Don’t really know where to report this. Should I file a bug report in the Github bug tracker? And if so, would this be related to deconz or hue binding. Actually I am not even sure if this is a bug, or just an inconvenience because of my configuration.
After upgrading my OH installation to 2.5.6 (BTW also upgraded Deconz to 2.05.78), I started getting errors like the following from a backup script I am running nightly:
file has vanished: "/var/lib/openhab2/jsondb/backup/1593735966369--org.eclipse.smarthome.config.discovery.DiscoveryResult.json"
file has vanished: "/var/lib/openhab2/jsondb/backup/1593735966878--org.eclipse.smarthome.config.discovery.DiscoveryResult.json"
When I looked into this, it turned out a new file was being written twice per second. I stopped OH and diffed two files. I have some Xiaomi Aqara motion sensors connected to deconz. They are set up in deconz to turn off some lights, without involving OH at all. Hence I have not added the Things (just left them in the inbox). The only differences in the .json-files were some timestamps in items belonging to the motion sensor rules:
"hue:0840:00212E04DEE1:27": {
"class": "org.eclipse.smarthome.config.discovery.internal.DiscoveryResultImpl",
"value": {
... CUT ...
"properties": {
"modelId": "PHOSCON_FSM_STATE",
"uniqueId": "fsm-state-1593803551911",
"sensorId": "27"
"representationProperty": "uniqueId",
"flag": "NEW",
"label": "FSM_STATE Holder Rebeccas lys tændt",
- "timestamp": 1593803606943,
+ "timestamp": 1593803607451,
"timeToLive": -1
I have removed the Phoscon Sensor Control rules, and the updates were reduced to every 10 seconds. The updates were now coming from the timestamps of Hue groups (which I have not been using in OH, they appeared after my OH upgrade). Here is a (slightly edited) diff:
"hue:group:00212E04DEE1:5224": {
"value": {
... CUT ...
"properties": {
"groupId": "5224"
"representationProperty": "groupId",
"flag": "NEW",
"label": "TRADFRI wireless dimmer 9 (LightGroup)",
- "timestamp": 1593798634926,
+ "timestamp": 1593798644951,
"timeToLive": -1
This time I tried hiding them from the inbox, but that doesn’t solve the problem, they are still in the json-file, just with a new field indicating they are hidden. So I went ahead and added all those groups as Things in OH, and the file update interval is now down to 5 minutes:
"deconz:dimmablelight:3d8ca982:90fd9ffffe2a576801": {
"value": {
... CUT ...
"properties": {
"uid": "90:fd:9f:ff:fe:2a:57:68-01",
"id": "10",
"firmwareVersion": "1.2.245",
"modelId": "TRADFRI transformer 30W",
"vendor": "IKEA of Sweden"
"representationProperty": "uid",
"flag": "NEW",
"label": "hobbyroom under shelf (IKEA of Sweden)",
- "timestamp": 1593803932892,
+ "timestamp": 1593804232889,
"timeToLive": -1
This now shows the deconz-Things (the lights are not added as Things in OH due to them also being available through the Hue binding).
Is this a bug, or working as designed? Luckily I am on a Debian box with an SSD, but even so creating a new file twice every second seems a little overwhelming. On a Raspberry Pi my guess would be that the SD-card could wear out quickly.
It seems go stop if I add all the stuff from the Inbox as Things. But is it otherwise bad to leave them in the Inbox?
For instance I have a bunch of lights set up with the Hue binding, but now also available through the Deconz-binding (which used to support only sensors). Should I migrate them all over to using the Deconz-binding and remove the Hue binding?
