hello, newbie on using openHAB.
I defined a Hue lamp as an item in combination with expire binding. I made several switches with a different time to send “off” command.
When I manualy use the main switch on the sitemap to put the light on, all the time-switches go ON besides the main switch, and the light itself goes OFF after 30 seconds (the first expire defined item).
How do I define the item-switches in a correct way to distinguish the switches from each other?
I use an Intel NUC with Windows 10 and openHAB 2.5.0.M5 Milestone Build
Hi Thomas and welcome to the OpenHAB community!
What I’m not 100% clear on is if you are using Paper User Interface to create your Hue lamp ‘thing’
The first configuration file you posted says things: but it appears to be an items file
It is possible to create OpenHAB ‘things’ in a file, but for a new guy just getting started, letting Paper User Interface do it for you is much easier and less prone to problems. If the first configuration is actually a ‘items’ file (placed in the items folder) then you are good
Also if you are going to post files and rules (which is great because it will help us help you) place your stuff in code fences as it is much easier to read. Just place three tilde on a line (by themselves) before and after your code
example
rule "my rule"
it also helps to know your OpenHAB version and the platform it is running on
Hello Andrew, thx for swift response. Not totally familiar with the vocublary yet, sorry for that. Off course I meant Items instead of things. I Adjusted the original post. Hope things (items :-)) are clear now.
OK… I’m going to guess the light gets turned on and OpenHAB turns it back off reacting to the first item which is the shortest time period… guessing
I think your idea would work with just one switch but with 4, you may have to write a rule. What is the point of having 4? I get the idea is to have 4 different time periods but to what end?
Maybe there is a misunderstanding of what expire does. Any update or command to the Item (that does not match the expire instruction) begins or restarts the timing.
So, in the case of four “expiring” Items linked to the same channel … any update on the channel starts all four Items expire timers.
You could have no channels linked to the four Items. And a rule that listensd for a command to any one of them and passes it to the “real” Item/channel.
I resume this post because I really cannot understand how to use the expire binding. All I want to do is having a button on my UI that trigger my TV to poweroff after 60min
These are my items
Switch CA_TV_OnOff "TV bedroom" (CL) ["Switchable"] { channel="samsungtv:tv:0bebc200_00c8_1000_9f61_50856903009e:power"}
Switch CA_TV_AutoOff "Turn off after 60min" <button> (CL) {expire="60m,command=OFF" }
This is my rule:
rule "TV bedroom autooff"
Item CA_TV_AutoOff received command
CA_TV_OnOff.sendCommand(OFF)
But when I push the CA_TV_AutoOff button on the UI the rules is immediately triggered and my tv switch off.
How can I have a button that when pressed simply start the trigger that turnoff my tv after XX min ?
