I have some items I set expire = “X- m, command = STOP”
And I would like to see how much time is left until item goes off
Is this possible?
Nope.
You can set some other data Item to datetime when you begin the timing, and calculate how long it’s been going or how there is left. If you tell us what you want it for, there might be other solutions.
I use telegram action and then I look at when I turned on the switch according to the message in the telegram and that’s how I calculate how much time is left.
I thought there was a better way to calculate the time left …
