I’m trying to put together a setup to control a wifi enabled thermostat and I’m using the base code from this post with a few minor modifications.
Part of it is a python script that is executed from a rule. I have all the scripts saved in /etc/openhab2/scripts, all the scripts are executable, I gave the openhab user ownership of the scripts, and I even went so far as to give open 777 permissions on the files. The openhab user is also part of the sudo group. I think, at the very least, the permission side of things is taken care of.
There are 2 main scripts; ‘therm.py’ which performs the actual communications with the server and ‘tstat’ which calls on therm.py to pull information from the server and update the OH items. I know the script works as for as communicating with the server and making the appropriate changes because I can manually run the scripts from a terminal and everything works. It will change the temperature set point, switch between cool and heat, cancel holds, etc. The script will also return a result to let me know that it was successful or if it failed. However, when I attempt to execute the python script via a Rule, the logs show me that it executed the script but it does not show any return information and nothing changes on the server. To make things more confusing, I can call on the ‘tstat’ script from a rule to pull the information from the server and it runs correctly, returns the values, and updates the items without a problem. It is only when I call the python script directly by itself that it doesn’t work.
Any insight into what I might be missing? Would it be easier just to create a bash script to call the python script like the ‘tstat’ script?
Items
Number ACMode "A/C System Mode [MAP(acstatus.map)]"
Number ACInsideTemp "Inside Temp [%.0f °F]" <temperature> (persist)
Number ACCoolSetPoint "Cool Set Point [%.0f °F]" (persist)
Number ACHeatSetPoint "Heat Set Point [%.0f °F]" (persist)
Number ACSetPoint "Set Temp [%.0f °F]" (persist)
Number ACHoldTime "Hold Until [MAP(holdtime.map):%s]"
Number ACCoolHoldStatus "[MAP(achold.map):%s]"
Number ACHeatHoldStatus "[MAP(achold.map):%s]"
Switch ACCancelHold "Cancel Hold"
Rules
// Send Setpoint
rule "Send SetPoint to MyTotalConnectComfort Portal"
Item ACSetPoint received command
if ( ACMode.state==3) {
executeCommandLine("python /etc/openhab2/scripts/therm.py -c " + receivedCommand)
else
executeCommandLine("sudo /etc/openhab2/scripts/therm.py -h " + receivedCommand)
//Update thermostat after update is sent
rule "Sync after update"
Thread::sleep(10000)
executeCommandLine("/etc/openhab2/scripts/tstat")
tstat File
#!/bin/bash
# Script by Jamie R. Cid
# jay@cidcomm.com
#Get data from MyTotalControl and send to OH. This grabs one copy of the data and stores it instead of doing it for every request below. That's how you get blocked ;)
echo Getting Data from MyTotalControl Website
/etc/openhab2/scripts/therm.py -s > /var/log/honeywell.log
TEMPDATA="/var/log/honeywell.log"
echo Checking AC Mode
MODESTATUS=$( grep "System Mode" $TEMPDATA | sed -n -e 's/^.*System Mode: //p')
curl --header "Content-Type: text/plain" -X POST "http://192.168.0.8:8080/rest/items/ACMode" -d "$MODESTATUS"
echo $MODESTATUS
echo Checking Indoor Temp
TEMPSTATUS=$( grep "Indoor Temperature" $TEMPDATA | sed -n -e 's/^.*Indoor Temperature: //p')
curl --header "Content-Type: text/plain" -X POST "http://192.168.0.8:8080/rest/items/ACInsideTemp" -d "$TEMPSTATUS"
echo $TEMPSTATUS
echo Checking Cool Setpoint
COOLSTATUS=$( grep "Cool Setpoint" $TEMPDATA | sed -n -e 's/^.*Cool Setpoint: //p')
curl --header "Content-Type: text/plain" -X POST "http://192.168.0.8:8080/rest/items/ACCoolSetPoint" -d "$COOLSTATUS"
echo $COOLSTATUS
echo Checking Heat Setpoint
HEATSTATUS=$( grep "Heat Setpoint" $TEMPDATA | sed -n -e 's/^.*Heat Setpoint: //p')
curl --header "Content-Type: text/plain" -X POST "http://192.168.0.8:8080/rest/items/ACHeatSetPoint" -d "$HEATSTATUS"
echo $HEATSTATUS
echo Checking Cool Hold Status
COOLHOLDSTATUS=$( grep "Status Cool" $TEMPDATA | sed -n -e 's/^.*Status Cool: //p')
curl --header "Content-Type: text/plain" -X POST "http://192.168.0.8:8080/rest/items/ACCoolHoldStatus" -d "$COOLHOLDSTATUS"
echo $COOLHOLDSTATUS
echo Checking Heat Hold Status
HEATHOLDSTATUS=$( grep "Status Heat" $TEMPDATA | sed -n -e 's/^.*Status Heat: //p')
curl --header "Content-Type: text/plain" -X POST "http://192.168.0.8:8080/rest/items/ACHeatHoldStatus" -d "$HEATHOLDSTATUS"
echo $HEATHOLDSTATUS
echo Checking Hold Time
HEATHOLDSTATUS=$( grep "Hold Until" $TEMPDATA | sed -n -e 's/^.*Hold Until : //p')
curl --header "Content-Type: text/plain" -X POST "http://192.168.0.8:8080/rest/items/ACHoldTime" -d "$HEATHOLDSTATUS"
echo Syncing Temperature Setpoint
MODECHECK=$( grep "System Mode" $TEMPDATA | sed -n -e 's/^.*System Mode: //p')
echo $MODECHECK
if [ "$MODECHECK" = "3" ];
curl --header "Content-Type: text/plain" -X PUT "http://192.168.0.8:8080/rest/items/ACSetPoint/state" -d "$COOLSTATUS"
else
curl --header "Content-Type: text/plain" -X PUT "http://192.168.0.8:8080/rest/items/ACSetPoint/state" -d "$HEATSTATUS"
fi
exit 0
therm.py
#!/usr/bin/python
# By Brad Goodman
# http://www.bradgoodman.com/
# brad@bradgoodman.com
####################### Fill in settings below #######################
USERNAME="my user name"
PASSWORD="my pass"
DEVICE_ID=my device ID
############################ End settings ############################
import urllib2
import urllib
import json
import datetime
import re
import time
import math
import base64
import time
import httplib
import sys
import getopt
import os
import stat
import subprocess
import string
AUTH="https://mytotalconnectcomfort.com/portal"
cookiere=re.compile('\s*([^=]+)\s*=\s*([^;]*)\s*')
def client_cookies(cookiestr,container):
if not container: container={}
toks=re.split(';|,',cookiestr)
for t in toks:
k=None
v=None
m=cookiere.search(t)
if m:
k=m.group(1)
v=m.group(2)
if (k in ['path','Path','HttpOnly']):
k=None
v=None
if k:
#print k,v
container[k]=v
return container
def export_cookiejar(jar):
s=""
for x in jar:
s+='%s=%s;' % (x,jar[x])
return s
def get_login(action, value=None):
cookiejar=None
#print
#print
#print "Run at ",datetime.datetime.now()
headers={"Content-Type":"application/x-www-form-urlencoded",
"Accept":"text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8",
"Accept-Encoding":"sdch",
"Host":"mytotalconnectcomfort.com",
"DNT":"1",
"Origin":"https://mytotalconnectcomfort.com/portal",
"User-Agent":"Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/28.0.1500.95 Safari/537.36"
conn = httplib.HTTPSConnection("mytotalconnectcomfort.com")
conn.request("GET", "/portal/",None,headers)
r0 = conn.getresponse()
#print r0.status, r0.reason
for x in r0.getheaders():
(n,v) = x
#print "R0 HEADER",n,v
if (n.lower() == "set-cookie"):
cookiejar=client_cookies(v,cookiejar)
#cookiejar = r0.getheader("Set-Cookie")
location = r0.getheader("Location")
retries=5
params=urllib.urlencode({"timeOffset":"240",
"UserName":USERNAME,
"Password":PASSWORD,
"RememberMe":"false"})
#print params
newcookie=export_cookiejar(cookiejar)
#print "Cookiejar now",newcookie
"DNT":"1",
"Origin":"https://mytotalconnectcomfort.com/portal/",
"Cookie":newcookie,
conn.request("POST", "/portal/",params,headers)
r1 = conn.getresponse()
#print r1.status, r1.reason
for x in r1.getheaders():
(n,v) = x
#print "GOT2 HEADER",n,v
#print "Cookiejar now",cookie
location = r1.getheader("Location")
if ((location == None) or (r1.status != 302)):
#raise BaseException("Login fail" )
print("ErrorNever got redirect on initial login status={0} {1}".format(r1.status,r1.reason))
return
# Skip second query - just go directly to our device_id, rather than letting it
# redirect us to it.
code=str(DEVICE_ID)
t = datetime.datetime.now()
utc_seconds = (time.mktime(t.timetuple()))
utc_seconds = int(utc_seconds*1000)
#print "Code ",code
location="/portal/Device/CheckDataSession/"+code+"?_="+str(utc_seconds)
#print "THIRD"
headers={
"Accept":"*/*",
"DNT":"1",
#"Accept-Encoding":"gzip,deflate,sdch",
"Accept-Encoding":"plain",
"Cache-Control":"max-age=0",
"Accept-Language":"en-US,en,q=0.8",
"Connection":"keep-alive",
"Referer":"https://mytotalconnectcomfort.com/portal/",
"X-Requested-With":"XMLHttpRequest",
"User-Agent":"Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/28.0.1500.95 Safari/537.36",
"Cookie":cookie
conn.set_debuglevel(999);
#print "LOCATION R3 is",location
conn.request("GET", location,None,headers)
r3 = conn.getresponse()
if (r3.status != 200):
print("Error Didn't get 200 status on R3 status={0} {1}".format(r3.status,r3.reason))
return
# Print thermostat information returned
if (action == "status"):
print r3.status, r3.reason
rawdata=r3.read()
j = json.loads(rawdata)
#print "R3 Dump"
#print json.dumps(j,indent=2)
#print json.dumps(j,sort_keys=True,indent=4, separators=(',', ': '))
#print "Success:",j['success']
#print "Live",j['deviceLive']
print "System Mode:",j['latestData']['uiData']["SystemSwitchPosition"]
print "Indoor Temperature:",j['latestData']['uiData']["DispTemperature"]
print "Indoor Humidity:",j['latestData']['uiData']["IndoorHumidity"]
print "Cool Setpoint:",j['latestData']['uiData']["CoolSetpoint"]
print "Heat Setpoint:",j['latestData']['uiData']["HeatSetpoint"]
print "Hold Until :",j['latestData']['uiData']["TemporaryHoldUntilTime"]
print "Status Cool:",j['latestData']['uiData']["StatusCool"]
print "Status Heat:",j['latestData']['uiData']["StatusHeat"]
print "Status Fan:",j['latestData']['fanData']["fanMode"]
return
headers={
"Accept":'application/json; q=0.01',
"DNT":"1",
'Content-Type':'application/json; charset=UTF-8',
'Referer':"/TotalConnectComfort/Device/CheckDataSession/"+code,
"Cookie":cookie
# Data structure with data we will send back
payload = {
"CoolNextPeriod": None,
"CoolSetpoint": None,
"DeviceID": DEVICE_ID,
"FanMode": None,
"HeatNextPeriod": None,
"HeatSetpoint": None,
"StatusCool": 0,
"StatusHeat": 0,
"SystemSwitch": None
# Calculate the hold time for cooling/heating
# t = datetime.datetime.now();
# stop_time = ((t.hour+hold_time)%24) * 60 + t.minute
# stop_time = stop_time/15
# Modify payload based on user input
if (action == "cool"):
payload["CoolSetpoint"] = value
payload["StatusCool"] = 1
payload["StatusHeat"] = 1
payload["CoolNextPeriod"] = 99
if (action == "heat"):
payload["HeatSetpoint"] = value
payload["HeatNextPeriod"] = 'null'
if (action == "cancel"):
payload["StatusCool"] = 0
payload["StatusHeat"] = 0
if (action == "fan"):
payload["FanMode"] = value
# Prep and send payload
location="/portal/Device/SubmitControlScreenChanges"
rawj=json.dumps(payload)
conn = httplib.HTTPSConnection("mytotalconnectcomfort.com");
#print "R4 will send"
#print rawj
conn.request("POST", location,rawj,headers)
r4 = conn.getresponse()
if (r4.status != 200):
print("Error Didn't get 200 status on R4 status={0} {1}".format(r4.status,r4.reason))
return
else:
print "Success in configuring thermostat!"
# print "R4 got 200"
def printUsage():
print
print "Cooling: -c temperature -t hold_time"
print "Heating: -h temperature -t hold_time"
print "Status: -s"
print "Cancel: -x"
print "Fan: -f [0=auto|1=on]"
print
print "Example: Set temperature to cool to 80f for 1 hour: \n\t therm.py -c 80 -t 1"
print
print "If no -t hold_time is provided, it will default to one hour from command time."
print
def main():
if sys.argv[1] == "-s":
get_login("status")
sys.exit()
if sys.argv[1] == "-x":
get_login("cancel")
sys.exit()
if (len(sys.argv) < 3) or (sys.argv[1] == "-help"):
printUsage()
sys.exit()
if sys.argv[1] == "-c":
get_login("cool", sys.argv[2])
sys.exit()
if sys.argv[1] == "-h":
get_login("heat", sys.argv[2])
sys.exit()
if sys.argv[1] == "-f":
get_login("fan", sys.argv[2])
sys.exit()
if __name__ == "__main__":
import urllib2
import urllib
import json
import datetime
import re
import time
import math
import base64
import time
import httplib
import sys
import getopt
import os
import stat
import subprocess
import string
for t in toks:
k=None
v=None
if m:
k=m.group(1)
v=m.group(2)
k=None
v=None
if k:
#print k,v
container[k]=v
return container
s=""
for x in jar:
return s
def get_login(action, value=None, hold_time=0):
cookiejar=None
#print
#print
"DNT":"1",
(n,v) = x
retries=5
#print params
"DNT":"1",
"Cookie":newcookie,
(n,v) = x
return
code=str(DEVICE_ID)
#print "Code ",code
#print "THIRD"
headers={
"Accept":"*/*",
"DNT":"1",
"Cookie":cookie
#conn.set_debuglevel(999);
return
rawdata=r3.read()
#print "R3 Dump"
return
headers={
"DNT":"1",
"Cookie":cookie
payload = {
"FanMode": None,
"StatusCool": 0,
"StatusHeat": 0,
#t = datetime.datetime.now();
#stop_time = ((t.hour+hold_time)%24) * 60 + t.minute
#stop_time = stop_time/15
payload["CoolNextPeriod"] = 'null'
#print rawj
return
else:
def printUsage():
print
print "Status: -s"
print "Cancel: -x"
print
print
print
def main():
get_login("status")
sys.exit()
get_login("cancel")
sys.exit()
printUsage()
sys.exit()
sys.exit()
sys.exit()
sys.exit()
main()
- Platform information:
- Hardware: Intel Atom x64 1.46GHz, 2G RAM, 64Gb SSD
- OS: Ubuntu 18.04
- Java Runtime Environment: OpenJDK Runtime Environment (Zulu 8.36.0.1-CA-linux64) (build 1.8.0_202-b05)
- openHAB version: 2.4 release build
