- Platform information:
- Hardware: Raspberry Pi 3
- OS: Raspbian GNU/Linux 9
- Java Runtime Environment: openjdk version “1.8.0_152”
- openHAB version: 2.4.0 Release Build
- Issue of the topic:
I created a script to wake my PC using Wake on LAN and suspend it (hibernate).
When I execute the script from the command line everything works fine, passing “on” as a parameter turns the PC on, passing “off” as a parameter turns the PC off, and passing “status” as a parameter correctly displays the status of the PC (off for a while, while booting up, on when done)
However when I create a Thing with the exec binding only the “on” and “status” part work. I directed some log messages to a file in the “off” section and they are appended to the file correctly, but the hibernate command does not seem to come through.
here is the script:
#!/bin/bash
MAC_ADDRESS="XX:XX:XX:XX:XX:XX"
IP_ADDRESS="XXX.XXX.XXX.XXX"
USERNAME='user'
PASSWORD='password'
case "${1}" in
[oO][nN])
exec sudo etherwake $MAC_ADDRESS &> /dev/null
[oO][fF][fF])
date >> /var/log/pascal.log
echo "PC off " >> /var/log/pascal.log
whoami >> /var/log/pascal.log
echo "timeout 3 sshpass -p $PASSWORD ssh $USERNAME@$IP_ADDRESS shutdown /h " >> /var/log/pascal.log
echo "$PATH" >> /var/log/pascal.log
echo "" >> /var/log/pascal.log
exec timeout 3 sshpass -p $PASSWORD ssh $USERNAME@$IP_ADDRESS shutdown /h &>/dev/null
[sS][tT][aA][tT][uU][sS])
timeout 1 ping -c 1 -n $IP_ADDRESS &>/dev/null
if [ $? -eq 0 ]; then
echo "ON"
exit 0
else
echo "OFF"
exit 1
fi
echo
echo "Usage: pascals_pc <on|off|status>"
echo
exit 1
esac
exit 0
I placed it in /usr/local/bin/
and added ALL ALL=NOPASSWD: /usr/sbin/etherwake
to my sudoers file using visudo
Please post configurations (if applicable):
Things configuration related to the issue
Thing exec:command:pascals_pc "Pascals PC Control" [ command="/usr/local/bin/pascals_pc %2$s", interval=0, timeout=10, autorun=true ] Thing exec:command:pascals_pc_status "Pascals PC Status" [ command="/usr/local/bin/pascals_pc status", interval=20, timeout=5 ]
Items configuration related to the issue
String network_device_pascals_pc_control "Pascals PC Control" { channel="exec:command:pascals_pc:input", channel="exec:command:pascals_pc_status:output", autoupdate="false" } String network_device_pascals_pc_status "Pascals PC Status" { channel="exec:command:pascals_pc_status:output" } Switch network_device_pascals_pc_switch "Pascals PC" ["Switchable"]
Sitemap configuration related to the issue
sitemap test label="My home automation" { Frame label="Test Frame" { Switch item=network_device_pascals_pc_switch } }
Rules code related to the issue
rule "Pascals PC Switch" when Item network_device_pascals_pc_switch changed then logInfo("Network", "Switching Pascals PC " + network_device_pascals_pc_switch.state.toString + ": " + network_device_pascals_pc_control.state.toString) network_device_pascals_pc_status.postUpdate(network_device_pascals_pc_switch.state.toString) network_device_pascals_pc_control.sendCommand(network_device_pascals_pc_switch.state.toString) end rule "Pascals PC State" when Item network_device_pascals_pc_status changed then logInfo("Network", "Switching Pascals PC " + network_device_pascals_pc_status.state.toString + ": " + network_device_pascals_pc_control.state.toString) network_device_pascals_pc_switch.postUpdate(network_device_pascals_pc_status.state.toString) end
If logs where generated please post these here using code fences:
None besides the output from the rule
