I am trying to install OpenHABian on my raspberry PI 2.
I tried with 2G SD card and it failed at JAVA installation.
Then I tried with 4G SD card and it failed sooner. At repository update…
2017-04-10_09:59:42_UTC [openHABian] Ensuring network connectivity… OK 2017-04-10_09:59:42_UTC [openHABian] Waiting for dpkg/apt to get ready… OK 2017-09-18_18:00:26_UTC [openHABian] Updating repositories and upgrading install ed packages… FAILED 2017-09-18_18:43:32_UTC [openHABian] Initial setup exiting with an error.
The 4GB card should technically be big enough. Please try once again. Are you using any special network settings or is your ISP/country known to block certain internet services?
