I picked up an AN158 the other day, but I have a bit of difficulty configuring the metering part of it. The switch works fine. The item configuration looks like this (possibly very wrong…):
Switch swc_4 “switch4” {zwave=“23:command=switch_binary”}
Number swc_4_W “switch4 power consumption [%.1f W]” { zwave=“23:command=meter” }
How would I configure the sitemap to view the consumption and how would I store it in a db.
I’m using an AN147 … I would like to use it to switch on/off a lamp. Could you please provide me with the item entries to switch on / of AN147 wallplug …
Thx
Hi Peter,
I’m not aware of an Everspring AN-147 being in existence. Typo??
If you mean AN-148, the anwer is in the initial post (Switch swc_4 “switch4” {zwave=“23:command=switch_binary”} )
For Everspring AD-147 you better start a new topic.
its an AN147, I saw your item config … I have a problem with my item file.
This is my sitemap-file
sitemap Haus label=“Hauptmenue”
Frame {
Group item=uebFT label=“Übersicht Fenster” icon=“house”
Group item=uebPWR label=“Übersicht Steckdosen” icon=“switch”
This my item file
// Gruppen
Group uebFT // Uebersicht Zustand alle Fenster/Tuer-Sensoren)
Group uebPWR // Uebersicht Zustand alle Steckdosen)
Hi, I’m trying to set the KW / h but they do not work, Watts and Switch items work fine.
I link the Kwh to the number item but not work, has there been any changes since the date of this post?
Yep, a bit. I switched to OH2, now the AN158 is a thing, exposing it’s channels.
I’m not longer monitoring individual consumption so I do not have an items example for you
