Switched over to OH 2.1 about 2 weeks ago. Had a bit of a difficulty in rewriting all config files, but I am there for 90%.
I have a EZMotion Express sensor (movement, temp and luminance) that I think stopped reporting after I made the cut over, but I am not really sure. Anyway, the device is initialized, its reporting values in the log but they never end in the channel but the battery level…
for instance Temperature
2017-10-02 21:19:24.297 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 11: Received COMMAND_CLASS_SENSOR_MULTILEVEL command V5
2017-10-02 21:19:24.298 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 11: Sensor Multi Level REPORT received
2017-10-02 21:19:24.298 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 11: Sensor Type = Temperature(1), Scale = 1
2017-10-02 21:19:24.298 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 11: Sensor Value = 71.7
2017-10-02 21:19:24.298 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2017-10-02 21:19:24.299 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 71.7
2017-10-02 21:19:24.299 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 11: No sensorType set for channel zwave:device:0042a834:node11:alarm_motion
Luminance:
2017-10-02 21:19:24.222 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 11: Incoming command class SENSOR_MULTILEVEL
2017-10-02 21:19:24.222 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 11: Received COMMAND_CLASS_SENSOR_MULTILEVEL command V5
2017-10-02 21:19:24.222 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 11: Sensor Multi Level REPORT received
2017-10-02 21:19:24.223 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 11: Sensor Type = Luminance(3), Scale = 0
2017-10-02 21:19:24.223 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 11: Sensor Value = 35
2017-10-02 21:19:24.223 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2017-10-02 21:19:24.223 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 35
2017-10-02 21:19:24.224 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 11: No sensorType set for channel zwave:device:0042a834:node11:alarm_motion
Its reporting against the alarm_motion channel but I think that is wrong. The alarm_motion channel is working:
2017-10-02 20:41:18.208 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 11: Incoming command class BASIC
2017-10-02 20:41:18.208 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 11: Received Basic Request
2017-10-02 20:41:18.208 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 11: Basic Set sent to the controller will be processed as Basic Report
2017-10-02 20:41:18.208 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 11: Basic report, value = 0xFF
2017-10-02 20:41:18.208 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-10-02 20:41:18.208 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 255
2017-10-02 20:41:18.209 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Updating channel state zwave:device:0042a834:node11:alarm_motion to 255 [DecimalType]
2017
as is the battery report:
2017-10-02 20:50:20.271 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 11: Starting initialisation from DONE
2017-10-02 20:50:20.273 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 11: Incoming command class BATTERY
2017-10-02 20:50:20.274 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 11: Received Battery Request
2017-10-02 20:50:20.274 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 11: Battery report value = 89
2017-10-02 20:50:20.275 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-10-02 20:50:20.275 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = BATTERY, value = 89
2017-10-02 20:50:20.276 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Updating channel state zwave:device:0042a834:node11:battery-level to 89 [DecimalType]
Anybody using this sensor and having the same experience?
regards,
Han
