when i run this on windows run i am able to run with no issues, also most of the other exec commands are still working , i am getting below error from OH logs
22:32:34.248 [ESH-thingHandler-72] ERROR org.openhab.binding.exec.handler.ExecHandler - An exception occurred while executing 'c:\Program Files (x86)\Google\Chrome\Application\chrome.exe https://www.youtube.com/watch?v=U9BwWKXjVaI' : 'Cannot run program "c:\Program": CreateProcess error=2, The system cannot find the file specified'
Opens or Prints a filename according to the definition of the file extension in the Registry. For example: a filename with .doc extension will be opened with MS-Word, a filename with .html extension will be opened with your default browser. If you specify a valid web site address, the Web site will be opened in your default browser. the [operation] parameter can be “open” or “print”.
Examples:
shexec “open” “c:\my documents\abc.doc”
shexec “print” “d:\files\1.pdf”
shexec “open” “http://www.nirsoft.net”
so it will look like this in the thing def
nircmd.exe shexec “open” “http://www.nirsoft.net”
i did this also not sure i got the DOC right
is this looks ok? still not wokring
c:\Program@@Files@@(x86)\Google\Chrome\Application\chrome.exe@@https://www.youtube.com/watch?v=U9BwWKXjVaI
