wu3mi
(Christoph Wurm)
#1
i am trying to write a rule to take a picture from my doorphone by motion.
Unfortunately it don’t work with this commands:
rule "take pic on motion"
Item OA_Gateway_MotionTest received update
val url = "http://192.168.0.58:8080/picture.jpg"
val outputFile = "/home/user/Downloads/" + now.toString.replaceAll("[:\\/ ]+", "_") + ".jpg"
var cmd = "curl -m 10 -o " + outputFile + " " + url
executeCommandLine(cmd)
logInfo("MotionRule", cmd)
}end
The Log writes the right command (checked on commandLine itself)
Is there any hint with executeCommandLine with curl?
best regards
wu3mi
rossko57
(Rossko57)
#2
val results = executeCommandLine(cmd)
logInfo("MotionRule", cmd + results)
It’s often a permissions issue
Wolfgang_S
(Wolfgang_S)
#3
Check the permission of the directory /home/user/Downloads/. E.g. with the command
ls -ld /home/user/Downloads
Is it writeable for the user that is owning the process openhab software is running under ( user openhab ) ?
wu3mi
(Christoph Wurm)
#4
thx for the fast reply …
It works now with the hint from @rossko57
The permissions issue was my first idea, tbh, i don’t know , why rosskos57’s hint works …
but thanks to you
regards
wu3mi
rossko57
(Rossko57)
#5
It’s not a fix, just reports error messages that you might not have seen.
You’v done something else to “fix” it.
system
(system)
closed
#6
