Hi, with the new approach in OH2 i can’t deal with Exec binding and Network binding.
I want to use them to reboot my RPi screens. So far I’ve set up things like this:
EXEC:
These however generates warning for exec:
[WARN ] [home.core.thing.binding.ThingFactory] - Could not create channel ‘run’ for thing type ‘exec:command:piAntre_reboot’, because channel type ‘exec:running’ could not be found.
and ERROR for network:
[ERROR] [nding.network.service.NetworkService] - Cannot use DHCP listen: Permission denied (Bind failed)
I’d like to have switch showing status of remote Pi screen as online (ON) and when by switchnig it OFF Pi will reboot.
Unfortunately I can’t help with the exec binding problem. But I wonder what your Item definition is. Per the documents there isn’t a “running” channel. Did you mean to use the “run” channel?
In terms of NETWORK binding, I’ve set up permissions following Rich guideline and now I get:
[ERROR] [rvice.dhcp.ReceiveDHCPRequestPackets] - DHCPREQUEST field is missing
but the thing itself seems to work fine so the switch is ‘ON’ when the thing is online.
Switch is configured as follows:
But I get this when turn the switch:
[INFO ] [ome.core.thing.internal.ThingManager] - Not delegating update ‘ON’ for item ‘Network_piAntre_reboot’ to handler for channel ‘exec:command:piAntre_reboot:run’, because thing is not initialized (must be in status ONLINE or OFFLINE).
Now I need to run Network_piAntre_reboot by turning switch ‘OFF’ and have the switch as ‘ON’ based on the network:device:piAntre status.
Something to deal with the channels i guess but how to link these 2 things?
