Hello Community,
I’m trying to run a script (script.sh) that will add, to an already created text file, a line with the current date. This script should be executed every time a switch item changes state. To do that I created a rule. I already gave all users the right to execute the script with chmod, and i can execute the script from a shell with the following command:
sudo -u openhab script.sh
rights:
script.sh:
#!/bin/bash
current_time=$(date "+%Y.%m.%d-%H.%M.%S")
echo $current_time >> t.txt
rules:
var results
rule "Create Timestamp"
Item FF_CF_CONTROL changed
if (FF_CF_CONTROL.state == ON)
results = executeCommandLine("/home/bob/Desktop/script.sh")
else
logInfo("test", "exec result " + results)
I am getting this error when i change the state of the item “FF_CF_CONTROL”:
17:11:00.512 [WARN ] [org.openhab.core.io.net.exec.ExecUtil] - Error occurred when executing commandLine '[/home/bob/Desktop/script.sh]'
java.io.IOException: Cannot run program "/home/bob/Desktop/script.sh": error=13, Permission denied
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1128) ~[?:?]
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1071) ~[?:?]
at org.openhab.core.io.net.exec.ExecUtil.executeCommandLine(ExecUtil.java:59) ~[?:?]
at org.openhab.core.model.script.actions.Exec.executeCommandLine(Exec.java:40) ~[?:?]
at jdk.internal.reflect.GeneratedMethodAccessor76.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1192) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1167) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1153) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:1098) ~[?:?]
at org.openhab.core.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:1008) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:971) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:247) ~[?:?]
at org.openhab.core.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:227) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:1318) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:239) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:488) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:267) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:475) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:251) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:213) ~[?:?]
at org.openhab.core.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:80) ~[?:?]
at org.openhab.core.model.script.runtime.internal.engine.DSLScriptEngine.eval(DSLScriptEngine.java:131) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.lambda$0(ScriptActionHandler.java:62) ~[?:?]
at java.util.Optional.ifPresent(Optional.java:183) [?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.execute(ScriptActionHandler.java:59) [bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1180) [bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.runRule(RuleEngineImpl.java:988) [bundleFile:?]
at org.openhab.core.automation.internal.TriggerHandlerCallbackImpl$TriggerData.run(TriggerHandlerCallbackImpl.java:89) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Caused by: java.io.IOException: error=13, Permission denied
at java.lang.ProcessImpl.forkAndExec(Native Method) ~[?:?]
at java.lang.ProcessImpl.<init>(ProcessImpl.java:340) ~[?:?]
at java.lang.ProcessImpl.start(ProcessImpl.java:271) ~[?:?]
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1107) ~[?:?]
... 43 more
17:11:00.598 [INFO ] [org.openhab.core.model.script.test ] - exec result null
Any clue?
Thank you.
Bernardo
