Experience with fritz!dect 200?
fritzaha
Tags: #<Tag:0x00007fae02a14188>
(Matt Hias) #1
Dear all,
I want to monitor my wasching machine using a fritz!dect 200 power plug. Basically it’s working, But as the power is not just going to zero, when the machine finished, I’ve got some trouble with too many notifications.
The following is my rules files (sorry for the ugly coding;-):
var  boolean vvWaschmaschineAn = false
rule "Waschmachinenerkennung"
	Item Waschmaschine_Verbrauch changed   // Sobald der Verbrauch sich ändert
	logInfo("RULE", "--> Rule: Waschmaschinenerkennung hat gegriffen")
	var double wv=(Waschmaschine_Verbrauch.state as DecimalType).doubleValue
//		logInfo("WV:", wv.toString())
	if(wv > 5){
		if (vvWaschmaschineAn == false){
					logInfo("RULE", "AN: 1 x warten")
					Thread::sleep(60000) // 60000 Warte eine Minute
					if(wv >5){
						logInfo("RULE", "AN: 2 x warten")
						Thread::sleep(6000) // 60000 Warte eine Minute
						if(wv >5){
							logInfo("RULE", "AN: 3 x warten")
							if(wv >5){
									vvWaschmaschineAn = true
									postUpdate(vWaschmaschineAn, ON)
									logInfo("RULE", "--> Waschmachine an ON")
									setMasterVolume(new PercentType(50))
								//	say("Hallo. Die Waschmaschine läuft")
if(wv < 5){
	//if(wv < 1 && vWaschmaschineAn == ON){
	if (vvWaschmaschineAn == true){
					logInfo("RULE", "AUS: 1 x warten")
					if(wv < 5){
						if(wv < 5){
							logInfo("RULE", "AUS: 2 x warten")
							if(wv < 5){
									postUpdate(vWaschmaschineAn, OFF)
									logInfo("RULE", "--> Waschmachine an OFF")
								//	say("Hallo. Die Wäsche ist fertisch.")
The power chart looks like:
Cheers
Matthias
(SiHui) #2
(Matt Hias) #3
Hi sihui,
that is exaclty what I was looking for. I went through the tutorial and adjusted my rules accordingly…let’s wait and see, how to adjust to my machine.
Thanks a lot.
BR
Matthias
(Dennis) #4
Hi Matt_Hias,
have you finish your code?
I also have the Frits Dect 200 and would like to monitor my washing machine.
Maybe you could publish your final code as a tutorial.
Thanks a lot.
Dennis
(Matt Hias) #5
Hi Dennis,
no, I din’t finish that one, finally I gave up. It was not difficult to monitor the washing machines energy consumption. But the trigger points, that I identified when my washing maschine = ON/OFF, were not really reliable. I think this really depends on your individual washing maschine and the different programs, it can run.
Best Regards
Matthias
(Christoph Weitkamp) #6
Hi Dennis,
here is my complete setup - requirements: avmfritz binding, map transformation, rrd4j persistence. It’s based on the tutorial above and as @Matt_Hias already mentioned the challenge is to find the right values for your washing machine. I removed the calculation of the costs and the CO2 emissions in the report. Ping me if you are interested.
fritz.items
Number fritzWashingMachineDECT200Power "Aktuelle Leistung [%.2f W]" <energy> { channel="avmfritz:FRITZ_DECT_200:192_168_XXX_XXX:AAAAAAAAAA:power" }
Number fritzWashingMachineDECT200Energy "Gesamtverbrauch [%.3f kWh]" <energy> { channel="avmfritz:FRITZ_DECT_200:192_168_XXX_XXX:AAAAAAAAAA:energy" }
household.items
Number householdWashingMachineState "Aktueller Status [MAP(household-de.map):%s]" <washingmachine_2>
DateTime householdWashingMachineLastChange "Letzte Änderung [%1$tA, %1$td.%1$tm.%1$tY %1$tH:%1$tM:%1$tS Uhr]" <time>
household.rules
val STATE_OFF = 0
val STATE_STANDBY = 3
val STATE_ACTIVE = 2
val STATE_FINISHED = 1
rule "FRITZ!Box - fritzWashingMachineDECT200Power changed"
    Item fritzWashingMachineDECT200Power changed
    // Washing Machine State Machine
    if( fritzWashingMachineDECT200Power.state < 0.2 ) householdWashingMachineState.sendCommand(STATE_OFF)
    else if( fritzWashingMachineDECT200Power.state > 11.0 ) householdWashingMachineState.sendCommand(STATE_ACTIVE)
    else if( fritzWashingMachineDECT200Power.averageSince(now.minusMinutes(2), "rrd4j") > 5.0 ) {
        if( householdWashingMachineState.state == STATE_OFF ) householdWashingMachineState.sendCommand(STATE_STANDBY)
    } else {
        if( householdWashingMachineState.state == STATE_ACTIVE ) householdWashingMachineState.sendCommand(STATE_FINISHED)
rule "Household - householdWashingMachineState changed"
    Item householdWashingMachineState changed
    val thisChange = new DateTimeType()
    // create report if washing machine is finished
    if( householdWashingMachineState.state == STATE_FINISHED ) {
        // get last change
        val lastChange = householdWashingMachineLastChange.state
        val startTime = new DateTime(lastChange.toString)
        val endTime = new DateTime(thisChange.toString)
        // calculate running time
        val seconds = (endTime.millis - startTime.millis) / 1000
        val totalMinutes = seconds / 60
        val remainderSeconds = seconds % 60
        val totalHours = totalMinutes / 60
        val remainderMinutes = totalMinutes % 60
        // get energy consumption
        var Number diffEnergy = fritzWashingMachineDECT200Energy.deltaSince(startTime, "rrd4j")
        // deltaSince returns null value if some data is missing in persistence
        if( diffEnergy === NULL ) {
            val avgPower = fritzWashingMachineDECT200Energy.averageSince(startTime, "rrd4j")
            diffEnergy = avgPower * 0.024// 24 / 1000 = 0.024
        val message = "Waschmaschine ist fertig.\n\n" +
                      "Aktueller Status: " + householdWashingMachineState.state.toString + " (" + transform("MAP", "household-de.map", householdWashingMachineState.state.toString) + ")\n" +
                      "Start: " + lastChange.format("%1$tA, %1$td.%1$tm.%1$tY %1$tH:%1$tM:%1$tS Uhr") + "\n" +
                      "Ende: " + thisChange.format("%1$tA, %1$td.%1$tm.%1$tY %1$tH:%1$tM:%1$tS Uhr") + "\n" +
                      "Laufzeit: " + String::format("%02d", totalHours) + "h " + String::format("%02d", remainderMinutes) + "m " + String::format("%02d", remainderSeconds) + "s\n" +
                      "Verbrauch: " + String::format("%.3f", diffEnergy.floatValue) + " kWh\n"
        // send notification message
        // TODO
    // remember this change
    householdWashingMachineLastChange.postUpdate(thisChange)
household-de.map
NULL=NULL
UNDEF=UNDEF
0=Aus
1=Fertig
2=Aktiv
3=Standby
Please contact me if I forget anything.
(Dennis) #7
Thanks for your code. Now I will try. If I have any problems, I’ll come back to you if I may.
