Also not that the docs in the OP indicate you should create $OH_CONF/automation/jsr223 to put the library scripts into.
Then just import the library.
Now that the library has changed a ton since this was written and there are other aspects of the PaperUI roles that makes much of this documentation invalid. I’m waiting for most of that to get done and checked in before updating theses docs.
//not working
//var pe = Java.type(“org.eclipse.smarthome.model.persistence.extensions.PersistenceExtensions”);
//works
var OffsetDateTime = Java.type(“java.time.OffsetDateTime”);
var now = function(){ return OffsetDateTime.now(); };
//i’d like to have the lastUpdate of the item, i don’t know how to achieve
//var jdt = new DateTime(items[“Beregnung_TageOhneRegen”].toString());
//var jdt = new OffsetDateTime (items[“Beregnung_TageOhneRegen”].toString());
//var prevTime = previousState(“MyItem”).timestamp;
//var MyItem = getItem(“Beregnung_TageOhneRegen”);
//works
var logger =Java.type(“org.slf4j.LoggerFactory”).getLogger(“org.eclipse.smarthome.model.script.Rules”);
logger.error(“This is an error log”);
logger.warn(“This is a warning log”);
logger.info(“This is an info log”);
logger.debug(“This is a debug log”);
logger.trace(“This is a trace log”);
//var item = ir.getItem(“Beregnung_TageOhneRegen”).lastUpdate(“influxdb”);
//var prevTime = pe.previousState(ir.getItem(“Beregnung_TageOhneRegen”)).timestamp; //logger.info(“This is an info log” + prevTime);
//var asODT = OffsetDateTime.parse(ir.getItem(“Beregnung_TageOhneRegen”).lastUpdate);
2019-06-23 16:14:29.921 [WARN ] [omation.core.internal.RuleEngineImpl] - Fail to execute action: 2
java.lang.RuntimeException: java.lang.ClassNotFoundException: org.eclipse.smarthome.model.script.actions.ScriptExecution cannot be found by com.eclipsesource.jaxrs.publisher_5.3.1.201602281253
at jdk.nashorn.internal.runtime.ScriptRuntime.apply(ScriptRuntime.java:521) ~[?:?]
at jdk.nashorn.internal.runtime.Context.evaluateSource(Context.java:1438) ~[?:?]
at jdk.nashorn.internal.runtime.Context.load(Context.java:962) ~[?:?]
at jdk.nashorn.internal.objects.Global.load(Global.java:1719) ~[?:?]
at jdk.nashorn.internal.scripts.Script$Recompilation$299$rules$cu1$restOf.:program(/etc/openhab2/automation/jsr223/jslib/rules.js:20) ~[?:?]
at jdk.nashorn.internal.runtime.ScriptFunctionData.invoke(ScriptFunctionData.java:652) ~[?:?]
at jdk.nashorn.internal.runtime.ScriptFunction.invoke(ScriptFunction.java:513) ~[?:?]
at jdk.nashorn.internal.runtime.ScriptRuntime.apply(ScriptRuntime.java:517) ~[?:?]
at jdk.
var OPENHAB_CONF = Java.type("java.lang.System").getenv("OPENHAB_CONF");
load(OPENHAB_CONF + '/automation/lib/javascript/core/rules.js');
There still a lot of documentation left to be written for JS libraries, and the functionality is still evolving to get on par with Jython. An osgi.js was added 4 days ago, and I plan to add metadata.py and metadata.js later today!
2019-06-24 23:17:00.838 [INFO ] [jsr223.javascript ] - |Hello World!|
2019-06-24 23:17:00.838 [DEBUG] [e.automation.internal.RuleEngineImpl] - The rule ‘793a81f7-db03-40da-95fc-8f1a52f42340’ is executed.
2019-06-24 23:17:13.487 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Added ScriptEngine for language ‘application/javascript’ with identifier: 19de419c-2b4c-4680-8ed6-a68a89ef2de7
2019-06-24 23:17:14.055 [WARN ] [e.automation.internal.RuleEngineImpl] - Fail to execute action: 2
java.lang.RuntimeException: java.lang.ClassNotFoundException: org.openhab.core.automation.util.RuleBuilder cannot be found by com.eclipsesource.jaxrs.publisher_5.3.1.201602281253
at jdk.nashorn.internal.scripts.Script$Recompilation$716$rules$cu1$restOf.:program(/etc/openhab2/automation/lib/javascript/core/rules.js:16) ~[?:?]
at jdk.nashorn.internal.scripts.Script$Recompilation$681$^eval_$cu1$restOf/842791077.:program(:2) ~[?:?]
at jdk.nashorn.api.scripting.NashornScriptEngine.evalImpl(NashornScriptEngine.java:448) ~[?:?]
at jdk.nashorn.api.scripting.NashornScriptEngine.evalImpl(NashornScriptEngine.java:405) ~[?:?]
at jdk.nashorn.api.scripting.NashornScriptEngine.evalImpl(NashornScriptEngine.java:401) ~[?:?]
at jdk.nashorn.api.scripting.NashornScriptEngine.eval(NashornScriptEngine.java:154) ~[?:?]
at javax.script.AbstractScriptEngine.eval(AbstractScriptEngine.java:264) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.lambda$0(ScriptActionHandler.java:60) ~[?:?]
at java.util.Optional.ifPresent(Optional.java:175) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.execute(ScriptActionHandler.java:57) ~[?:?]
at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1191) [247:org.openhab.core.automation:2.5.0.201906210304]
at org.openhab.core.automation.internal.RuleEngineImpl.runNow(RuleEngineImpl.java:1039) [247:org.openhab.core.automation:2.5.0.201906210304]
at org.openhab.core.automation.internal.RuleEngineImpl.runNow(RuleEngineImpl.java:1055) [247:org.openhab.core.automation:2.5.0.201906210304]
at org.openhab.core.automation.rest.internal.RuleResource.runNow(RuleResource.java:288) [251:org.openhab.core.automation.rest:2.5.0.201906210325]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:564) ~[?:?]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) [129:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) [129:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) [129:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) [129:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) [129:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) [129:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) [129:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) [129:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [129:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [128:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [128:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [128:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [128:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [128:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [128:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [129:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [129:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [126:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [126:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [126:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [126:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [126:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [20:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:873) [92:org.eclipse.jetty.servlet:9.4.18.v20190429]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:542) [92:org.eclipse.jetty.servlet:9.4.18.v20190429]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [197:org.ops4j.pax.web.pax-web-jetty:7.2.10]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) [91:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [89:org.eclipse.jetty.security:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) [91:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) [91:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1700) [91:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) [91:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1345) [91:org.eclipse.jetty.server:9.4.18.v20190429]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [197:org.ops4j.pax.web.pax-web-jetty:7.2.10]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) [91:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:480) [92:org.eclipse.jetty.servlet:9.4.18.v20190429]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1667) [91:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) [91:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1247) [91:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) [91:org.eclipse.jetty.server:9.4.18.v20190429]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [197:org.ops4j.pax.web.pax-web-jetty:7.2.10]
at org.eclipse.jetty.server.Server.handle(Server.java:505) [91:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:370) [91:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:267) [91:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:305) [82:org.eclipse.jetty.io:9.4.18.v20190429]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [82:org.eclipse.jetty.io:9.4.18.v20190429]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [82:org.eclipse.jetty.io:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [94:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [94:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [94:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [94:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [94:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:698) [94:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:804) [94:org.eclipse.jetty.util:9.4.18.v20190429]
at java.lang.Thread.run(Thread.java:844) [?:?]
As for the error, my guess is that you saved the rule and then tried to execute it without triggering it first. This is a known bug (the issue has not yet been migrated over from the ESH repo). You can manually execute rules that use Scripted Actions, but you need to trigger them first after every save.
The choice is yours to make. It’s not just a decision between JavaScript and Python… it’s Nashorn and Jython. These scripting languages, including the underlying ScriptEngines and how they interact with Java, behave very differently. If you are a web developer with experience using very old versions of JS and only plan to do simple rules, then Nashorn seems like the best choice, especially once a scripting API or the helper libraries have been built out. Otherwise, you are passing up a much more powerful tool for scripted automation in Jython, and it comes with a complete set of helper libraries and documentation.
How do i get the below table in scripts that don’t execute from Paper UI generated rules?
Object
Purpose
event
Describes the event that caused the Rule to trigger. This variable does not exist unless the Rule was triggered by an Item or Channel event.
command
The command that caused the Rule to trigger. This is equivalent to receivedCommand in Rules DSL. This variable does not exist unless the Rule is triggered by a command.
oldState
The previous state of the Item. If it is UNDEF or NULL the variable will be blank when logged. This is equivalent to previousState in Rules DSL. It does not exist unless the Rule was triggered by an item changed trigger.
newState
The current state of the Item. If it is UNDEF or NULL the variable will be blank when logged. This is equivalent to triggeringItem.state in Rules DSL. Only exists when the Rule was triggered by an item changed trigger.
state
The current state of the Item. If it is UNDEF or NULL the variable will be blank when logged. This is equivalent to triggeringItem.state in Rules DSL. Only exists when the Rule was triggered by an item updated trigger.
I am trying to migrate over my DSL rules to JSR223 via scripts and can’t figure out how to replicate the receivedCommand object from RulesDSL
JSRule({
name: "HVAC Control Relays",
description: "Relay Controls for Downstairs HVAC",
triggers: [
CommandEventTrigger("HVAC_Relay_Op_State")
execute: function( module, input){
// first send command to switch over to relay control
logInfo("AC_Control.js", "Starting the HVAC COntrol Rule")
sendCommand("Konnected_AC_Out", OFF);
//always ensure that fan is on as well
sendCommand("Konnected_AC_Zone_5", ON);
logInfo("zach zach");
//logInfo("zach zach " + command);
logInfo("zach 2 " + event.itemName);
yields the following in my logs:
2019-06-29 10:54:55.521 [INFO ] [jsr223.javascript ] - |AC_Control.js|
1:'Starting the HVAC COntrol Rule'
2019-06-29 10:54:55.522 [INFO ] [jsr223.javascript ] - |zach zach|
2019-06-29 10:54:55.523 [ERROR] [omation.core.internal.RuleEngineImpl] - Failed to execute rule '136b1df8-5b7b-4c7e-8c24-06440a055023': Fail to execute action: 1
I get the same error if if uncomment out the logInfo zach zach + command line
These are not language specific. I’ve gone through the code for all of the existing triggers (each trigger provides different event attributes) and documented them…
It’s not the only way nor even the best way. A lot has changed since I started writing these and the UI is being completely rewritten which is largely why I stopped writing this series. It will be picked back up again soon and it will make it into the docs. There is already a really good start to a beginner;s tutorial you can find here.
But if you are using anything but Rules DSL in OH 2.X you are using the NGRE. In OH 3, it’ll be just called the Rule Engine and it will also run Rules DSL.
For the specific task of using scripts within NGRE in papaerUI, I’d say it is the best tutorial .
I am not using he helper lib as it seems to be changing and I don’t want to rely on it yet.
Although I have a good experience with OH, but it was not easy to find out what APIs are available and what are not (I am still trying to find out how to load the logger )
