I have various Everspring z-wave AN157 switches around my house. I bought a new one that looks identical, but it has a new model number: AN301-3
I signed up on opensmarthouse.org but I don’t have the Create Device button that’s described in the guide:
The device type of an AN157 in the database is 0004:0001,0104:0001
The device type of my new AN301-3 in OpenHab is 0060:0004:000F::1.1
This makes me think it should be a new device?
The Z-wave XML for the new Everspring AN301-3 is attached.
network_e3faa253__node_58.xml (9.0 KB)
<node>
<homeId>0xe3faa253</homeId>
<nodeId>58</nodeId>
<version>4</version>
<manufacturer>0x60</manufacturer>
<deviceId>0xf</deviceId>
<deviceType>0x4</deviceType>
<listening>true</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<sleepDelay>500</sleepDelay>
<nodeInformationFrame>
<commandClass>COMMAND_CLASS_ZWAVEPLUS_INFO</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION_GRP_INFO</commandClass>
<commandClass>COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_TRANSPORT_SERVICE</commandClass>
<commandClass>COMMAND_CLASS_VERSION</commandClass>
<commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
<commandClass>COMMAND_CLASS_DEVICE_RESET_LOCALLY</commandClass>
<commandClass>COMMAND_CLASS_POWERLEVEL</commandClass>
<commandClass>COMMAND_CLASS_SECURITY_2</commandClass>
<commandClass>COMMAND_CLASS_SUPERVISION</commandClass>
<commandClass>COMMAND_CLASS_FIRMWARE_UPDATE_MD</commandClass>
<commandClass>COMMAND_CLASS_ALARM</commandClass>
<commandClass>COMMAND_CLASS_SWITCH_BINARY</commandClass>
<commandClass>COMMAND_CLASS_CONFIGURATION</commandClass>
</nodeInformationFrame>
<associationGroups class="concurrent-hash-map">
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<maxNodes>0</maxNodes>
<associations/>
</associationGroup>
</entry>
<entry>
<int>2</int>
<associationGroup>
<index>2</index>
<associations/>
</associationGroup>
</entry>
</associationGroups>
<endpoints class="concurrent-hash-map">
<entry>
<int>0</int>
<endPoint>
<deviceClass>
<basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_SWITCH_BINARY</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_POWER_SWITCH_BINARY</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
<supportedCommandClasses class="concurrent-hash-map">
<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
<COMMAND__CLASS__NO__OPERATION>
<version>1</version>
<instances>1</instances>
<control>false</control>
<versionSupported>1</versionSupported>
</COMMAND__CLASS__NO__OPERATION>
</entry>
<entry>
<commandClass>COMMAND_CLASS_BASIC</commandClass>
<COMMAND__CLASS__BASIC>
<isGetSupported>true</isGetSupported>
</COMMAND__CLASS__BASIC>
</entry>
<entry>
<COMMAND__CLASS__SWITCH__BINARY>
</COMMAND__CLASS__SWITCH__BINARY>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION__GRP__INFO>
<autoSubscribeGroups/>
</COMMAND__CLASS__ASSOCIATION__GRP__INFO>
</entry>
<entry>
<COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</entry>
<entry>
<COMMAND__CLASS__ZWAVEPLUS__INFO>
<versionSupported>2</versionSupported>
<zwPlusVersion>1</zwPlusVersion>
<zwPlusRole>ROLE_TYPE_SLAVE_ALWAYS_ON</zwPlusRole>
<zwPlusNodeType>NODE_TYPE_ZWAVEPLUS_NODE</zwPlusNodeType>
</COMMAND__CLASS__ZWAVEPLUS__INFO>
</entry>
<entry>
<COMMAND__CLASS__CONFIGURATION>
<configParameters/>
</COMMAND__CLASS__CONFIGURATION>
</entry>
<entry>
<COMMAND__CLASS__ALARM>
<version>8</version>
<versionSupported>8</versionSupported>
<alarms>
<entry>
<alarmType>POWER_MANAGEMENT</alarmType>
<alarmState>
<reportedEvents/>
<outer-class reference="../../../.."/>
</alarmState>
</entry>
</alarms>
<v1Supported>true</v1Supported>
</COMMAND__CLASS__ALARM>
</entry>
<entry>
<COMMAND__CLASS__MANUFACTURER__SPECIFIC>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>96</deviceManufacturer>
<deviceType>4</deviceType>
<deviceId>15</deviceId>
</COMMAND__CLASS__MANUFACTURER__SPECIFIC>
</entry>
<entry>
<COMMAND__CLASS__POWERLEVEL>
<powerLevel>0</powerLevel>
<powerTimeout>0</powerTimeout>
</COMMAND__CLASS__POWERLEVEL>
</entry>
<entry>
<COMMAND__CLASS__FIRMWARE__UPDATE__MD>
<versionSupported>4</versionSupported>
</COMMAND__CLASS__FIRMWARE__UPDATE__MD>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION>
<version>2</version>
<maxGroups>2</maxGroups>
</COMMAND__CLASS__ASSOCIATION>
</entry>
<entry>
<COMMAND__CLASS__VERSION>
<versionSupported>3</versionSupported>
<libraryType>LIB_SLAVE_ENHANCED</libraryType>
<protocolVersion>6.9</protocolVersion>
<applicationVersion>1.1</applicationVersion>
<hardwareVersion>1</hardwareVersion>
</COMMAND__CLASS__VERSION>
</entry>
<entry>
<COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
<version>3</version>
</COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors>
<int>1</int>
<int>23</int>
<int>48</int>
<int>51</int>
<int>52</int>
<int>56</int>
<int>59</int>
<int>60</int>
</nodeNeighbors>
<lastReceived>2022-12-09 10:29:10.420 UTC</lastReceived>
</node>
If anyone can guide me how to add this to the database, I would be grateful thank you.
