In a rule I try to use executecommandline, but the executable is not launched.
My Openhab version is 3.1.1 on a windows server 2016 inside a VM.
Openhab is launch manually ( not as a service )
I use Voicecommand which work perfectly, here is the rule :
rule "Light Control"
when Item VoiceCommand received command then
var String command = VoiceCommand.state.toString.toLowerCase
logInfo("Voice.Rec","VoiceCommand received "+command)
if (command.contains("allumer") ){
if (command.contains("sapin")) {
sendHttpGetRequest("http://192.168.1.136/cm?cmnd=Power%20On")
if (command.contains("guirlande")) {
sendHttpGetRequest("http://192.168.1.134/cm?cmnd=Power%20On")
if (command.contains("laser")) {
sendHttpGetRequest("http://192.168.1.133/cm?cmnd=Power%20On")
if (command.contains("dehors")) {
sendHttpGetRequest("http://192.168.1.132/cm?cmnd=Power%20On")
if (command.contains("éteindre") ){
sendHttpGetRequest("http://192.168.1.136/cm?cmnd=Power%20Off")
sendHttpGetRequest("http://192.168.1.134/cm?cmnd=Power%20Off")
sendHttpGetRequest("http://192.168.1.133/cm?cmnd=Power%20Off")
sendHttpGetRequest("http://192.168.1.132/cm?cmnd=Power%20Off")
if (command.contains("canal") ){
val results=executeCommandLine(Duration.ofSeconds(5),"c:\\openhab2\\flop\\controle.exe")
logInfo("test",results)
controle.exe is not launched, I don’t know why. ( word canal is detected, i try to put the executecommandline at the strart of the script, it is not working )
In the log I have that : 2021-12-18 16:28:37.902 [INFO ] [org.openhab.core.model.script.test ] -
Any ideas ?
Thanks in advance.
