Hi there,
I thought it would be nice to have a List or Table or Matrix of how events will work together.
But I can’t do it on my own. I don’t know how all combinations should behave.
So far I searched in the forum and copied some basics
Possible triggers
Items triggered through UI/ external call:
Switch MyItem "my item name"
Switch MyItem "my item name" {autoupdate="false"}
Group:Dimmer:MAX gMyItems "group of my items"
Rules executing code
sendCommand(MyItem,ON)
sendCommand(MyItem,100)
sendCommand(MyItem,"ON")
sendCommand(gMyItems ,ON)
sendCommand(gMyItems ,100)
sendCommand(gMyItems ,"ON")
postUpdate(MyItem,ON)
postUpdate(MyItem,100)
postUpdate(MyItem,"ON")
postUpdate(gMyItems ,ON)
postUpdate(gMyItems ,100)
postUpdate(gMyItems ,"ON")
parts of rules found in the forum which will do something or not
Item MyItem changed
Item MyItem changed to ON
Item PowderRoom changed to 100
Item MyItem received command
Item MyItem received update
Item MyItem received update TRUE
Result should be something like:
Example 1
Item
switched to ON through UI
rule "my rule"
when Item MyItem changed
logInfo("my rule","something triggered me")
Rule will trigger: yes
UI will update: yes
Example 2
Item
rule "my rule"
Rule will trigger: ?
UI will update: ?
Example 3
Item
postUpdate through rule
rule "my rule"
UI will update: ?
