I have a question.
The Jablotron Alarm channel states, when trigged, the event “ALARM” or “TAMPER”.
What is the event when the firealarm goes off?
I have JA 151ST A and want to create a rule which is set off by an fire Alarm.
I have a question.
In general, it’s probably ALARM. TAMPER is usually sent when the device itself is messed with.
There is a third type of event class. Because the Smoke detector Siren can signal, with different tones, intrusion/tampering alarm or fire detection.
I don’t want trigger the smoke/heat detector and log the event, any other ideas?
So i tryed it and i think the binding needs an update.
When a fire alarm goes off the binding gives out “alarm” but the jablotron app is stating a fire alarm.
So i think there is a differentiation from jablotron between fire or intrusion alarm.
@Ondrej_Pecta can you help and check it out?
BR
Don
