It took me a couple hours today to figure out that the scheduler in OpenHAB stopped executing jobs because one rule was dead locked. Below the short version of the rule.
If within a ReentrantLock block an exception is raised the unlock in the finally won’t be called. The exception causes to halt the jobscheduler. It took a while to understand that the rule was causing this issue, because no error was raised within the log files. Adding a catch statement did not help either.
I changed the rule, so it won’t raise an exception.
import org.openhab.core.library.types.*
import org.openhab.model.script.actions.*
import org.joda.time.*
import java.util.concurrent.locks.ReentrantLock
var java.util.concurrent.locks.ReentrantLock lock = new java.util.concurrent.locks.ReentrantLock()
rule “Rule using curl which blocks scheduler”
System started or
// Every 15 seconds
or Time cron “*/15 * * * * ?”
lock.lock()
try {
if (NonExistentItem.state == Uninitialized) {
logInfo(“Test”, “Test”)
} finally{
lock.unlock()
