Just use inside widget css style?
style:
padding: 0
margin: 0
style:
padding: 0
margin: 0
i use the standard oh-list-card and put my custom widget list inside the oh-list-card.
the margin comes from the oh-list-card and so i can’t apply the css style inside the widget.
i tried this (page code) but it’s not working:
blocks:
- component: oh-block
config: {}
slots:
default:
- component: oh-grid-row
config: {}
slots:
default:
- component: oh-grid-col
config: {}
slots:
default:
- component: oh-list-card
class:
style:
padding: 0
margin: 0
slots:
default:
- component: widget:rollershutter_list_widget_new
header: Eingang
item: rs_eingang
header: Büro
item: rs_buero
masonry: null
Delete “class:”
oops, sorry. deleted the “class” line but the margin is still there.
default:
style:
padding: 0
margin: 0
slots:
Let’s call for Batman. @RGroll , does oh-list-card accept css styles? Maybe a style in a parent component could help there? Maybe change oh-list-card to f7-card?
Awesome
@rlkoshak thanks for your excamples, i really like them, but i struggle to find a solution and maybe you can help.
When using the custom widget the automatic location of the item is gone (e.g Bath > Xiaomi Mijia BT HT), is there way to show this location with custom widgets as well
I ope this image explains a bit better what i mean
You can modify the custom widget code to add that to the footer I would guess. I don’t know. All these examples were written before the Equipment and Location stuff were shown as part of the widgets so that information is all included in the Item’s label for me.
thanks for the hint with the footer it is working now
when adding the “props.footer” the same way as the other field and not entering any data in it, openHAB will put the “grand-group” > “group” of the item in the footer by itself
Hello everyone,
isn’t it possible to create a custom widget from the standard “List Card” widget? But it should be so dynamic that you can add multiple widgets in the page editor like in the standard. I want to add some flex style formats in the custim widget to switch to rows or columns display.
In my experiments I can add multiple widgets in the page editor but they are removed again when saving.
Here is my construction widget:
uid: KRDListCard
tags:
- Liste
props:
parameters:
- description: A text prop
label: Prop 1
required: false
type: TEXT
parameterGroups: []
timestamp: Jul 2, 2023, 7:52:24 PM
title: Text
stylesheet: >
.2Spalten {
display: flex;
flex-direction: row;
gap: var(--f7-card-margin-vertical);
class:
- 2Spalten
style:
display: flex
flex-direction: row
slots:
- component: {}
default: []
The last lines are just trial and error.
But maybe there is a completely different solution, but I can’t find the solution.
You can only create a reusable custom widget from the Developer Tools → Widgets screen. You can define widgets inline though.
You should be able to define the whole list card with it’s custom list item widgets in one go, but you need to be aware that the List Card is just a container for List Item widgets. The List Item Widgets themselves will be defined in the slots.
