I’m running OH2. I have this item, that execute a script every hour:
String ROUTER_SPEEDRESULT "Risultato Test Velocità[%s]" { exec="<[/etc/openhab2/myscript/speed_test.sh:3600000:REGEX((.*))]"}
Sometime, I need to disable this item, and script do not be executed. I would like to setup another Switch Item to toggle execution on and off, but I have no idea on how to make it work as I expect.
It is possible to perform this?
I don’t think you should define your item with an exec binding if you want to enable/disable the execution of the script!
Best thing to do is using a rule that describes the usage of such an action far more better than a binding linked to an item!
rule "Periodically execute a script"
Time cron "0 0 * * * ?"
if(MySwitch.state == ON) {
val String results = executeCommandLine("/etc/openhab2/myscript/speed_test.sh", 300000) // wait up to five minutes
ROUTER_SPEEDRESULT.postUpdate(results)
