Hey everyone,
tl;dr
Any ideas, how to archieve a dynamic approach to manipulate a local variable based on an unknown amount of arrays in a second JSON file?
What I would like to do?
I use the Twitch API (a tech/gaming live streaming service) in my setup to extract informations about channels and their current streaming status. I reuse these informations to start kodi-plugins etc.
Everything works fine in a more or less rigid setup.
I´d like to extend this with a more flexible approach, by checking my twitch-follows (also possible via one of their API endpoints) from time to time - without calling the API too often. Currently I´m following two channels (as you see in the output of the JSON examples below), but it can be 5, 10 or up to 200.
In their newest API revision (v5) you need to send a get request to multiple endpoints to get all the informations you need.
and what the heck is your problem?
I would like to avoid calling the “channel” API-endpoint for each data-array in the “follows” output, but I can´t get it managed to add and convert the right amount or arrays from the first API request:
../users/follows?from_id=123456
- Requesting all followers for id 123456 -
../users?id=123456&id=78901234&id=56789012...
- Requesting detailed informations about all followed channels
I´m pretty sure that this is possible with some kind of loop or REGEX transformation, but after a long night out yesterday my search skills seems drained and I´m kinda stuck.
Someone willed to kick my butt and point me in the right direction?
follows JSON output
"total": 2,
"data": [
"from_id": "123456789",
"to_id": "35987962",
"followed_at": "2018-05-16T18:54:35Z"
"to_id": "12875057",
"followed_at": "2018-04-30T23:04:55Z"
"pagination": {
"cursor": "eyJiIjpudWxsLCJhIjoiMTUyNTEyOTQ5NTc0MTAxNDc2OSJ9"
channel JSON output (Multiple values in request allowed)
{"data": [
"id": "35987962",
"login": "linustech",
"display_name": "LinusTech",
"type": "",
"broadcaster_type": "partner",
"description": "We broadcast WAN Show, gaming hardware builds and Q&A's, and more through this channel. Check our the rest of what we do at http://www.youtube.com/LinusTechTips",
"profile_image_url": "https://static-cdn.jtvnw.net/jtv_user_pictures/linustech-profile_image-38d527cc424347f5-300x300.jpeg",
"offline_image_url": "https://static-cdn.jtvnw.net/jtv_user_pictures/97e024d6311cca7d-channel_offline_image-1920x1080.jpeg",
"view_count": 7070482
"id": "12875057",
"login": "gronkh",
"display_name": "GRONKH",
"type": "",
"description": "Zart im Schmelz und süffig im Abgang. Ungebremster Spieltrieb seit 1896.",
"profile_image_url": "https://static-cdn.jtvnw.net/jtv_user_pictures/gronkh-profile_image-76b34139eaa46bb5-300x300.png",
"offline_image_url": "https://static-cdn.jtvnw.net/jtv_user_pictures/gronkh-channel_offline_image-eb70f551d9327737-1920x1080.jpeg",
"view_count": 50098542
twitch.rules
rule "Getting twitch data periodically"
Item Twitch_StreamerRefresh received command //Testing switch
if (clientId!==true || twitchUserId!==true) {
//Twitch Helix API #1 - grabbing follows of user
var rawMessageFollows = executeCommandLine('curl -X GET --silent --header “accept:application/json” --header "client-id:' + clientId + '" "https://api.twitch.tv/helix/users/follows?from_id=' + twitchUserId + '"', 5000)
Twitch_FollowsAPI.postUpdate(rawMessageFollows) //Store API response
// Twitch Helix API #2 - grabbing user info
Thread::sleep(500) //Wait for the script to catch up
var rawMessageUsers = executeCommandLine('curl -X GET --silent --header “accept:application/json” --header "client-id:' + clientId + '" "https://api.twitch.tv/helix/users?id=' + twitchUserId + '"', 5000)
Twitch_UsersAPI.postUpdate(rawMessageUsers) //Store API response
logInfo("Twitch.TV", "Helix API (users): "+rawMessageUsers) //Send stuff to log
else {
logInfo("Twitch.TV", "ERROR: No client-/user-ID found in *.rules. Please provide valid ID(s)!")
Thank you!
