Just installed the binding, I wanted to use it to build my own notification mechanisms, since those of evcc have some shortcomings. However one of the key channels does not seem to work, the vehicle title of the loadpoint. Is it just me, or is this broken?
Yes, it is only one word. I tried to change the code, but I am not smart enough for that. In evcc github you can find the exactly word. I lost the place for the moment.
IIRC this has already been fixed in the evcc binding in the latest version, which is however currently only available as 4.2.0 Milestone 1 or SNAPSHOT.
Until then, someone would have to cherry-pick the changes to the 4.1.x branch and build a patched 4.1.x version.
Really annoying how often evcc has breaking API changes ā¦
That will be openHAB 4.2.0, which I would expect for end of July.
I know itās a long time until then ā¦ I will eventually release a version with the backported adjustments to the marketplace until then.
currently I have trouble with the EVCCās PvPower and VehicleTitle Items in my openHAB binding: PvPower is NULL and the string is empty all time. In the given interval when all other parameter are getting set, the vehicle title is updated to empty, PvPower is not set. I am sure there was a time it worked correct. Weird is that in the EVCC UI I can see the correct vehicle title and the correct PvPower - only in the openHAB binding I canāt.
I have the same setup, also with huawei-dongle-powersensor and see the same problems. With the latest evcc version 0.125.0, both PV Power and (Home) Battery Power/SoC dissapeared from the evcc Channels, I have issues with VehicleTitle a bit longer already, but that was not that important to me that I followed up on this.
I downgraded evcc to 0.124.10, now PV Power and Battery Power/SoC is working as expected again.
Thank you Grisnir! Good to know that I am not the only one with this issue.
Vehicle Title is not working longer than PvPower, I can confirm! I do not use a battery, thatās why I cannot confirm this statement.
For me the VehicleTitle is important as well, thatās why I donāt want to downgrade (which version worked with the title?). Hope there will be a fix in an upcoming version.
I cannot find anything concerning renaming VehicleTitle in this topic (and yes I tried CTRL+F).
I switched the channel to VehicleName and now the item is NULL (instead of empty string with VehicleTitle).
In the bindings documentation, the channel is named VehicleTitle as well. May you can give me a hint?
Thanks!
