Executing Startup Tasks - km200_1?
I just updated my openhab project and executed the “Perform Setup Tasks…”. However it’s failing with the following and I can’t seem to figure out where it’s getting “km200_1” - any ideas?
    Importing project org.openhab.binding.km200_1
    ERROR: org.eclipse.oomph.resources code=0 org.eclipse.core.internal.resources.ResourceException: Invalid project description.
    org.eclipse.oomph.resources.backend.BackendException: org.eclipse.core.internal.resources.ResourceException: Invalid project description.
      at org.eclipse.oomph.resources.backend.BackendContainer.importIntoWorkspace(BackendContainer.java:158)
      at org.eclipse.oomph.setup.projects.impl.ProjectsImportTaskImpl$1.run(ProjectsImportTaskImpl.java:384)
      at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2240)
      at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2262)
      at org.eclipse.oomph.setup.projects.impl.ProjectsImportTaskImpl.importProjects(ProjectsImportTaskImpl.java:372)
      at org.eclipse.oomph.setup.projects.impl.ProjectsImportTaskImpl.perform(ProjectsImportTaskImpl.java:295)
      at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3305)
      at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.access$1(SetupTaskPerformer.java:3248)
      at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil$1.run(SetupTaskPerformer.java:4469)
      at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2267)
      at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.performNeededSetupTasks(SetupTaskPerformer.java:4463)
      at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.access$0(SetupTaskPerformer.java:4461)
      at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:3239)
      at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:3214)
      at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:3114)
      at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:556)
      at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:682)
      at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
I ended up solving this - turns that my openhab1-addons project had an existing reference to “org.openhab.binding.km200” project. However - there was a commit that occurred ~28 days ago than changed the name of the project (in the .project file) to “org.openhab.binding.km200_1”. When the setup task tried to import it - it saw that “org.openhab.binding.km200” pointed to the same resource as “org.openhab.binding.km200_1” and choked on it with the above. Once I removed the km200 project from the workspace - the import worked fine (the project is now named km200_1.
