- Platform information:
Hardware: RPI2
OS: Raspbian buster
Java Runtime Environment: OpenJDK Runtime Environment (build 1.8.0_212-8u212-b01-1+rpi1-b01)
openHAB version: 2.5.1 (via apt repositories)
- Issue of the topic:
I try for several weeks to add EZmotion device to openhab but I do not receive updates of temperature and luminance and on habmin Z-Wave Network Viewer My 2 EZmotion devices (24 and 28) seams to not communicate with controler (1)
On thing configuration, the Association group field is empty.
When I choose Controller from drop down list, save the configuration after changing of thing, the Association group field is emptied.
When I make the change, I have the following on debug log:
openhab> log:set DEBUG org.openhab.binding.zwave
openhab> log:tail org.openhab.binding.zwave
10:33:57.723 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 28: Configuration update received
10:33:57.744 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 28: Configuration update set group_1 to [controller] (ArrayList)
10:33:57.754 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 28: Association 1 consolidated to [controller]
10:33:57.766 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 28: Unknown association group 1
I tried several times to exclude/include the device to the network and pushing the include/awake button on the device several time before and during the changes without success.
I just notice on debug logs that node 28 send updates to the network but they are not received by the thing:
2020-01-17 10:34:10.405 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 1C 03 80 03 64 0A
2020-01-17 10:34:10.416 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=28, callback=0, payload=00 1C 03 80 03 64
2020-01-17 10:34:10.421 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=28, callback=0, payload=00 1C 03 80 03 64
2020-01-17 10:34:10.424 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-01-17 10:34:10.427 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 28: Application Command Request (ALIVE:UPDATE_DATABASE)
2020-01-17 10:34:10.430 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 28: Incoming command class COMMAND_CLASS_BATTERY, endpoint 0
2020-01-17 10:34:10.433 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 28: SECURITY not supported
2020-01-17 10:34:10.435 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 28: Received COMMAND_CLASS_BATTERY V1 BATTERY_REPORT
2020-01-17 10:34:10.438 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 28: Battery report value = 100
2020-01-17 10:34:10.442 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2020-01-17 10:34:10.443 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 1C 05 31 05 03 01 05 DA
2020-01-17 10:34:10.445 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_BATTERY, value=100
2020-01-17 10:34:10.450 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Updating channel state zwave:device:c71311cd:node28:battery-level to 100 [DecimalType]
2020-01-17 10:34:10.462 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 28: Commands processed 1.
2020-01-17 10:34:10.465 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 28: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@edc2c6.
2020-01-17 10:34:10.469 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-17 10:34:10.475 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-17 10:34:10.477 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=28, callback=0, payload=00 1C 05 31 05 03 01 05
2020-01-17 10:34:10.478 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-01-17 10:34:10.481 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-01-17 10:34:10.485 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0C 00 04 00 1C 06 31 05 01 2A 02 A8 58
2020-01-17 10:34:10.485 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=28, callback=0, payload=00 1C 05 31 05 03 01 05
2020-01-17 10:34:10.488 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-01-17 10:34:10.490 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 28: Application Command Request (ALIVE:UPDATE_DATABASE)
2020-01-17 10:34:10.492 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 28: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
2020-01-17 10:34:10.492 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=28, callback=0, payload=00 1C 06 31 05 01 2A 02 A8
2020-01-17 10:34:10.494 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 28: SECURITY not supported
2020-01-17 10:34:10.496 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 28: Received COMMAND_CLASS_SENSOR_MULTILEVEL V5 SENSOR_MULTILEVEL_REPORT
2020-01-17 10:34:10.497 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 28: Sensor Type = Luminance(3), Scale = 0
2020-01-17 10:34:10.499 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 28: Sensor Value = 5
2020-01-17 10:34:10.501 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2020-01-17 10:34:10.503 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_MULTILEVEL, value=5
2020-01-17 10:34:10.505 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 28: No sensorType set for channel zwave:device:c71311cd:node28:alarm_motion
2020-01-17 10:34:10.507 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 28: Commands processed 1.
2020-01-17 10:34:10.509 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 28: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@f763e0.
2020-01-17 10:34:10.510 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-17 10:34:10.512 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-17 10:34:10.515 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=28, callback=0, payload=00 1C 06 31 05 01 2A 02 A8
2020-01-17 10:34:10.516 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-01-17 10:34:10.518 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 28: Application Command Request (ALIVE:UPDATE_DATABASE)
2020-01-17 10:34:10.521 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 08 00 04 00 1C 02 84 07 6E
2020-01-17 10:34:10.526 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=28, callback=0, payload=00 1C 02 84 07
2020-01-17 10:34:10.538 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 28: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
2020-01-17 10:34:10.540 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 28: SECURITY not supported
2020-01-17 10:34:10.547 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 28: Received COMMAND_CLASS_SENSOR_MULTILEVEL V5 SENSOR_MULTILEVEL_REPORT
2020-01-17 10:34:10.550 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 28: Sensor Type = Temperature(1), Scale = 1
2020-01-17 10:34:10.555 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 28: Sensor Value = 68
2020-01-17 10:34:10.558 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2020-01-17 10:34:10.564 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_MULTILEVEL, value=68
2020-01-17 10:34:10.567 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 28: No sensorType set for channel zwave:device:c71311cd:node28:alarm_motion
2020-01-17 10:34:10.571 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 28: Commands processed 1.
2020-01-17 10:34:10.574 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 28: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@401e9.
2020-01-17 10:34:10.577 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-17 10:34:10.579 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-17 10:34:10.583 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=28, callback=0, payload=00 1C 02 84 07
2020-01-17 10:34:10.586 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-01-17 10:34:10.589 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 28: Application Command Request (ALIVE:UPDATE_DATABASE)
2020-01-17 10:34:10.592 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 28: Is awake with 0 messages in the queue
2020-01-17 10:34:10.594 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 28: Start sleep timer at 5000ms
2020-01-17 10:34:10.596 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2020-01-17 10:34:10.633 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 28: Node Status event - Node is AWAKE
2020-01-17 10:34:10.636 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 28: Commands processed 1.
2020-01-17 10:34:10.639 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 28: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1d0c83c.
2020-01-17 10:34:10.641 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-17 10:34:10.644 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-17 10:34:10.646 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-01-17 10:34:10.649 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
Updates seams to be sent to alarm_motion channel insted of temp/luminance ones.
- Please post configurations (if applicable):
- Items configuration related to the issue
openhab> smarthome:things show zwave:device:c71311cd:node28
UID: zwave:device:c71311cd:node28
Type: zwave:homeseer_ezmotionexpress_00_000
Label: Hallway Z-Wave Node 028: EZMotion Express Wireless 3-in-1 Sensor
Status: ONLINE: Node initialising: UPDATE_DATABASE
Bridge: zwave:serial_zstick:c71311cd
Properties:
zwave_class_basic : BASIC_TYPE_ROUTING_SLAVE
zwave_class_generic : GENERIC_TYPE_SENSOR_BINARY
commandClass:COMMAND_CLASS_NODE_NAMING:2 : ccRemove
commandClass:COMMAND_CLASS_NODE_NAMING:1 : ccRemove
commandClass:COMMAND_CLASS_MANUFACTURER_SPECIFIC:1 : ccRemove
commandClass:COMMAND_CLASS_NODE_NAMING:3 : ccRemove
zwave_neighbours :
zwave_lastwakeup : 2020-01-17T11:31:20Z
modelId : EZMotion Express
zwave_version : 0.0
commandClass:COMMAND_CLASS_MULTI_CHANNEL:3 : ccRemove
commandClass:COMMAND_CLASS_MULTI_CHANNEL:1 : ccRemove
commandClass:COMMAND_CLASS_MULTI_CHANNEL:2 : ccRemove
commandClass:COMMAND_CLASS_VERSION:1 : ccRemove
vendor : Express Controls
defaultAssociations : 1
zwave_routing : true
commandClass:COMMAND_CLASS_ASSOCIATION:2 : ccRemove
commandClass:COMMAND_CLASS_ASSOCIATION:1 : ccRemove
zwave_beaming : true
commandClass:COMMAND_CLASS_ASSOCIATION:3 : ccRemove
zwave_secure : false
zwave_class_specific : SPECIFIC_TYPE_ROUTING_SENSOR_BINARY
commandClass:COMMAND_CLASS_MANUFACTURER_SPECIFIC:2 : ccRemove
commandClass:COMMAND_CLASS_VERSION:2 : ccRemove
commandClass:COMMAND_CLASS_MANUFACTURER_SPECIFIC:3 : ccRemove
commandClass:COMMAND_CLASS_VERSION:3 : ccRemove
zwave_devicetype : 2
commandClass:COMMAND_CLASS_CONFIGURATION:1 : ccRemove
commandClass:COMMAND_CLASS_CONFIGURATION:3 : ccRemove
zwave_frequent : false
commandClass:COMMAND_CLASS_CONFIGURATION:2 : ccRemove
zwave_listening : false
manufacturerId : 001E
manufacturerRef : 0002:0001,0002:0002
dbReference : 140
zwave_deviceid : 2
zwave_nodeid : 28
commandClass:COMMAND_CLASS_WAKE_UP:1 : ccRemove
commandClass:COMMAND_CLASS_WAKE_UP:3 : ccRemove
commandClass:COMMAND_CLASS_WAKE_UP:2 : ccRemove
commandClass:COMMAND_CLASS_BATTERY:2 : ccRemove
commandClass:COMMAND_CLASS_BATTERY:1 : ccRemove
zwave_manufacturer : 30
commandClass:COMMAND_CLASS_BATTERY:3 : ccRemove
Configuration parameters:
binding_cmdrepollperiod : 1500
action_failed : false
wakeup_interval : 360
action_remove : false
binding_pollperiod : 86400
action_heal : false
config_1_1 : 200
config_2_1 : 5
wakeup_node : 1
config_3_1 : 255
config_4_1 : 100
config_5_1 : 0
node_id : 28
config_6_1 : 255
Channels:
Label: Motion Sensor
Type: zwave:alarm_motion
Description: Indicates if a motion alarm is triggered
Label: Battery Level
Type: system:battery-level
Label: Illumination Sensor
Type: zwave:sensor_luminance
Description: Indicates the current light reading
Label: Temperature Sensor
Type: zwave:sensor_temperature
Description: Indicates the current temperature
