7b6b0.
13-Nov-2017 21:04:45.840 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880100BE9F54: Coordinator status changed to ONLINE.
13-Nov-2017 21:04:45.840 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880100BE9F54: Coordinator is ONLINE. Starting device initialisation.
13-Nov-2017 21:04:45.847 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880102E7B6B0: Coordinator status changed to ONLINE.
13-Nov-2017 21:04:45.847 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880102E7B6B0: Coordinator is ONLINE. Starting device initialisation.
13-Nov-2017 21:04:45.851 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880100BE9F54: Command for channel zigbee:device:6933de2d:0017880100be9f54:0017880100BE9F54_11_switch_level --> REFRESH
13-Nov-2017 21:04:45.852 [WARN ] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - No handler found for zigbee:device:6933de2d:0017880100be9f54:0017880100BE9F54_11_switch_level
13-Nov-2017 21:04:45.853 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880102E7B6B0: Command for channel zigbee:device:6933de2d:0017880102e7b6b0:0017880102E7B6B0_11_switch_level --> REFRESH
13-Nov-2017 21:04:45.853 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880100BE9F54: Command for channel zigbee:device:6933de2d:0017880100be9f54:0017880100BE9F54_11_switch_onoff --> REFRESH
13-Nov-2017 21:04:45.854 [WARN ] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - No handler found for zigbee:device:6933de2d:0017880100be9f54:0017880100BE9F54_11_switch_onoff
13-Nov-2017 21:04:45.854 [WARN ] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - No handler found for zigbee:device:6933de2d:0017880102e7b6b0:0017880102E7B6B0_11_switch_level
13-Nov-2017 21:04:45.854 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880102E7B6B0: Command for channel zigbee:device:6933de2d:0017880102e7b6b0:0017880102E7B6B0_11_switch_onoff --> REFRESH
13-Nov-2017 21:04:45.854 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880100BE9F54: Command for channel zigbee:device:6933de2d:0017880100be9f54:0017880100BE9F54_11_color_color --> REFRESH
13-Nov-2017 21:04:45.855 [WARN ] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - No handler found for zigbee:device:6933de2d:0017880100be9f54:0017880100BE9F54_11_color_color
13-Nov-2017 21:04:45.855 [WARN ] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - No handler found for zigbee:device:6933de2d:0017880102e7b6b0:0017880102E7B6B0_11_switch_onoff
13-Nov-2017 21:04:45.855 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880100BE9F54: Command for channel zigbee:device:6933de2d:0017880100be9f54:0017880100BE9F54_11_color_temperature --> REFRESH
13-Nov-2017 21:04:45.855 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880102E7B6B0: Command for channel zigbee:device:6933de2d:0017880102e7b6b0:0017880102E7B6B0_11_color_color --> REFRESH
13-Nov-2017 21:04:45.855 [WARN ] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - No handler found for zigbee:device:6933de2d:0017880100be9f54:0017880100BE9F54_11_color_temperature
13-Nov-2017 21:04:45.855 [WARN ] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - No handler found for zigbee:device:6933de2d:0017880102e7b6b0:0017880102E7B6B0_11_color_color
13-Nov-2017 21:04:45.857 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880100BE9F54: Initialising node
13-Nov-2017 21:04:45.857 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880102E7B6B0: Command for channel zigbee:device:6933de2d:0017880102e7b6b0:0017880102E7B6B0_11_color_temperature --> REFRESH
13-Nov-2017 21:04:45.857 [WARN ] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - No handler found for zigbee:device:6933de2d:0017880102e7b6b0:0017880102E7B6B0_11_color_temperature
13-Nov-2017 21:04:45.858 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880102E7B6B0: Initialising node
13-Nov-2017 21:04:46.300 [DEBUG] [ab.binding.zigbee.handler.ZigBeeCoordinatorHandler] - ZigBee Node discovered: ZigBeeNode [IEEE=000D6F00049DC3EB, NWK=0000, Type=COORDINATOR]
13-Nov-2017 21:05:00.973 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880102E7B6B0: Node updated - ZigBeeNode [IEEE=0017880102E7B6B0, NWK=C055, Type=ROUTER]
13-Nov-2017 21:05:00.973 [DEBUG] [ab.binding.zigbee.handler.ZigBeeCoordinatorHandler] - ZigBee Node discovered: ZigBeeNode [IEEE=0017880102E7B6B0, NWK=C055, Type=ROUTER]
13-Nov-2017 21:05:00.984 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880102E7B6B0: Initialising node
13-Nov-2017 21:05:00.985 [INFO ] [ab.binding.zigbee.discovery.ZigBeeDiscoveryService] - 0017880102E7B6B0: Starting ZigBee device discovery
13-Nov-2017 21:05:00.986 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880102E7B6B0: Created 4 channels
13-Nov-2017 21:05:00.986 [DEBUG] [ding.zigbee.discovery.ZigBeeNodePropertyDiscoverer] - 0017880102E7B6B0: ZigBee node property discovery start
13-Nov-2017 21:05:00.987 [DEBUG] [ding.zigbee.discovery.ZigBeeNodePropertyDiscoverer] - 0017880102E7B6B0: ZigBee node property discovery using 49237/11
13-Nov-2017 21:05:01.427 [DEBUG] [inding.zigbee.converter.ZigBeeConverterSwitchLevel] - ZigBee attribute reports ZclAttribute [cluster=LEVEL_CONTROL, id=0, name=CurrentLevel, dataType=UNSIGNED_8_BIT_INTEGER, lastValue=254] from 0017880102E7B6B0
13-Nov-2017 21:05:01.433 [DEBUG] [inding.zigbee.converter.ZigBeeConverterSwitchOnoff] - 0017880102E7B6B0: Initialising device on/off cluster
13-Nov-2017 21:05:02.076 [DEBUG] [inding.zigbee.converter.ZigBeeConverterSwitchOnoff] - 0017880102E7B6B0: ZigBee attribute reports ZclAttribute [cluster=ON_OFF, id=0, name=OnOff, dataType=BOOLEAN, lastValue=true]
13-Nov-2017 21:05:02.817 [DEBUG] [binding.zigbee.converter.ZigBeeConverterColorColor] - ZigBee attribute reports ZclAttribute [cluster=COLOR_CONTROL, id=0, name=CurrentHue, dataType=UNSIGNED_8_BIT_INTEGER, lastValue=null] from 0017880102E7B6B0
13-Nov-2017 21:05:03.179 [DEBUG] [inding.zigbee.converter.ZigBeeConverterSwitchLevel] - ZigBee attribute reports ZclAttribute [cluster=LEVEL_CONTROL, id=0, name=CurrentLevel, dataType=UNSIGNED_8_BIT_INTEGER, lastValue=254] from 0017880102E7B6B0
13-Nov-2017 21:05:03.180 [DEBUG] [binding.zigbee.converter.ZigBeeConverterColorColor] - ZigBee attribute reports ZclAttribute [cluster=LEVEL_CONTROL, id=0, name=CurrentLevel, dataType=UNSIGNED_8_BIT_INTEGER, lastValue=254] from 0017880102E7B6B0
13-Nov-2017 21:05:03.645 [DEBUG] [ding.zigbee.discovery.ZigBeeNodePropertyDiscoverer] - 0017880102E7B6B0: ZigBee node property discovery complete: {zigbee_manufacturer=Philips, zigbee_logicaltype=ROUTER, zigbee_powerlevel=FULL, zigbee_model=LTW001, zigbee_networkaddress=49237, zigbee_powersource=MAINS, zigbee_stkversion=1, zigbee_datecode=20160810, zigbee_zclversion=1, zigbee_hwversion=20, zigbee_appversion=2, zigbee_powermode=RECEIVER_ON_IDLE, zigbee_powersources=[MAINS, DISPOSABLE_BATTERY, RECHARGABLE_BATTERY]}
13-Nov-2017 21:05:03.645 [INFO ] [ab.binding.zigbee.discovery.ZigBeeDiscoveryService] - 0017880102E7B6B0: Update ZigBee device zigbee:device with bridge zigbee:coordinator_telegesis:6933de2d
13-Nov-2017 21:05:04.052 [DEBUG] [binding.zigbee.converter.ZigBeeConverterColorColor] - ZigBee attribute reports ZclAttribute [cluster=COLOR_CONTROL, id=7, name=ColorTemperature, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=366] from 0017880102E7B6B0
13-Nov-2017 21:05:04.052 [DEBUG] [g.zigbee.converter.ZigBeeConverterColorTemperature] - ZigBee attribute reports ZclAttribute [cluster=COLOR_CONTROL, id=7, name=ColorTemperature, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=366] from 0017880102E7B6B0
13-Nov-2017 21:05:04.301 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880102E7B6B0: Initializing ZigBee thing handler
13-Nov-2017 21:05:04.312 [DEBUG] [ding.zigbee.discovery.ZigBeeNodePropertyDiscoverer] - 0017880102E7B6B0: ZigBee node property discovery start
13-Nov-2017 21:05:04.312 [DEBUG] [ding.zigbee.discovery.ZigBeeNodePropertyDiscoverer] - 0017880102E7B6B0: ZigBee node property discovery using 49237/11
13-Nov-2017 21:05:06.050 [DEBUG] [ding.zigbee.discovery.ZigBeeNodePropertyDiscoverer] - 0017880102E7B6B0: ZigBee node property discovery complete: {zigbee_manufacturer=Philips, zigbee_logicaltype=ROUTER, zigbee_powerlevel=FULL, zigbee_model=LTW001, zigbee_networkaddress=49237, zigbee_powersource=MAINS, zigbee_stkversion=1, zigbee_datecode=20160810, zigbee_zclversion=1, zigbee_hwversion=20, zigbee_appversion=2, zigbee_powermode=RECEIVER_ON_IDLE, zigbee_powersources=[MAINS, DISPOSABLE_BATTERY, RECHARGABLE_BATTERY]}
–> turned openhab switch off = works
13-Nov-2017 21:05:16.771 [DEBUG] [.openhab.binding.zigbee.handler.ZigBeeThingHandler] - 0017880102E7B6B0: Command for channel zigbee:device:6933de2d:0017880102e7b6b0:0017880102E7B6B0_11_switch_onoff --> OFF
